Question about Cell Phones
Rc helicopter battery
I was wondering how long i have to charge my battery? and also where can i take it to be repaired or replaced if it is damaged?
    Problem Solver:
  • 11 Answers
Tip #1: Wait at least 15-20 minutes after you drain a battery to charge it.
This allows the battery to cool down before each charge cycle. I would make sure the battery is cool to the touch before charging it again, but 15 minutes should be alright.
Pointer #1: If the battery is hot after use, then it is a good sign that your battery is getting old.
Anything warmer than about 140 degrees is dangerous; if your battery is this warm after flying, it's time to replace it. I wouldn't use it anymore so it doesn't explode. This is a good indication that in the near future you should look to getting a new one. I would recommend a higher quality / mAh battery (keep the same voltage, though) if the battery running out is a stock battery.
Tip # 2: Wait at least 15 minutes after charging a battery to use it.
Once again, this is to let the battery's chemical processes have a break.
Pointer #2: Battery terms to understand when buying a RC battery.
mAh: Milli Ampere Hour. This is basically the electric charge transferred by a current of one milliampere for one hour. I'm no electrical genius, but the higher the mAh, the longer a battery will last per charge. This is the one part of a battery that you can change without damaging the heli.
Volt: The electrical pressure. Basically this determines how much power can flow to the motor. For lipo batteries the voltage comes in multiples of 3.7 volts, or 3.7 volts per cell.
Cell: An independent 3.7 volt battery.
If you would like a little more in-depth explanation, I found this howstuffworks article helpful.
Litium-Ion (Li-Ion): a type of battery that has a rigid cell structure and shape. It is safer than a lipo battery, but not as efficient.
Lithium-Polymer (Lipo): a type of battery with a flexible cell structure and shape. Lipos can catch fire and explode if mistreated or dropped on a hard surface. BE CAREFUL! Although more dangerous, they are more efficient than li-ion batteries and can come in practically any shape with the same cell count.
Look below to see how the li-ion (on the right) has two defined cylindrical shapes in the package, whereas the lipo to the left is just a rectangle with no visible curvature or cells.
Posted on Jul 19, 2013
There aren't green light in charger
Search Results
    How To Fix Your RC Helicopter - YouTube
    ? 4:22
    https://www.youtube.com/watch?v=R65JJYwSH50
    Jun 28, 2010 - Uploaded by R/C 101
    Does your RC helicopter spin out of control in the air or ... thing that the video says but there nothing wrong about it the remote is fine but the propeller .... i have a brookstone RC stunt copter that i have not used in a few months. i .... however when I come to fly it, it makes a sound but the wings aren't working.
    All comments on How To Fix Your RC Helicopter - YouTube
    https://www.youtube.com/all_comments?v=R65JJYwSH50
    where can I buy new gears and pinions for my mini rc helicopter?. Read more Show.... The two pins on the charger port aren't working they won't charge ..... The charging light is off meaning the battery is charged. Any ideas? ..... So, the motor spins the correct way but there is no gear to transfer the power to the rotors 'A'.Missing: silver ‎bullet
    rc helicopter light flashing Remote Controls Questions
Jan 19, 2016 | Brookstone Rc Mini Helicopter Silver...
Remote will not control the helicopter
did you charge the helicopter.... you need to put the charging cable in to the copter. and charge up can use a usb power plug. when charged the light on the usb cable should light up or flash. also if you take the plastic cover off the front there is a battery in there and a board check to see what number its set on. it takes around 5 seconds for the remote to recognise the unit.
Dec 26, 2013 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
Helicopter is not getting charged
1) test the contacts and clean it very well +adjust it
2) if after cleaning the problem remain, the power supply inside is faulty. some capacitor, diode, or resistence is faulty. Repair
God bless you
Jan 25, 2013 | Brookstone U-control Silver Bullet Rc...
Where doI find the slot to recharge my helicopter
with most rc helicopters you have to disconnect the receiver unit from its battery and connect the charging lead to the battery lead the charger should have 2 leads 1 for the transmitter & 1 for the receiver
hope this helps
Aug 08, 2011 | xheli Exceed RC 24Ghz WarHawk 300 4Channel...
I bought rc helicopter of alloy king and i dont know how to make it start.
Insert the batteries into the battery slots in both the controller and the helicopter.now you will be able to control the rc helicopter whenever you want by just switching on the remote control for the device.
May 10, 2011 | Toys
My helicopter flew for a few seconds and then feel to the ground. It seems as if the controller does not work with the helicopter
Check your battery pack to see if the controller lost power or the battery pack in the RC ARF to ensure that, the copter can receive.
Dec 22, 2010 | RC ARF Falcon 40 Helicopter
My Yiboo Micro Blade Rc copter won't charge. I've tried disconnecting and reconnecting the batteries, but every time I plug it in the charging light doesn't come on and it goes into transmitting mode....
Well my K11 helicopter that I bought from Paddys Markets Sydney Australia last week for $45 gave up after three flights. I suspect the battery is either dead or not charging or a burnt out wire. I suspect your micro RC helicopter has a similar issue. I smashed open my charger with a dumbell weight to see if the wiring inside it was ok. All looks good, but when it is plugged in, it does not even produce heat, which chargers always do to a certain amount. I also dismantled helicopter and took out battery. For $45 it is not worth me buying a voltmeter, another charger (which I cannot find online) and my manufacturer has a dodgy website as well! I recommend keeping your toy for parts and maybe getting another one?
Sep 10, 2010 | Max 2 Tail Rotor Blade For Yiboo Shark Rc...
Cell Phones Logo
82 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
