Question about Fisher and Paykel GWL11 Top Load Washer
My machine won't power on - Fisher and Paykel GWL11 Top Load Washer
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 56 Answers
Your starter switch isn't engaging, need to test it
Posted on Jul 19, 2013
Power won t stay on
1.check outlet to make sure it's ok
2.could be power cord
3.could be connection between power cord and sewing machine
4.could be short in wiring
if it continues, I suggest to have the machine checked
Jan 17, 2014 | Sewing Machines
Machine won't power on
check motor and pump for shorts to earth, replace motor controller. check for earth faults before reconnecting power.
Jul 18, 2013 | Fisher and Paykel GWL11 Top Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
Washing Machine Intuitive Eco model number IW811 won't power on?
Possible Cause Solution The power switch is not turned on at the wall. Unplug the machine from the wall. Wait 60 seconds, plug back in and turn the power back on again. The household power supply is at fault. Try plugging another electrical appliance into the power slot.
Aug 06, 2012 | Fisher and Paykel Washing Machines
Bernina 1130 power cord won't retract
since the machine is a bernina, the machine probably needs to
be checked at a sewing machine shop, to see why the power
cord won't retract
Jun 03, 2012 | Bernina Sewing Machines
How to turn on the machine?
what the meaning with your question ?
your HP ProBook Charging oke but won't turn on ?
or not charging and won't turn on ?
or What ?
if i see your question "How to Turn on the Machine ? "
of course the answer is " By pressing the Power Button or Power Swith "
Jan 06, 2012 | HEWLETT-PACKARD HP ProBook 6550b Notebook
The machine won't turn on at all. Tried t in several functioning outlets and it won't power up. Only 6 months old. Keurig B60
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Aug 11, 2011 | Keurig B60 Coffee Maker
After a power outage, the lid is locked and won't open. I tried running a new cycle but won't run either. Any suggestions. Thanks, Jan
This is a common problem, often associated with a momentary power failure when the controller doesn't get time to reset and return to an idle state before the machine gets power back and it gets "confused". Regardless of the cause, you will almost certainly find that unplugging from the mains (Not just powering off on the button, as some door locks have a sneak circuit, even when the power is turned off at the button) and leaving the machine undisturbed for a full 20 minutes will allow a reset, the door lock will disengage and all will be well when you power back up.
Additionally, on older machines with analog program selectors, turn the selector to an end of program setting before you power it off.
Jul 11, 2011 | Washing Machines
My hoover washing machine top load won't start. I have checked the power from the wire going to the timer.The door latch switch is working and still it won't start.
my hoover washing machine do not stop they show 1 min left . i was try serval time the happend is same and inside few water as well
May 26, 2011 | Hoover HTC243 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
12 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
