Question about RTO Wayne 1/2 Hp Shallow Well Jet Pump
Shallow water pump keeps stopping
I have a shallow water Wayne 1/2 hp pump and it has stopped 3-4 times over the past few days. At first I thought it was the ground-fault interrupter it's plugged into so I ran it to another socket and it worked... then it happned again 3-4 times and I noticed the pump motor was VERY HOT and when re-plugged in "nothing". So I let it cooled down, and plugged in and all I heard was a vibration sound but no pump turning and thought it might be a dab section of the motor, so I unplugged it and used a screw driver to move the motor fan a few turns , re-plugged it in and it worked again....only to stop a few hours later..... reading the other posts I expect it is overheating but have not timed the pump before the PSI shuts it off.....
    Top Expert:
  • RTO Master
  • 48,226 Answers
New pump --not big enough for the job
old pump --motor windings problem, faulty start run capacitor
I suspect that as the motor is 1/2 hp if will run good when there is a need for water but under pressure the pressure switch is set to high so the motor overloads and gets hot
Posted on Mar 24, 2017
3 Suggested Answers
  • 10 Answers
SOURCE: I have a AquaScape 4500 GPH Pump it has worked
Where the wire goes into the pump there is a o ring thatis probably leaking and any sort of water the motor might be getting is tripping the breaker. You probably have it plugged into a gfi and it sense very low amounts of water, and trips, You can determine by plugging it into a regular outlet and it should work. But definently fix the oring at the point of entry on the pump
Posted on Apr 17, 2010
SOURCE: I have a 1/2 horse wayne shallow well pump. At
check air in your water tank should be less than you're cut in pressure..
Posted on May 09, 2011
Very low water pressure and excessive pump running
Clean electric switchcontacts with crocus cloth. Adjust higher cut in pressure on this switch.
Apr 12, 2014 | Wayne WATER SYSTEMS SWS50-12P 1/2 HP...
I have a utilitech convertable pump. It is used as a shallow well pump at the moment. It worked fine untill last week, the hot water tank went bad and we replaced the tank and all the above ground lines....
Hi mid_age_elf
Your problem is that your "water bound"...
Your water tank must have a cushion of air for the pressure switch to work properly.
Turn off your pump and drain about 1/3 of the water from your tank.
Once you have an "air cushion" the pump and switch will work properly.
You can also add air pressure using an air compressor and an air valve installed on the top of your water tank or maybe on the side or bottom of the tank.
You would put air into the tank until about 1/3 of the water is gone replaced with the air.
Once that is complete your problem will be solved.
Please take time to rate me
Oct 21, 2012 | Utilitech 1-HP Cast Iron Shallow Well Jet...
My 1/2 hp flowtec pump keeps acting up worked great for 2 weeks Then I replaced pressure switch worked for 3 days then changed plastic hose to switch worked for 1/2 a day. Will not shut off
Three things to check
1. There may be getting sediment in the water line to switch. Flush the well tank at the boiler drain to see how much sediment (if any) comes out. Flush well if heavy sediment and call Well company.
2. Make sure the check valve is OK also.
3. If the impeller is bad on the pump it will not build pressure and keep running.
4. The well may be going bad, low volume. Call well company.
Jun 21, 2011 | Flotec Corrosion Resistant Shallow Well...
My water pump kicks on every 30 min or so even if there is no water used
When a pump goes on and off there is a water leak somewhere.
There should be a gauge. Let the pump build up pressure and watch the gauge.
The pressure will probably be dropping. This means that water is going somewhere. The leak could be anywhere that you use water, sprinklers, sinks, hose lines. If there is a valve above or near the pump, shut that valve and see if the pressure stops dropping. If the pressure stays up and the pump stops cycling on and off, the leak in in the pressure piping somewhere, you must locate it and repair it.
If the pressure continues to drop even with the discharge valve shut, the water must be leaking back into the well. There is a check valve somewhere on your line between the well and the pump. If this check valve is leaking, pressure will drop and the pump will come on to restore it.
If it is possible to shut off the discharge of the pump, shut that valve and watch the pressure gauge to see if it is dropping.
Dec 12, 2010 | RTO Wayne 1/2 Hp Shallow Well Jet Pump
Pump stopped working while pumping
Yes, most motors are thermally protected. It is usually bi-metallic, and resets itself.
Aug 08, 2009 | Flotec Corrosion Resistant Shallow Well...
No information on Wayne 55701-RP1
This isn't a valid Wayne pump model number according to Wayne's website. Please double check your pump and visit:
May 23, 2009 | Wayne Water Systems Wayne RECONDITIONED...
RTO Wayne 1/2 Hp Shallow Well Jet Pump Logo
59 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Are you a RTO Garden Expert? Answer questions, earn points and help others
