Question about Honda GCV190-N5AP 187cc GCV190 Series OHC Vertical Shaft Engine with
I put 2 cycle gas in my 4 cycle Honda gcv190 pressure washer
I put 2 cycle gas with oil in my pressure washer. I drained it and put in regular gas but it still wont start. Any suggestions?
  • spenglersue
    spenglersue Jul 19, 2013
    I just tried to start the pressure washer again and this time it fired up. Doesn't look like I caused any damage....thank goodness.
    New Friend:
  • 22 Answers
Remove and empty the carburetor bowl, remove the spark plug, pull the start rope seweral times to get rid of the faul fuel from the cylinder, fitt new, or clean and fitt the old spark plug back, drain the fuel tank and fill up with clean fresh fuel.
Posted on Feb 16, 2015
    New Friend:
Did you pull the spark plug out and clean it ? if you did , did you also put the starter cord and turn the motor over without the plug installed to get rid of the 2-cycle oil out of the cylinder ? if not do so.
Posted on Jul 26, 2013
  • 57 Answers
SOURCE: We have a Honda GCV 190 gas pressure washer. It
check that the fuel tap is on
Posted on Dec 19, 2010
  • 174 Answers
SOURCE: Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Posted on Jul 19, 2009
  • 1388 Answers
SOURCE: pressure washer stalls
Pressure washers work under very dirty conditions, no wonder they encounter engine problems. Here are a few pointers from a former pressure pump tech. The unloader is a source of engine overloading however this can easily be checked with a pressure guage attached to the gun with a tee fitting having the guage and the normal tip used for the unit. The pressure should never rise over rated pressure. The pressure should drop considrably when trigger is released. The life of the pump and engine can be increased by setting max pressure to 75% of rating. Most engine problems are from following conditions:
Leaking or misadjusted valves; clogged muffer /spark arrester; weak spark coil that is about to fail completely; kill switch/oil sensor wiring and or sensor mal function; gas cap not venting properly causing vacuum in tank and wet or dirty air filter.
All these problems easy to check, fastest repair is to disconnect oil sensor wire to check oil safety system. Then temp replace coil with known good coil. Loosen muffer bolts to check for clogged muffler. Temp run engine without gas cap to check for vacuum. Finally if everything fails, run the engine with carb cleaner spraying directly into the intake. If the engine continues to run with carb cleaner then the problem is fuel delivey and faulty carb. enjoy
Posted on Dec 01, 2008
  • 10865 Answers
SOURCE: honda powered gx160 model pressure washer wont start
Buy a new plug, drain out all of the old gas and put in new gas, and take a look at the air cleaner. If the air cleaner is dirty replace it. There you now have a good spark, good fuel and good air. The engine should start. If it doesn't get some carberator cleaner spray and some starting fluid spray.
Posted on Apr 12, 2009
  • 151 Answers
SOURCE: Pressure washer with Honda GX160 5.5 HP OHV-Starts easily but...
what about the linkage between the governer and the carb. Is that working and not binding?
Posted on Dec 24, 2009
What oil viscosity and how much on my simpson pressure washer msv 3024
Here's a link to your Simpson manual:
http://simpsoncleaning.com/wp-content/uploads/2016/manuals/megashot/MSV3024-I-pwmanual-7107460.pdf
No oil is required for the pump.
10W-30 is normally specified for a Honda GCV160-GCV190 engine. You drain the oil by removing the oil cap/dipstick and then tilting the machine on it's side so that the oil can drain out if the oil fill into a container. (Drain when warm so it flows easily).
The capacity of the engine is ~18.6 oz. Refill amount is ~12.0-13.5 oz. (either engine).
When refilling, add oil and check on dipstick often. To check, press the dipstick into the oil fill, but DO NOT SCREW IT DOWN. Just insert the dipstick in until it contacts the top of the oil fill. The correct reading is between the lower and upper limits marked on the dipstick. (You may have to look carefully to see the marks).
Dec 27, 2015 | Simpson Garden
What kind of pump oil
What you have is a generic pump from china more than likely. Its built along the line of a FAIP pump. They arent supposed to have the oil changed in them at all. Most are sealed pumps but may have a plastic plug in it. If you must replace the oil then I would suggest Pressure washer parts catalog quick links Pressure Washers High Pressure... and get this item 4.5 OZ. AR64545 OIL FOR AXIAL PUMPS. It is recommended for pumps built similarly but not for your specific pump. But it should work. Good luck. W
Feb 21, 2015 | Simpson MSV3025-S Megashot 3000 PSI Honda...
What kind of pump oil for simpson gcv190
I need to know the model of the pump you have. You are giving us the model of the engine which is a Honda GCV190. Can you tell me the model on the pump itself. It is more than likely an AR pump but I need to know . It is more than likely going to take 30 weight non detergent but some pumps take specific oil. You can also call Barens at Pressure washer parts catalog quick links Pressure Washers High Pressure... They can hook you up with the correct oil for your pump. Good luckOADXAV
Feb 21, 2015 | Simpson Garden
Honda gcv 190
If it begins to catch then you definitely have ignition. Try replacing the plug with same type. If same result, the main jet in carburetor is clogged or the needle valve is stuck and not allowing fuel to enter into motor.
Mar 29, 2014 | Garden
Accidently put 2 cycle gas into Karcher G2600VH, Drained gas,Took spark plug out and cleaned. It is running fine now is there anything I should do in addition
Placing 2 cycle gas into a 4 cycle engine does not cause problems (but will blow white smoke and, in time, dirty the plug). I would have probably just ran it through.
:o).
Jun 04, 2011 | Karcher G 2600 VH Gas Pressure Washer
Honda gx110 3.5
I'm assuming this is a 4 cycle engine. If yes check the level of the oil in the crankcase - DON'T over fill, drain some out if over filled. If 2 cycle engine your oil mix is to rich. drain gas from tank and mix a fresh match of fuel with the proper amount of oil.
Jun 24, 2009 | Honda 8 HP Engine
Do I need to add oil to the gas for a Troy-Bilt 2500 power washer
This engine is 4-cycle. It does not require oil in the gas. Is the crankcase full of oil? Do you know how to check it?
May 05, 2009 | Karcher 2500 PSI Pressure Washer
Honda GCV190-N5AP 187cc GCV190 Series OHC Vertical Shaft Engine with Logo
245 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
