Phillips 55pl9224 37
The Tv turns on, but after a minute, it turns itself off. Any ideas???
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 21 Answers
Sounds like a compasitor.
Posted on Jul 19, 2013
4 Suggested Answers
SOURCE: 42 inch Phillips LCD TV turns itself off after
I had the same problem for 3 days. Remove all inputs to the TV and turn it on again. If it stays on for any length of time you're half way there. While the TV is on, go to the picture format menu and change it from automatic to widescreen. This worked well in my case, but still think there may be an underlying problem with the input circuit. Good luck!
Posted on Feb 27, 2011
  • 81 Answers
SOURCE: 32" phillips tv turn self
If you go to this website, http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=32PFL5332D/37&slg=en&scy=US
You will see firmware information on the right hand side of the screen. Please open and read the Firmware Upgrade Read Me file. These contain instructions and the update history of this model TV. Underneath the Read me file you will find the download link. You must follow the instructions in the read me file or you risk damaging your unit further.
This is from the read me:
The set is switched OFF/shut down by itself after a few hours turning ON.
The newest upgrade should fix all your issues.
Hope that helps!
Posted on Jul 20, 2011
caroldon
  • 17129 Answers
SOURCE: phillips 42ppfp5532d/05 turns itself off
This is a fault solution which can be checked and corrected by you assuming that there is no component failure. There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Check for tips to look into the SMPS unit with some of my tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Thank you for using Fixya.
Posted on Sep 03, 2011
Phillips flat screen TV
It sound like its fly-back transformer side circuit fault. This is not a user repairable fault. Contact any service technician.
Jun 10, 2013 | LG 42PC3RA 42 in. HD-Ready Plasma TV
My Phillips plasma when turned on, turns itself off straight away. Any ideas? All the repair places are closed over the weekend. Now does not turn on at all.
Tries tv unplug,replug tv back about an hour later.By letting tv resetting itself back to the factory setting.Now the tv should be working again.If still have the same problems.The power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Try website like Ebay.com to guy a whole refurbish power supply board for the replacement.
Jan 07, 2011 | Philips 42PF9966 42 in. HD-Ready Plasma...
Our 47' lcd phillips full hd tv is scrolling through the source list of its own accord. very frustrating...... any ideas?
Sticky menu control button on the tv or could be a defective main board. Have seen both cause the problem. you can try and unplug tv for about 5 minutes or so and see if it resets itself..
Oct 17, 2010 | Philips Televison & Video
Tv turns itself off after less than a minute or if lucky after a few minutes or more power light stays on even though tv turns off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Sep 26, 2010 | Insignia IS-LCDTV32 32 in. Television
Samsung TV turns itself off every 10/15 minutes
Solutions?
Hope this helps
Jul 20, 2010 | Samsung TXM3297HF 32" TV
Pioneer SD-P6091 Projection TV - TV turns off by itself
Solutions?
Hope this helps
Jan 20, 2009 | Pioneer SD-P6091K TV
Mitsubishi WS 65513 turns itself off
Solutions?
Hope this helps
Jan 05, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Phillips 27PT9015D/37
Worn-out capacitors in the power circuit might cause this kind of problem.
Jun 22, 2008 | Philips Magnavox 27MS343S 27" TV
TV turns itself off after a few seconds, no picture at all
Solutions?
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
