Question about Lexmark X9575 InkJet Printer
My printer will not power on
It worked one day and the next it had no power, I tried unplugging it and nothing worked. Is there a fuse that might have blown?
  • maryann Jul 22, 2013
    No fuse..I took it apart from top to back. everything looked like new inside. no apparent problem. I put it back together, one last try and no power, so in the trash it went.
    Champion:
  • 247 Answers
Yes u need to open it to replace fuse
Posted on Jul 19, 2013
FRIGIDAIRE FRS20ZRG STOPPED WORKING AFTER MOVING IT, LIGHTS STOPPED THE NEXT DAY
It may have been defrosting on a timed cycle when the compressor stopped. If any water was present at the time, it may have seeped into the electrics. Check the fuse and you have power to the on/off switch and thermostat.. If fuse blown, check all is dried out before plugging back in.
Apr 21, 2012 | Frigidaire Refrigerators
Blinking lights
Power off printer, remove power plug from printer, remove usb cable from printer, pull out paper and check for jams, check toner cartridge, clean area underneath the toner cartridge head, uninstall printer from windows control panel, reboot computer, plug-in printer with a different working usb cable, plug in power to printer, power on printer, reinstall printer driver. All in those steps exactly. If that doesn't work I would say you have a bad printer on your hands.
Nov 16, 2011 | Dell 1110 Laser Printer
TV will not do anything. working one day nothing the next day
Try unpluging tv and hold down power button for one minute. Maybe tv will reset itself. Most tv have a fuse tiny you will have to remove back panel to replace. Hope this helps!
Aug 23, 2011 | Dynex Televison & Video
Nothing happens. it death. was working fine. an them .. the next day nothing ...
Sorry to read about your problem, I hope this helps you out.
here are some problems you may have.
  1. No power to outlet (blown fuse or tripped breaker or GFCI).
  2. Blown main fuse - likely due to other problems.
  3. Open thermal protector or thermal fuse.
  4. Defective controller or its power suppy
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | Frigidaire FMCB115GC Microwave Oven
Canon Pixma Mp810 won't turn on, any suggestions
I had the same problem. Everything was working fine one day, but when I tried to switch it on the next day, nothing! The status light came on green briefly but then turned off. I thought the power module might be blown so I ordered a new one, that changed nothing, my printer was still completely dead, showing no sign of working at all.
I dismantled it to inspect every component for signs of failure, everything looked like new. Having read that the print heads can fail (dry out then blow) on canon printers, I tried starting the printer without the printhead and hey presto, it turned on and went through it's startup cycle. After making whirring sounds for a while a message popped up telling me that there was no printhead installed. As soon as I reinserted the printhead the printer turned off and wouldn't turn on again, even if I removed the printhead again (and unplugged/waited etc). I had to unplug and then re-plug a connector on the printer's motherboard to get back to the stage when the printer would turn on (without the printhead).
I have inspected the printhead with high powered magnification and found nothing unusual - a new printhead is about $100! My final conclusion is that there is nothing actually "wrong" with the printer but rather that it is a case of programmed obsolescence. My printer is about 5 years old (like new) and in the service manual that is the prescribed lifetime for the printer, so it's designed to simple stop working after that time.
PS. I did do the ink well reset procedure, didn't help.
Mar 19, 2010 | Canon PIXMA MP810 All-In-One InkJet...
No power to left drivers door
it is likely a relay in the fuse panel under the dash. feel the tops of them as you have someone try the power locks or windows if that is not working. the relay should click or become very hot.
Sep 17, 2009 | 2003 GMC Sierra
Won't turn on
try the fuse in the plug
Apr 26, 2008 | Brother HL 1440 Laser Printer
No power lights
I had the same problem and here is how I fixed it. Well, it's not really fixed but I circumvented the problem. I had my 4L unplugged for months because I was using an Okidata for a while. When I plugged in the 4L it wouldn't power up anymore. It worked when I put it storage, but not now. I tried plugging it in and out so much I got to the point where I was going to toss it. No help on line, nothing in the manuals. AHhhhh!
Then on a hunch I tried this...
I plugged the thing in and let it sit for hours. Then I unplugged it. After some time (hours) I plugged it back in and let it sit for hours. Then unplugged again for hours. Then plugged back in and I saw all the lights flash for a brief moment, but then they all went off. I just kept repeating this (it will take at least a whole day or more), and eventually when I plugged it back in it came to life. At this point DON'T UNPLUG IT!
Now...I was able to duplicate this fix because I recently moved and the thing was unplugged again for a few days. Plugged it back in at my new house and guess what, yea..same problem, but I went through the same procedure and it worked again.
Now it will not be unplugged.
Mar 18, 2008 | HP LaserJet 4L Printer
Won't power up
I fixed it! Instead of 20 minutes I unplugged it for about 4 hours and everything is working fine. It's a moody ol' girl.
Mar 02, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Lexmark X9575 InkJet Printer Logo
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
