Question about Exercise & Fitness
Life fitness treadmill repair
I have an ST35 sport treadmill. Lately we are getting shocks from the handles. A repair service found arcing from the control board the frame. They didn't know how to solve this. Do I need a new board or is there something else I can do?
    Top Expert:
  • 12,223 Answers
Go to www.treadmilldoctor.com and get the board.
However the shock imply the you have a ground faulty. you must test the outlet ground with electrician and fix it, before.
see the diagram attached. life fitness treadmill repair - 9ceb917d-bb7f-4c4f-9c7d-a809eb935521.jpg
God bless you
Posted on Jul 19, 2013
Testimonial: "thank you, I already tested the receptacle and everything is fine, polarity and ground. if there is a ground problem to the plug how do i test for the break?"
vpaaf
  • 115 Answers
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
Posted on May 01, 2009
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
Posted on Jan 08, 2010
  • 5 Answers
SOURCE: I have a life fitnes treadmil. The read out says
u would have 2 buy a new motor controller communication board and replace the old 1 its very difficult
Posted on Jan 27, 2010
  • 16 Answers
SOURCE: Life Fitness Treadmill "FET" error
Can you please provide model of unit.
Posted on Feb 20, 2010
bwinton
  • 83 Answers
SOURCE: life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Posted on May 07, 2010
My Vision Fitness T9250 treadmill. Can hear a low noise when no one is on it but gets much louder when anyone is on it and operating...any ideas where to start looking for repairs?
Try to open and separate the motor carefully from treadmill chasis, turn the motor shaft with hand if it not easily turn or you hear a unsual sound try to open the motor and add a lubricant to motor bearing, and turn the motor on if its still noise replace all the bearings with new one
Dec 14, 2014 | Vision Fitness T9250 Simple Folding...
Treadmill motor control board
You can get repair service from www.gympart.com
Dec 25, 2013 | Life Fitness Exercise & Fitness
Life Fitness 9100HR Treadmill won't start
Typically a non start up of any electrical Exercise equipment raises alot of red flags If this treadmill will not start Check the internal fuse MAKE SURE ITS NOT PLUGGED IN!!!! UNPLUG IT FROM THE WALL
2 If there is NO Fuse and you just bought it new Return it for an exchange.
3 Check your wall outlet for less then 5 Bucks you can buy a wall outlet tester that tells you if your Outlet is good Or Bad.4 DO NOT Attempt to service this item on your own the way they make treadmills you have to have a qualified service tech come out and fix it because the risk of serious shock or death is emminent.
May 04, 2012 | Life Fitness Exercise & Fitness
Life fitness 9500 is shocking users? help?
Hi, there is a service bulletin for this problem.
1) perform a continuity test on the power cord between the earth pin at the plug and any exposed metalwork of the treadmill (say an exposed bolt). If you get a reading of less than 1ω - that is good. If higher than this, try another part of the treadmill or trace the cause.
2) Ensure the Power outlet has a good ground - Your electrician could verify this for you.
The most common problems are static buildup on the Striding belt caused by users wearing polyester and scuffing their feet as they are running. This causes static buildup which gets discharged through the user when they come into contact with the treadmill frame.
Happy hunting
Jun 22, 2010 | Life Fitness 9500HR Next Generation...
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
