Question about Vacuums
Control board location - Vacuums
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vacuums Master
  • 102,366 Answers
Control board location in what make and model vacuum?
Posted on Jul 19, 2013
Motor not working on shark what could cause that
A failed motor or motor control board or defective wiring to the motor or the control board.
Feb 02, 2017 | Shark Vacuums
Need location to buy replacement circuit boards or parts lists for circuit boards
many components can be sourced from shops like Jaycar or the like
try the manufacturer for a complete board or a schematic of the board
Dec 29, 2015 | Tenma 72-6340 Vacuum Desoldering Station
Looking for replacement component for motor controller board, a capacitor that is in series with the AC input line.
Unfortunately Rainbow does not offer this part by itself, they only make the computer as a complete assembly. Rainbow E2 controller 120v You can try contacting local vacuum shops and see if they have any broken Rainbows with good controllers that they would be willing to sell only that part to you.
800-775-6586
GoodVac com
Feb 10, 2015 | Rainbow Vacuums
Motor revs up down
It might be a circuit board problem. I suggest taking it to a professional
Feb 16, 2014 | Miele S571 Bagged Canister Vacuum
I have a Kenmore Elite Ultrawave Microwave Hood Combination and am getting an F9 fault code. I hear a rythmic intermittant buzzing, the unit shuts off and the F9 appears on the screen. I have pulled open...
F9 code can mean something different depending upon the particular model.....
1.) IF your Microwave uses "UltraWave technology"/"SmartWave technology"...Then either the Magnetron has failed or the Inverter board has failed OR maybe the control board has failed (HUH?).
2.) IF your Microwave does NOT use "UltraWave technology"/"SmartWave technology" then one or more of the door switches has failed.
** "UltraWave technology"/"SmartWave technology" **
I'll explain a few things about this wonderful technology...
The control board (accepts the pushbutton commands) has to talk to the inverter board to tell it how much power should be applied to the magnetron. The inverter board will then power the magnetron and inform the control board if the magnetron is working OK.
If there is something wrong with the magnetron or inverter board or a there is a communication breakdown between the control board and the inverter board...WA-LA-----F9----
A pretty reliable test for the Magnetron is to operate the oven and listen for a ticking sound 5-6 times about a second apart. If you can hear the ticking....The magnetron has failed..if no ticking, the control or inverter board failed.
Nov 01, 2010 | Vacuums
Bought clearance item Sunday just found out the brush bar was motorized it turms only when i move the vacum back and fourth it should turn on its own right ? I have very little suction from the bottom the...
This appears to be a loose connection. The below post was answered by highntools a while ago. It probably is related to you problem. That is why moving it back and forth makes it go on.
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
There have been several people who reported loose or burnt wires to be the culprit for the brush bar not working. The DC15 does not use a belt, but a motor that is control by the circuit board. And I really believe that in your instance, the problem is a loose wire between the circuit board and the brush motor.
Mar 09, 2010 | Dyson DC15 All Floors - The Ball Bagless...
When I vacuum the carpet it won't engage into the brush mode, or it does intermittenly. It stays in the brushless mode for the most part
Aug 12, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Beater brushes don't work, what to do? They only work when the canister is in about an 85 degree up position.
Jul 12, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Electrolux C104A does not turn on. won't start. No light on, no sound. Is there any fuse to be raplace and/or ?
The Renny is a hard machine to diagnose. You could have a broken wire in the cord or in the hose. There is a fuse wire located inside the canister that could be bad.Also, the handle circuit board2.gif could be bad or the triac (another circuit board) located inside the canister could be bad. There is no use for you to open the machine. You could do more damage than good.
Jul 06, 2009 | Electrolux Guardian Bagged Canister Vacuum
Circuit board
You should be able to locate parts for your vacum at this link by entering the model number.
http://www.fantom.com/fantom/default.aspx
Mar 25, 2008 | Fantom Vacums Cyclone XT Upright Vacuum
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
