Bn59 01010a remote control
More than half the buttons are not working..What should be done?
    Top Expert:
  • 12,223 Answers
See the picture attached, use digital camer or webcam cell, the LED must be TURN ON from r. control. Otherwise you open the r.control and clean the keypads from dirty, corrosion, oxide, use contacts cleaner solvent, and fix it. try it
God bless youbn59 01010a remote control - 63b5d974-59ff-42fc-bd06-0cdde0cf6e70.jpg
Posted on Jul 19, 2013
Can not get my steam vac to suck up water everything else works.done half floor empty water to do other half of floor and it just stopped sucking up water
  • There a twist lever on the side to change from floor to tools. If "everything else works" then you have it on tools. Twist it back to floor and it will work.
Sep 11, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
My remote for my 1999 vw bug dose not work
The first thing to try is a new battery. Mine takes a CR2032 coin cell. Replacement isn't difficult, just pull the two halves of the remote apart; the top half with the key separates from the bottom half with the buttons, then the bottom half opens up and the battery is right there. No tools needed.
When you press a button, you should see the red LED on the remote light up. You can also take it to most auto parts stores, and they'll have a tester that will tell you if your remote is generating a signal or not. If you've replaced the battery and the tester doesn't show a signal, it may be time to replace the remote.
A replacement remote will have to be programmed for your car, but it's not a difficult procedure and you don't have to go to a dealer to get it done. An internet search should give you instructions fairly easily.
May 03, 2014 | 1999 Volkswagen Beetle
E shows on left of screen with 0 on right hand side. I can't get it to respond to any prompt.
sounds as if your calculator has registered a number to large to display. this can be done in either the normal calculating mode, or in the memory calculating mode. i will help with both scenarios.
for normal calculating mode:
try pressing the CE button and holding for about a half a second. the E should disappear and calculating function should resume.
if that doesn't work, try disconnecting power supply for a few seconds, then reestablishing power and hit CE
for memory calculating mode(there will be a M on the screen as well if this is the problem)
press either the CE or MC/MCE button for a half second. this should return normal function.
if that doesn't work, try the power reset as described above.
Jan 15, 2014 | Canon MP18D II Basic Calculator
Zanussi washing machine pause button flashing machine wont work iz141s
Disconnecting the wires from the main PCB helped resolve half the problem, but the machine still does not rinse and spin. Unless programmed manually. Still, that's easily done at the end of a wash cycle. Is liveble.
Jul 24, 2012 | Zanussi ZWF1440 Front Load Washer
Why does my remote control only work on the volumn and mute buttons
Most likely the TV button is not hit. At the top, you need to depress the correct button to control the correct peripheral. If you have done that, and it still doesn't work, check the batteries and you may have to buy a new one. Don't forget to rate me please.
Jan 21, 2011 | Samsung Aa59-00322 Remote Control
Half my buttons on my philips remote arent' working?
I am So Sorry Too Tell You This But Those Phillips Remote or Products Don't Work It's a Bad Brand & Your Better Off Buying Like a RCA Remote or Other Mark Too Replace Your Current Remote Control.
Nov 27, 2010 | Philips Televison & Video
My W2253TQ developed a shadow across half of the screen (verticle)
I had the same problem and fixed it with a factory reset, which is done by pressing the menu button, selecting "setup" button, then continue pressing the autoset button on your monitor until "factory reset" is selected. Press the f engine button on your monitor and it will do the factory reset.
Oct 25, 2009 | LG Computers & Internet
How do you to turn off the pip feature on a Mitsubishi VS-60603 tv remote control?
hello on the remote control the should be a button half black and half white this is the pip button good
luck
shaun
Oct 03, 2009 | Mitsubishi VS-60603 60" Rear Projection...
Television half picture what causes this?
Sorry to let you know that your picture tube might be going out. Is your picture cut in half, or is your picture just using half of the screen. If is using just half the screen you might be able to adjust this with your horizontal control. If your picture is cut in half you might be able to adjust this on the inside back of the TV. Only problem with this the TV has to fully discharge from static as this static if you touch the inside picture tube can kill you. There are additional controls on the picture tube housing but should be done by an expert. Only problem with this, if this does not work you paid a service charge you could put towards another TV. Check out craigslist. Some great deals there. Let me know if I can help you with anything else.
JimmyC
Sep 25, 2009 | RCA Universal Remote Control
"Select" button doesn't work-Cox universal remote for XBOX 360
Depending on the specific remote, some buttons may not work with all systems. HOWEVER, in many cases the things you thing the "select button" would do, are done by the "play button" instead (IE: That's how I have to select DVD menu options with my remote).
If that is not the case with you, you can try a different programing code.
Sep 19, 2009 | Universal Remote Control Remote Control
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
