Question about Dell C521 DimensionTM PC Desktop
No video I can turn on the computer and my monitor says check cable and computer monitor working regretfully a regular video card will not fit in this version computer if this is the problem where do I purchase a new video card
    Sergeant:
  • 279 Answers
It's not necessarily the video that's the problem. Anything that would keep the computer from beginning the POST process (beginning of the process of booting your computer) could also result in no video. When you start the computer up, does it beep at all? If so, how many beeps, and are they long or short. The order and lengths of the beeps are the most basic type of error codes. Also, do you hear the hard drive spinning up? And does the CD/DVD ROM drive start up normally? It could be a power supply, your processor, memory, the motherboard or just the video card. It could also be just about anything in the computer if it developed a short, as a single short can cause the power supply to shut itself down so as to protect the computer from being further damaged. I would suggest disconnecting power to the drives, and trying again. If it boots to video, you know one of the drives is the culprit. If they aren't the problem, try removing the memory. It won't boot that way, but if the memory is the problem it will at least reach your POST and give you the option of entering BIOS. If you get that far, the memory is at fault. Then, try the same with any expansion cards onboard. If none of that causes it, then you either have a bad processor, bad onboard video, something else wrong with the motherboard, or bad power supply. Unfortunately, none of that can really be tested without having parts to swap out.
Posted on Aug 28, 2007
My acer monitor p191w will turn on acer logo comes on goes black then a screen comes out saying no signal then turns of light turns yellow ...tried restarting monitor nothing
Connect the monitor to a different computer, to see if the monitor works at all.
Connect a different monitor to your computer, to see if your computer really is "sending" a video-signal through the "data" cable. If not, then either the data-cable or the video-card inside the computer is faulty.
Jul 13, 2011 | Acer P191WBD LCD Monitor
My monitor doesnt come on i have model x163 what driver do i need
You don't need a driver for a monitor. It displays the signal that the Video Card sends to it. Check the power cable and monitor video cable at the monitor and at the computer. Disconnect these cables and then reconnect them and tighten the thumbscrews to secure the connection. If you have an onboard video card, you may have a problem with your motherboard, RAM, Processor, Harddrive or Video Card that is preventing the computer from turning on. If you use a PCI, PCI-Express, AGP, etc. video card, check to make sure is it securely seated in it's slot. Also check the power cables going to the video card (if any) and the monitor cable connected to the video card. Else you may have a failed video card, or a problem with your motherboard, RAM, Processor, Harddrive or Video Card that is preventing the computer from turning on.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 11, 2011 | Acer X163WB Monitor
I have a CMV222h Chimei monitor and it just blinks on and of regularly. Turning it of and on makes no difference. Some times it flashes quickly then it'll stay steady for a little while the other...
It blinks when it does not receive any "signal" from your computer's video-card.
Check that the video-cable is connected.
Try a different monitor, to see if the video-card is the problem.
Try the monitor on a different computer, to see if the monitor is OK.
Jun 26, 2011 | Chi Mei Corporation CMV 943A Monitor
Hi, the monitor suddenly turns a very green/yellow hue and is doing it more regularly now, it sometimes just as quickly goes back to normal. Any ideas? thanks
It can be the cable, please check all the pins at both ends and make sure they fit tightly to the connector at the monitor and at the PC, it can be the video card rpblem also so you need to try this monitor with other PC.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 12, 2010 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
I have an HP the monitor doent turn on but all the light are on how can i fix it.
1. unplug the monitor from the computer and check if you can see the monitor selftest (you will see diff color bars moving around) if you see the monitor self test then your monitor is working fine
2. check the cables. use a diff cable to connect your monitor to the computer. use a known good cable.
3. plug in your monitor to diff computer if it worked then you have to reseat your video card
(NOTE : before removing any internal parts from your computer. your pc must be off and the power cable is removed, after removing the power cable press the power button for about 5 secs to remove any electro static discharge)
4. after reseating the video card and still doesnt work remove the video card from the computer. use the onboard video card if you have one.
if it does work then the video card needs to be replaced.
you can also try to reset the memory by removing them and reinstalling them inside the computer
hope this help
Sep 07, 2010 | Computers & Internet
When turning the screen on, the light turn green but then turns orange and nothing comes on the screen
This means that the monitor is not getting a signal from the computer. The problem could be the video or graphics card or it could be the monitor itself.
Try to connect the monitor into a known working CPU. If the monitor works, then you need to check your video card.Try to pull out the card and clean it using a DRY clean cloth. And then re-seat the card to the slot. If nothing happen, insert the card into an available video slot. or try different computer. If same problem occur, contact the manufacturer.
NOW, if the problem is the monitor, check the cable, try to use different video cable. If same problem occur, then it should be checked by a technician.
Thank you and good luck!
Jun 28, 2010 | Hyundai ImageQuest L70N 17" LCD Monitor
WhenI turn my monitor on, a screen appears saying VGA input - no signal & DVI input - no siganl & then it goes to sleep
Do you have multiple Video cards installed in your computer?
Check the monitor on another computer to verify the Monitor works and so does the cable.
If Monitor works, cable works, and you have 1 video output from your computer, then your Video card is probably no good.
Jan 26, 2010 | Compaq fs740 17" CRT Monitor
When i turn the computer on the monitor says it is in power saver mode and to activate using the pc please help
Sounds like your monitor is not getting any signal. The monitor is probably working fine its the video card or connection that is having the problem. Check all cables, then check to make sure video card is working. Does your computer POST without any problems when you turn it on? Do you have an onboard video port and a AGP/PCI-e/PCI video port? If so, is your video connected to the onboard or the AGP/PCI-e/PCI
Jul 08, 2009 | Dell E773C 17" CRT Monitor
Monitor
try a different input cable and check if this is a cable or some loose connection problem.
that itself may get the problem solved many times.
Aug 01, 2008 | Computers & Internet
Monitor screen changes from regular color to a green tinted screen?
Is the cable connected securely? You may need to check your video card also. You may be able to disconnect the cable and get a red, green, blue icon on the screen. If that appears normal then there is nothing wrong with the monitor itself, it may be the cord or the video card.
Hope this helps!
May 31, 2008 | Dell 1503FP 15" LCD Monitor
Dell C521 DimensionTM PC Desktop Logo
62 people viewed this question
Clive
Clive
Alun Cox
