Keeps blowing fuses when unplugged from the wall
Blows the fuse on the power supply board every time I unplug it from the wall. It plays fine and stays on and shuts off normal but when I unplug it blows the fuse.
    Champion:
  • 247 Answers
Ensure u use the right fuse rating ask ya dealer ya fuse may be less than 13 amps hence heats up n melts
Posted on Jul 19, 2013
Testimonial: "im putting the same amp fuse back in and tried other outlets and I still get them same thing every time"
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 56 Answers
You need to replace the outlet your plugging it into or go to a different ciruit in the house n try again.
billynad
  • 51 Answers
SOURCE: Sylvania lcd color tv
try a diffenrt outlet if it still bunrs of a different fuse! could be the fuse not big enough for the different appliance on the circuit !
i would suggest take it to a tech it could be a problem in the tv that could cost only a few $ to fix !!!!
against trying to much to plug it in and out you could burn transistors or other expensive part of the tv!
Posted on Jan 14, 2008
  • 2336 Answers
SOURCE: proscan lcd tv model 26lb30h blows fuse on power board
If the fuse blows again after replacing it, there's a shorted diode, bridge rectifier, capacitor or transistor in the power supply.
I repair these power supplies. If you need furhter assistance, write to jah2mil@hotmail.com
Posted on Jun 20, 2009
brownline45
  • 310 Answers
SOURCE: Samsung LN40A530P1F LCD TV keeps blowing main
good day. your power supply is defective. maybe the regulator is shorted. you need a qualified technician to fix your problem.
Posted on Jun 22, 2010
diodeic
  • 1622 Answers
SOURCE: 26av502r - blowing fuses. i
You can do this by yourself all you have to do is to open the back cover of the television to check the faulty components. to fix you must have basic knowledge on electronics .
The fuses are there to protect the set from catching on fire in case there's a short circuit inside the set. Now in some cases an intermittent short can work after you replace the fuse but if its burnt black or brownish, there's a circuit inside the set in one of the circuits. always use a 100 watt light bulb across a blown fuse if your not sure if there is a short. if there is, the light will absorb the short and glow bright. if there is no short the bulb will glow bright , then go down very dim. you could have a main power supply problem, such as shorted bridge rectifiers,shorted main b+ capacitor, Hot could be shorted, or the Vertical or audio output IC could be shorted.
I hope this help in solving the problem.....
Posted on Nov 10, 2010
  • 4 Answers
SOURCE: Hi my pxt-50xd1 plasma
i have 2 of the power boards now i am struggling with, but there's a small capacitor that has gone on both of mine, it's labelled c5017 and is 10pF according to the service manual and i cannot remember the voltage but i'm using 630V ones to be safe but i think the orginal is much lower, so best to test that cap to see if it's causing the problem
Posted on Nov 13, 2010
1993 Goodman gas furnace keeps blowing fuse when first turned on
You can take each thermostat wire off the control board and use a ohm meter and test to ground, should not have any resistance. Another way is turn off power take each wire off the board, then place one wire at back on the control board terminals ome at a time, untill the one you get to the one that blows the fuse. If the wires check out good sometimes the thermostat itself can have a internal short and cause the fuse to blow.
Nov 27, 2012 | Heating & Cooling
I get no power indications to my Aqualink. I checked the circuit breakers, Any idea what is going on?
check back of PCB board fuse might be blown if keeps blowing fuses unplug all auxs then plug in 1 at a time till it blows thats whats wrong or check powersupply should be 24 volts ac on back board
Sep 23, 2012 | Jandy AQUALINK RS TELELINK KIT
I have been having issues with my 1996 Jimmy. When I turn the Key to accessory, the #10 ecm ignition fuse blowes. It will not start. Any suggestions? Thank you.
Unplug the injectors, coil, crankshaft position sensor, and the ignition module. Check to see if the fuse blows with these unplugged. If it doesn't than plug these back in one at a time until the fuse blows and replace that component.
If it still blows. than the pink wire that supplies power to all of the above components is shorted. A careful inspection of the wiring will be necessarry to find the problem.
One other note that fuse also feeds the Vehicle Control Module on vehicle equipped with a VCM (4.3 liter)
Oct 22, 2010 | GMC Jimmy Cars & Trucks
My tail lights are not working, it keeps blowing my fuse.
