Question about Nikon Speedlight SB-800 TTL Flash
Nikon SB800 UInlock
My SB800 is locked in Remote. How do I get out of this menu? Thanks in advance.
  • Jack Front Jul 20, 2013
    Unable to ove from following menu: CH 3, (the arow pointing to a Lock) followe by an image of a light bulb. 2nd row contains an image of a musical note, followed by the work REMOTE. 3rd row contain M over word zoom , followed by 85 mm the then a mall box containing Goup ovber A
  • 3 Answers
This was from a long while back, but has issue been solved???
Posted on Mar 21, 2014
3 Suggested Answers
bearydude
  • 62 Answers
SOURCE: SB800 Won't Remote
The channel on the flash for remote on the 4a withthe NIKON D70
If you are using the Nikon D200 then the channel is 1a ...
If you have any more questions contact
Berrie Smith Camera Repair
bbmw@bellsouth.net
Posted on Feb 06, 2008
  • 14 Answers
SOURCE: SB 800 Speedlight AF red lamp not function
The problem is probably caused by a fault in the main power circuit board, if the red light doesn't come on then you also probably won't hear the high pitched noise as the capacitor charges. Will be expensive to repair as you will need a new circuit board.
Posted on Sep 04, 2009
How do i change from remote ttl on my nikon sb800.
Press the Menu button. Scroll to the Custom Setting Menu. Scroll to "e Bracketing/flash". Right arrow and scroll down to "e3 Flash cntrl for built-in flash" and push the center button. You now have access to the TTL, Manual, Repeating flash and Commander modes. Right arrow on CMD and a menu will appear that allows you to set up the built in flash and the external flash groups.
Aug 15, 2013 | Nikon Speedlight SB-800 TTL Flash
Sb800 flashgun pull out diffuser and bounce card
Yikes sounds like your dangerous and need to call Nikon for forgiveness the charge will be minimal
Aug 28, 2012 | Nikon Speedlight SB-800 TTL Flash
How do I use two sb800 one on the camera and one behind a groups of people to eliminate the shadows on the wall
The SB-800 has a slave mode called SU-4 in the menu. It activates remote flash. When your on camera flash fires so will the slave flash. The slave flash will need to be able to "see" the light from the on-camrea flash to work.
To access the SU-4 remote mode hold the "SEL" button in for a few seconds until the menu appears. Scroll down to the SU-4 setting and turn it on.
When using this method set the flash to manual and set the power as needed.
Mar 08, 2010 | Nikon Speedlight SB-800 TTL Flash
I would like a dvd for the using of the Nikon SB800 flash
Blue Crane Digital DVD: Understanding the Nikon Flash SB800 and SB600
  • Mfr#
  • BC202
  • B&H# BLDVDNFSB800
THIS SHOULD HELP YOU
BERRIE SMITH CAMERA REPAIR
770-312-0719
bbmw@bellsouth.net
Feb 14, 2009 | Nikon Speedlight SB-800 TTL Flash
No iTTL mode (or TTL mode) in SB 800 synced with cord to D300
Bingo! That's an X-sync cable, only for firing the flash, syncing it withe shutter - carries out no auto features or communication with the camera.
Don't waste your money on another cable the same. There is no TTL light measuring features with an X-sync cable.
You can, however, get the proper 'off-the-camera' TTL syncing cable either from Nikon or a 3rd party provider. This proper TTL cable can cost a fair bit, I don't know exactly but thinking from $40-$50 to $80'odd.
Shop around, buy from a store where you have the face-to-face enquiry and a return facility if 'they' get it wrong.
**.The best way to acknowledge contribution is to rate it's relevance.**
Feb 04, 2009 | Nikon Speedlight SB-800 TTL Flash
Nikon SC-29 REMOTE CORD
Hi Kathy,
Are you ready?
1. Make sure the Nikon SC-29's Red Panel's Lock Switch is set to the Left. Pointing at Left Black Screw.
2. Connect the Nikon SC-29's (Red Panel) to your camera's Hotshoe by pushing it as far as it goes.
3. Turn Lock Switch to the Right (turn CW). This locks down to camera.
4. Make sure Nikon SC-29 (other ends) AF-ILL is set to OFF.
5. Make sure your Nikon SB-800's Lock Switch is set to the left side.
6. Attach your Nikon SB-800 into this Hotshoe.
7. Switch the Lock Switch on flash to the right.
8. When you wants to AF from flash, set AF-ILL to "OFF"
9. For the best results, set AF-ILL to "ON".
I teaches, do repairs, services and modifications on all photographic equipments.
I hope they are helpful to you as well as for any Nikon Photographers using the Nikon SC-29 Cable.
Mine has Autofocus, ITTL, Slave and Wireless Radio Remote Flash.
Truly,
atdlee@netzero.com
Jan 31, 2009 | Cameras
Nikon D3 and SB800 flash problem
The Sb800 and the Sb900 is compatible . Can you tell me more of what the problem is .
There is no frim ware for the flash . The NIKON SB 900 FLASH SHOE IS THICKER AND MAKES BETTER CONTACT . THE NIKON SB800 SHOE IS LOOSER AND NEEDS TO BE ADJUSTED
Nov 23, 2008 | Nikon Speedlight SB-800 TTL Flash
SB800 Won't Remote
bbmw@bellsouth.net
Feb 04, 2008 | Nikon Speedlight SB-800 TTL Flash
Nikon SB - 800 LCD Defect
Impact has damaged the LCD assembly .
IF you want it repaired contact the email address below
bbmw@bellsouth.net
Oct 29, 2007 | Nikon Speedlight SB-800 TTL Flash
SB800 firing but not syncing??
I had that same problem with the SB600 and the SB 800. Solutions; get a new one. After about a year of usage the sb600 started giving me that problem. It flashes but it does not sync. It still works as a remote unit, but not mounted on the camera. The SB800 just went to a coma last weekend. No sync at all, not even as remote unit, no strobe function, just a bright flash, when triggering the test button with new fresh batteries, it flashes at max power once and takes around 7 seconds to recycle. No multiple flashes at all. I had to buy a new one.
Jan 09, 2007 | Nikon Speedlight SB-800 TTL Flash
Nikon Speedlight SB-800 TTL Flash Logo
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
