Question about Dryers
I have a 20 year old electric dryer that normally
I have a 20 year old electric dryer that normally works great. All at once the dryer stopped heating, but otherwise works normally. I took the dryer apart, checked continuity of the heat coil, hi limit thermostat. All seemed fine. I checked the connection of the power cord and noticed one of the wires broken and burnt at the connection. I started taking the terminal block apart and the stud that sticks out just came out of the block. I don't know what caused it, so I don't know if I should just replace the terminal block or if something else caused the wire breakage. Should I just replace the terminal block and see if it works? My worry is I could have a fire if something else is wrong? Any suggestions would be appreciated. Thanks.
  • Dryers Master
  • 15,937 Answers
The problem is the terminal block, Vibration with the cord not being fastened to the block tight enough caused overheating at the block and it failed. Replace it.
Posted on Jul 19, 2013
  • 1028 Answers
SOURCE: connecting 4-wire recectacle 14-30r dryer
doesn't matter both are 110v lines but if you want look up to top screw connections the wires coming to those screws are also colored as long as the red and black are to outside screws dryer will work ok
Posted on Aug 07, 2008
SOURCE: Admiral Dryer (Model # ADE7005AYW) wire connector burning causing no heat
I had the same problem with my dryer. Fixed it with high temp wire (875 F) and end connectors rated for the same temperature. Make good connections between the wire and the connectors because if they are poor they will heat up as well. Sometimes the thermostat will cause this problem as well or an older heating element that is going bad.
Posted on Jan 18, 2009
  • 63 Answers
SOURCE: G.E. electric dryer terminal block and wires are
you did not say how old? but I find that all it takes is one wire to get old, and starts to heat up because electric cant flow through it, then it gets worse and worse fast, then heats up the whole block, till the whole thing gets melted...bad thing is its happens slow enough that the standard 30 amp breaker won't trip during this slow melt down!
Posted on Mar 13, 2009
  • 1150 Answers
SOURCE: AMANA dryer model ALE643RBW burnt wire
I would think that:
Low voltage. A lack of proper voltage increases the current flow (amps) and can cause overheating, thus, a burnt wire. Remember, the lower the voltage, the higher the amps.
Bad connection. Poor connections can cause small amounts of arcing, thus burning the connection. This adds resistance to the circuit which causes a possible voltage drop and, again overheating due to higher amps.
Since all that equipment is on the same circuit, I would really think it is a voltage drop situation. With everything calling for power at the same time, the breaker trips. In some cases, it may be just enough for the breaker not to trip but still have a low voltage situation.
There is the possibility of an over current, such as a power spike from the power company but it would have to happen more than just a time or two.
And the outside chance that lighting got into the system when it struck something close to you home but it, in almost every case, would destroy something else, usually electronic. (This has happened to me. Trashed my dryer, dishwasher, and answering machine.)
Good luck and hope this helps. Le me know how you come out.
Posted on May 11, 2009
localwonder
  • 6784 Answers
SOURCE: maytag electric dryer not heating
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Jun 03, 2009
No heat on any settings...worked the day before...great dryer, but less than a year old. What's up?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 30, 2010 | Fisher and Paykel DE09 Dryer
Dryer suddenly does not produce hot air
have the exact same problem, just over 1 year old no heat! first off my duct work under my floor is like a snake and is not a straight shot out of the house. I beleive this caused a ristriction in the venting because dyer seemed to be running hotter them normal. I took the top off the dryer and pulled the vent tube out of the bottom of the dryer. To my surprise found a three inch layer of lint on the bottom of the machine and also on the heating coil. After cleaning out all the lint i took a volt meter to the two wires that come down to the heater. started the dryer and found i had 220volts at the heater indicating the heater is out, found one on ebay for about 50 bucks. will be installing this weekend and will let you know how it works.
Mar 08, 2010 | Samsung DV218AEW Electric Dryer
Dryer not heating up but is otherwise running fine.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil. You should read continuity across the terminals, if not you will need to replace the coil as it is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape. If the coil heats up then replace the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine. I will include these two websites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, Hope this helps Please rate me, Thank you
Jan 03, 2010 | Whirlpool LER4634J Electric Dryer
My dryer is not rotating, heater is working. It is
sounds like a belt and the heating eliminate
Sep 26, 2009 | Dryers
Dryer Stopped Heating
Use a multimeter to check the heating element. You can't always go by looks. Check continuity and if there is none, the element is defective. Another thing to check is the thermal fuse. It is about an inch long and is usually attached to the exhaust duct. Use the meter to check it as well and if defective, replace it. Sure hope this helped and best wishes.
Jul 28, 2009 | Whirlpool LER5636P Electric Dryer
15 year old Kenmore dryer not working
Sounds like you thru the breaker. If not, it is the door switch.
Jul 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My whirlpool electric dryer smells hot.
generally if the uint shuts off from overheating and then will not restart for a 10-20 min period of time usually a sign htat hte motor is overheating and needs repalcing
Mar 31, 2009 | Whirlpool LER5636P Electric Dryer
Danby Dryer DCD5505 starts and stops continuosly
ITS COMPLETELY NORMAL!!! THATS HOW IT WORKS.
Oct 23, 2008 | Danby DCD5505W Electric Dryer
Dryers Logo
57 people viewed this question
Top Dryers Experts
