Question about Car Audio & Video
Rockford fosgate p4-400 protect mode.. reset?
5 Suggested Answers
tech48
  • 624 Answers
SOURCE: rockford fosgate bd1000a1
There is nothing to reset on this amp, it has no microprocessor.
Resets for electronic equipments are for clearing any software glitches that the microprocessor uses to do complex functions. I have only seen microprocessors in a couple of Kenwood amplifiers, and I have fixed many Fosgate amplifiers including this model. If you are not gettng any sound from it, you may have a blown channel. It is the most common failure I have seen in these. If that is the problem with yours, you need to take it to a service center that works on Rockford Fosgate amps, they have output transistors that are mounted on what is called a "mesha rail" and you can not change out just the 1 or 2 that are shorted, you must replace the entire rail because the transistors can not be removed from the rail and there are no generic parts for them as well.
I hope this helps you with your problem, deciding what you can do with it. It is a very good amplifier and in most cases it is worth the repair cost. You can not get a different amplifier of the same quality for less than the repair cost which usually runs about $125 at my shop.
Let me know if I can be any more help to you.
Dave
Posted on Jul 03, 2008
  • 182 Answers
SOURCE: Rockford Fosgate Punch 800 A2 shorting out.
replace the inputs on ur amp
Posted on Jun 29, 2009
laseramp
  • 309 Answers
SOURCE: 401s Rockford Fosgate Amp. Not powering on,just protect lite is on.
the problem is mostly with your audio side of the amp. i have a 800 Rockford punch series amp hooked in series running at about 15 vdc at 2 ohms stable for now. but the amps left front power side transistors overloaded and smoked out, i will be replaceing my mosfets soon. Now on that side your issues apear to be related to the signal side of the amp. when you hooked the amp up tell me breifly did you hook the rca inputs to the back of the sterio and did you select the proper rca inputs for the amp? also note that amps have a potentiomater that can be tuned up or down to allow the volume or wattage to go up or down threw the system. if it's turned all the way down you'll here nothing. but often you'll get a pop sound or quickly see the speaker move a bit. this indicated the signal side of the amp has signal comming in but no output, just look for a turnable small screw inside the amp top or side. and turn up acordingly. note: to much output will damadge your system. not just the amp. ;)
Posted on Aug 28, 2009
  • 3 Answers
SOURCE: rockford fosgate 450.4. 1st protect mode, now blows fuses...
smell it !
Posted on Oct 13, 2009
Hey I have a rockford fosgate t2500bdcp-1 when ever the bass is about to hit the amp goes to protect mode and comes back on
If you can tell that it is about to hit and the amp goes into protect mode, the amp is being over driven on the input.
Feb 06, 2017 | Rockford Fosgate Car Audio & Video
Protect mode?
You added speakers in parallel which reduced the effective impedance to to a value low enough that your Rockford Fosgate amplifier had to enter protect mode to prevent damage to its output stages.
Jan 22, 2014 | Car Audio & Video
800a4 stays in protect mode
Generally thats a sign of a shorted output device, either a bipolar transistor or mosfet. Also ground faults can trigger a protect light.
Feb 03, 2013 | Rockford Fosgate Punch 800a4 Car Audio...
It is stuck in protect and wont come out
bro...i had problem like that before and i found out that the load(speakers) was high thats why the fuse always blow...or...check the wire to the speakers if they are sorted or touched.gud luck
Oct 26, 2012 | Rockford Fosgate T1000-1bd - 1000W...
I have a rockford fosgate p5002 amp. I have 2 alpine 12" type-r's. I just got them bridged together and my amp keeps going into clipping mode. i tried turning down my gain and adjusting my frequency but it...
Hi unbridge the subs and run them sterio your overloading the amp and its going into protection mode. if you have anymore questions about car audio feel free to ask me...
Feb 05, 2010 | Rockford Fosgate Punch P5002 Car Audio...
When I am listening to my stereo in my truck with a pioneer headunit and a rockford fosgate p1 10" subwoofer. I listen to music and part of the song will hit hard then it will weaken dramatically. What is...
Your amplifier is going into protect mode.
It may already be damaged from repeated abuse.
The subwoofer is either bottoming out... has a blown or damaged coil... or your charging system is not adequate to keep your batter charged above 8VDC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 26, 2009 | Rockford Fosgate Car Audio & Video
Amp
There is no reset button. If you disconnect all of the speaker wires from the amplifier's speaker terminals and unplug the RCA cables, does the protect light still come on (I assume that you've already replaced the fuse)?
Jan 12, 2008 | Rockford Fosgate P6001BD Car Audio...
Rockford a2 not powering up
yiur amplifaer is in protection mode you moust reset the amp
Jun 15, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
Car Audio & Video Logo
21 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