1.Unplug your taillights at the sockets and the front running lights from sockets.
2. put in new fuse after unplugging taillights.
3 turn on taillights if fuse blows then the wiring is grounding out somewhere between the switch, fuse panel, and rear and or front parking lights.
4.If fuse does not blow then plug in one socket at a time keep rechecking fuse. when the fuse blows after plugging in a certain socket suspect that one to be bad and replace.
Sep 15, 2010 | 2005 Infiniti G35
The fridge is blowing the 12 volt fuse as soon as I power up the motor home, The fridge is turned off and it still blows the fuse, I tried to undo the 2 wires that go to the 12 volt block on the fridge and...
Unplug the wire located at terminal J4 (12v positive) on the control board, and see if you are still popping fuses. If so, then the fault lies between the wire you just removed and the fuse that keeps blowing.
If the fuse holds, and blows when you plug the wire back onto J4 terminal, then unplug the wire(s) at J2. These go to your door heater (used in humid conditions to remove condensation), as well as the interior light. The switch for the door heater is located on front panel, or is at the top edge of the freezer compartment with door open. It is not unusual for this switch to have issues since it gets chilled and moisture condenses on it. If unplugging the wires at J2 allows the fuse to hold, you probably got a shorted heater or bad heater switch. But, pull the lens off the interior light, and check the contacts there as well.
If the fuse still blows with J2 removed, then unplug the connector in the top left corner of the control board. This goes to the control panel on the inside of the fridge. If the fuse blows, replace the control board. If the fuse holds, the replace the control panel.
Jul 13, 2010 | Dometic RM2652 Refrigerator
LaserJet 5550dtn Printer: blows mains fuse and power supply board fuse and b...
The fuse blows all time on High Voltage Poewr Supply, on HP Color Laserjet 5550dn,
May 16, 2010 | HP LaserJet 5550dtn Printer
Blown fuse on a ilpi-009 power supply
hi, i don't know the exact power board you speak of, most fuses for power supply protect ac inboard power, and backlights. if backlight inverters touch ground or ground out, this will blow fuse. otherwise, the fused circuit is used for main inboard power going to primary capacitor. take an automotive fuse holder and solder test leads long enough to work with, install 4 amp blade fuse and jumper/solder the circuit to the fuse on the board and power on the monitor. if all goes well, probably just power surge or outlet grounded. if blows fuse, check to board for obvious burns or blown capacitors. if not there, unplug backlights and power on, if still blows, check to make sure no direct conact with board and back of screen. just be thorough about looking carefully for shorts if there is one. and don't forget to replace the factory fuse on the board with the correct one after you finish repairing, don't leave that automotive fuse in. good luck.
May 10, 2010 | Emprex LM2201 22" LCD Monitor
No power to tv - but ac cord and wall outlet are fine though
hello the glass fuse inside the tv might blew make sure the tv unpluged take the back in the power supply you should see a glass fuse if the fuse is black then it's blew if you put another 1 in and it blows again then you have a dead short somewhere
shaun
Nov 06, 2009 | Philips 60PW9363 60" Rear Projection...
Blowing fuses p50830bl
the board mounted overtop the of the chasis is the convergence power supply board
replace that board will bring your tv back to life
then go into menu readjust convergence red and blue DO NOT MOVE GREEN
Sep 01, 2009 | RCA P50830BL 50" Rear Projection...
My kenwood compact disk payer rxd-a53 shut off now it keeps click
Your problem is caused by a blown fuse on the main board 6.3amp 125volt time delay fuse replace with the exact same type. The reason the fuse blew is most likely because they is a problem with the amp.
I suspect one of the finals is blown 2SD2560 or 2SB1647. Open the case and with the power unplugged replace the fuse, next unplug the 4pin connector from the amplifier board 3 black wires and one red.
now plug in the RXD-A53 and turn it on. you should now have the display working and no clicking.
unplug it from the wall and reconnect the 4 pin connector and now plug it back in and turn it on if the fuse blows again take it to a qualified service technician, the above noted output transistors will run you about 6 bucks a piece they are 4 of them 2 of each for each channel plus labor.
Mar 02, 2009 | JBL On Stage Micro Speaker Dock for Apple...
Televison & Video Logo
Top Televison & Video Experts
