Question about Rapid 106 Electric Saddle Stapler
Can anyone repair a Rapid 101 Electric Saddle Stapler
There is an electrical problem on the circuit board and there are some rubber parts that have corroded
How do I load the stapler?
No you don't. We answer most things here.
If the stapler is like any of these
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Abostitch%20staple%20gun
You push the back in slightly to unlatch it and then drop it down a bit and the staple pusher comes out completely.
Jan 28, 2016 | Heavy Duty Stanley Bostich Heavy-duty...
How do I prevent Rapid 5080e stapler from jamming
Make sure that the tray for the staples is clean and LIGHTLY oiled, Staples are held together with glue. IT could also be an issue with the wear on the staple head driver. If you use it a lot, the unit might be worn to the point that it is out of spec.
Aug 28, 2015 | Rapid 5080E HEAVY-DUTY FLAT CLINCH...
Magtag Neptune Dryer - when I press start it say Pause and stops instantaneously. Anyone have this problem and know the solution?
sounds like a bad control board it seems like you have a letter missing in your model number ...I looked up the part ouch ..http://www.repairclinic.com/vwo1/Maytag-Dryer-Model-MDE5500AYW-ID-563862-Circuit-Board-Timer-Parts?s=t-mde550ay-%3d%3dd563862b4a8c13
Aug 14, 2013 | Maytag Neptune MDE5500AY Electric Dryer
Who sells staples 101 4 for a swingling 101 stapler
Hi, you can purchase them on amazon, here: Amazon com swingline 101 staples I hope this was helpful. Have a nice day
Jul 28, 2012 | Swingline Tools & Hardware - Others
How do I make the Optima 20 electic stapler model 48208 work after putting in the staples. I put the paper in as usual and it does not work. I have put the staples in correctly as I normally do, but
Unplug it, take it apart and examine the switch actuator and switch to see why they don't trigger the stapler. There's a good chance you'll find the actuator is broken or jammed by a foreign object, or the switch is worn out. Metal-filled epoxy works well for repairing ABS plastic parts.
Another possibility is a broken power cord. You can test the electrical parts for continuity with an ohmmeter (unplugged, of course!).
Nov 10, 2011 | Swingline 48208 Optima ® 20 Electric...
My Swingline Stapler Model 51110 electric stapler no longer staples. The staples will not move forward and it just does "blank" stapling. Also, it goes off on it's own all the time running stapples...
I have the same issue; however, there is some resinous material that came out of it as a result of my trying to figure out why it wasn't stapling anymore. Anyone know where I can take it for repair?
Aug 05, 2010 | Office Equipment & Supplies
Double or triple firing
Great, Sami! Could you please rate my assistance. Thank you.
Charlie
Aug 19, 2009 | Electric Stanley Tre500 Staple Gun /...
IVE MELTED MY TOP CIRCUIT BOARD IN MY WELDER AND NEED A NEW 30 AMP RAPID FUSE CAN ANY ONE HELP WITH A GOOD CONTACT NUMBER. JASON,,
call Darrell @ Meyers Electric out of Wales Wi. (414) 303-3097. You don't have to order the part but will find out how to get the right fuse.
Apr 25, 2009 | Welding Tools
Rapid 106 Electric Saddle Stapler Logo
174 people viewed this question
Top Rapid Office Equipment & Supplies Experts
Bill Boyd
Ambrelle Amburgey
Ambrelle Amburgey
Level 1 Expert
Are you a Rapid Office Equipment and Supply Expert? Answer questions, earn points and help others
