Question about Sharp LC-42P7M 42 in. LCD TV
How do i know whether my tv is analog or digital
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sharp Master
  • 102,366 Answers
The LC-42P7M is both. It accepts both digital and composite (analog) inputs.
Posted on Jul 19, 2013
New digital Flat screen TV (Element) only tunes analog Cable channels no digital
Check its user manuals' specification page, to know whether this TV is digital signal compactable one or not.
Dec 02, 2013 | Televison & Video
How can i use dvi port
DVI stands for (D)igital (V)ideo (I)nterface.
DVI is a new form of video interface technology made to maximize the quality of flat panel LCD monitors and high-end video graphics cards. It is a replacement for the P&D Plug & Display standard.
you can connect high definition monitor , LCD projector , LCD T.V to a DVI port
There three kind of DVI connector
1. DVI-D (Digital)
2. DVI-A (Analog)
3. DVI-I (Integrated Digital/Analog)
DVI-D format is used for direct digital connections between source video (namely, video cards) and digital LCD (or rare CRD) monitors
DVI-A - High-Res Analog
DVI-A format is used to carry a DVI signal to an analog display, such as a CRD monitor or and HDTV
DVI-I - The Best of Both Worlds
DVI-I format is an integrated cable which is capable of transmitting either a digital-to-digital signal or an analog-to-analog signal, but it will not work transmitting a digital-to-analog or analog-to-digital signal.
How to Recognize These three types of DVI Cable
There are two variables in every DVI connector cable, and each represents one characteristic.
The flat pin on one side denotes whether the cable is digital or analog:
A flat pin with four surrounding pins is either DVI-I or DVI-A
A flat pin alone denotes DVI-D
The pinsets vary depending on whether or not the cable is single- or dual-link:
A solid 27-pin set (rows of 8) for a dual- link cable
Two separated 9-pin sets (rows of 6) for a single-link cable
Jul 12, 2011 | Computers & Internet
I live in Florida. I purchased a (Portable Mobility DVD) 16" Portable Multimedia DVD and LCD TV from a vendor in China. The TV unit only receives "Analog signals", which are no longer...
The gadget you need is called a Digital (to Analog) Converter.
This is also referred to as a digital Set-Top Box (STB) and connects to the cable from your antenna. The STB is then connected to the TV. An antenna only receives the signal and cannot convert the digital transmission to an analog signal which your TV can display. Please click on the link below for an example of a Digital Converter:
http://www.amazon.com/iView-1000STB-Digital-Analog-Converter/dp/B003P5MFX2/ref=sr_1_1?ie=UTF8&qid=1298837630&sr=8-1
I am uncertain whether this specific product would actually be suitable for you as you didn't fully explain what you mean by "mobile". This product would only be suitable for an RV if you have a DC/AC inverter and 120v transformer as it requires domestic mains voltage to work.
Please could you explain your "mobile" situation in a little more detail and let me know whether you have mains AC voltage. I will then be able to tell you whether this product is suitable for your requirements or find some alternatives that will be.
Hope this helps. If you need further assistance, please reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Feb 27, 2011 | Televison & Video
We are in Ghana we need frequency and we update to get more channel
Your flat panel TV is probably factory set to receive ATSC signals (Hi-def DIGITAL TV), whereas
Ghana may not have converted from analog TV (NTSC) yet.
Digital TV's cannot receive analog signals. I'm just guessing about whether or not Ghana supports
Hi-Def broadcasts - you'll have to check with (any) TV channel in Ghana. The Analog-to-digital
conversion is an expensive one at the broadcast end, and may not have happened yet in Ghana.
The US conversion took place by FCC mandate June 12, 2009.
There are available $65 (USD) digital-to-analog converters, but what you may need is an
analog-to-digital converter, which doesn't exist. Your Flat-panel TV amy have to wait until Ghana
begins broadcasting a Hi-Def TV channel.
For a HD antenna, a regular old rabbit ear-type antenna will do.
Oct 15, 2010 | Televison & Video
How can I set my TV as analog or digital?
It should be done in the settings on the TV itself through the menu options and through the connections on the back. Whatever input you hook up as your source input on the back, the menu set up through the TV menu should correspond to whatever method you chose as your source, whether it be analog or digital. I hope this helps.
Oct 26, 2009 | Philips Televison & Video
Is our Quasar TV (SP2723) a digital or analog television?
That's an analog TV and would need a converter box for the new digital broadcasting.
Nov 28, 2008 | Quasar SP-2723 27" TV
How can I get Freeview Channels?
I have a Bush 6690D and I can confirm that it does have a built-in digital decoder for terrestrial signals (Freeview).
Have you checked whether ***********'s TV is set to digital mode ? The "Mode" button on the remote cycles between analog, digital and AV inputs.
Oct 23, 2008 | Bush DVD2038 DVD Player
Sony Trinirton TV and DAV-HDX 275 System
Here are a couple of the most common reasons for your problem:
Make sure you have selected the right input source on the DAV-HDX275 that your TV station source (cable, satellite, direct TV or whatever you get TV stations from) is connected to on the DAV-HDX275.
Also make sure that if you are using a digital input (HDMI, optical, or coaxial) from the TV station source, that the DAV-HDX275 in set for a digital input and on the right source.
If you are using an analog source (red and white RCA jacks) for the TV stations , make sure you do not have the digital input activated for that source on the DAV-HD275. You need to select the analog option.
You must also be sure that you have a cable, whether it is analog or digital, connected from the cable box to the DAV-HD275.
I hope this was helpful to you, it is always very important to double check all the connections and make sure the stereo is set to the right type of input (digital or analog).
If you have found this to be helpful, a good rating is always appreciated. Thanks and let me know if you need any more help.
Jun 22, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Sharp LC-42P7M 42 in. LCD TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
