Question about Windchaser Heating & Cooling
Instructions add freon - Windchaser Heating & Cooling
How do a add Freon into a 745Li BMW?
buy can with hose adapter and hook it up according to instructions to the low side port the following link shows how to add freon to different vehicles your vehicle is not their but the explanation and how to are the same for adding freon
How To Add Freon To Auto Yahoo Video Search Results
Aug 17, 2016 | Cars & Trucks
How do i add freon to a 2003 chevy Malibu
Look under the hood and open the black plastic cap on the lower aluminium valves and spray inside BEFORE YOU DO ANYTHING READ THE INSTRUCTIONS on the can the car needs to be started and the a/c turned on before you spray it in keep car and ac on while you add the freon
Jun 05, 2015 | 2003 Chevrolet Malibu
How to add freon to mercedes e320
Auto parts store sell freon kit with gauges and instructional DVD.it comes with standard and metric adapters .should be what you need.
May 18, 2014 | 2002 Mercedes-Benz E-Class
Please advise how to add freon to mitsubishi montero '01 air conditioner unit
The best thing i can tell you is to take it into a shop. You can add freon to a system but you need to know what kind your vehicle needs. If it takes the new current freon your in luck you can buy a recharge kit at any local parts store. If not you have a few options. You can get a conversion kit to change the system over to the new freon or you can try to find a shop that can recharge it with the older freon for your vehicle. Since its an 01 it should be the new freon but i cant be sure. There is a fitting with a cap on it on you AC Lines. should be 2 a red cap and a green cap. You remove the green cap and with the engine running attach a recharger bottle from the store and refill the system. Note the freon recharge kit will come with some instructions to always read them first. hope that helps good luck.
Jul 29, 2011 | 2001 Mitsubishi Montero
CAN I JUST ADD FREON TO THE A.C. SYSTEM ON 2002 CADILLAC DEVILE AND IF SO WHERE IS THE VALVE AT ON THE ENGINE
yes you can add freon.there is two aluminum lines one is a high side the other is a low side unscrew the low side cap (they have symbols on them ) grey or black caps ...the freon can have instructions in the back of can turn ac on and fill system good luck
Jun 08, 2011 | Cadillac DeVille Cars & Trucks
How do you replace the compressor? Is there an online mannual? 2003
Physically changing the compressor is easy. Just two freon lines, a belt, one clutch wire, and a few bolts.
But first you need to capture the old freon, which needs a vacuum pump and tank.
It is technically illegal to just vent it, and it is dangerous because of the pressure and cold. (wear eye protection and gloves)
You also need to add the right amount of the right type of oil, depending on the type of freon (a 2003 should be R134a).
But instructions should come with the new compressor.
Then you need to add the correct amount of freon.
If you saved it, then you just put that back in.
Otherwise the instructions should tell you how much to add.
Jul 10, 2010 | Cars & Trucks
I would like to add free on to the my 2000 Jeep
there are 2 lines coming off the compressor put freon in the larger of the two
May 24, 2010 | 2000 Jeep Wrangler
Adding Freon to 1997 Dodge Dakota SLT
You can purchase R134a cans with a built in gauge so you don't overcharge... Assuming the system has not completely discharged, usually a can or less will do. Here is a link with some basic instructions:
http://www.sadik.net/nissan/howto/ac_r134.htm
Jul 15, 2009 | 1997 Dodge Dakota
Air conditioning blowing out warm air was blowing out cold air gradually over a week it became warm
The Air-conditioning needs to be re-gassed. Take the car to an Auto Mechanic to get the Air-Conditioning re-gassed. They might also need to check it for leaks to make sure the gas stays in.
Jul 13, 2009 | 2005 Chrysler 300
Heating & Cooling Logo
42 people viewed this question
Top Windchaser Heating & Cooling Experts
Jay Finke
Jay Finke
Jake's Auto Care...
Steve
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
