Question about Samsung UN46C6300 TV
Factory reset screen has set time message on screen that will not go away
Message not sent on alcatel pop icon a564c
Your unspecified model of Alvatel cell phone is buggy. Try to do a Factory Reset if bug goes away. You chould look up in your manual if factory reset is available, else you caould visit the office of your Mobile Service Provider, they know how to do a Factry Reset.
A warning, after factory reset you'll lose all your saved data!
Aug 06, 2015 | Alcatel Cell Phones
Tip
How to reset Acer Aspire 5315 notebook to factory setting
There are two ways to reset the Acer Aspire 5315 notebook to factory setting which also means to reset it to the original setting.
The first way to reset the Acer Aspire 5315 to factory setting:
  1. Log-in as Administrator (if you have more that one account on your notebook).
  2. Go to Start.
  3. Select All Programs.
  4. Then select Accessories.
  5. Press System Tools.
  6. After that, press on System Restore.
  7. A page will appear, press Restore My Computer.
  8. Next, press next to continue.
  9. A message will appear, press Ok.
  10. Press next to confirm the restore point.
  11. The system will be restored.
  12. Restart the notebook.
The second way to reset the Acer Aspire 5315 to factory setting.
  1. Turn on the Acer notebook.
  2. Wait for a few seconds until you see the 'startup' process appears on the screen.
  3. As soon as you the 'startup' on the screen, press Alt+F10 for about five times.
  4. This will set the notebook automatically to factory setting.
**Try these steps at your own risk. Make sure to save on a Pen drive or USB Flash Drive any important documents/files before resetting your notebook.
on Apr 22, 2010 | Acer Aspire 5315 Notebook
How to unlock screen, when code number is lost?
Reset LG G2x P999 to Restore Factory Default Settings
How to hard reset (factory reset) the LG G2x P999?
There are two different ways you can reset your LG G2x P999 to its factory default settings, via settings menu and using phone buttons. WARNING!!! If a factory reset (hard reset) is performed, all installed application and user data such as messages, phone contacts, image, video and audio files will be erased. Please remember to back up any important data before performing a factory reset.
Reset LG G2x P999 using Settings Menu
  1. From the Home screen, press the Menu Key .
  2. Touch Settings > Privacy > Factory data reset.
  3. Read the warning and touch Reset phone.
  4. Touch Erase everything.
Reset LG G2x P999 using Phone Buttons
  1. Turn the power off.
  2. Press and hold the following keys at the same time for 15 seconds: Home Key+ Power Key + Down Volume Key.
  3. When the LG logo is displayed, release the keys. The phone will turn on and
    perform a factory reset immediately.
Resetting the phone does not erase any system software updates you have downloaded or any files on your microSD card.
Mar 26, 2015 | LG G2x / Optimus 2X 4G Android T-Mobi8GB...
Screen locked and unable to unlock
Turn off . Press and hold POWER + ENTER button for reset menu.
Select
Factory reset with Volume Down button and press Power to reset. All data will be lost! there is an alternate method too friend
Use this method to hard reset your Samsung GT-S Galaxy mini phone: Enter *2767*3855#. Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup to your PC before full reset! Take out SIM card before full reset.
Samsung GT-S5570 Galaxy mini download mode if you want to install eg. Gingerbread
Press and hold Volume DOWN + HOME + POWER ON S5570
Restart your device to clear any temporary software bugs
If you know the hard reset with buttons / keys, pls leave a comment. All comments are welcome!
Your device freezes or has fatal errors
If your device freezes or hangs, you may need to close programs or reset the device to regain functionality. If your device is frozen and unresponsive, press and hold [Power] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Idle mode, open the application list and select Settings :Privacy
:Factory data reset :Reset phone : Erase everything.
Clear storageā€¢ : Erase the credential contents from the device and reset the password
Set an unlock pattern
Once you set a screen lock, your device will require an unlock code each time you turn it on or unlock the touch screen
Settings Location and security Set screen lock : Pattern
If you forget your PIN or password, bring your device to a Samsung Service Centre to reset it.
Set an unlock PIN code
Settings Location and security :: Set screen lock : PIN
Set an unlock password
Settings Location and security :Set screen lock : Password.
You can hard reset software firmware update your Samsung GT-s Galaxy mini phone
Hope it helps u
Dec 08, 2013 | Samsung Cell Phones
Want to reset all settings
Follow the instruction given below:
Press "Home" > Settings >Privacy >Factory Data Reset
Read the message stating the types of data that will be deleted, then tap Reset Phone.
If you are certain that you would like to restore all factory settings, tap erase everything. Your phone will reset to the factory settings.
You can also use the method:
  1. Select Main Menu from the Home screen
  2. Tap Settings
  3. Scroll to and Select Phone Settings
  4. Scroll to and Select Reset Settings
  5. Tap Master Reset
  6. Tap Yes to confirm
  7. Enter the device's security code, then tap OK. NOTE: The default security code is 0000
Regards
Jul 07, 2011 | LG KS660 Cell Phone
I keep getting the error message "The process
Doing a Factory Reset should do the trick. Be sure to **back up** your text messages, bookmarks, apps etc before you do this.
Mar 05, 2011 | Google Android
I have a flashing message icon on the botton of my screen but i have no unread messages and it wont go away
You might have an unread message or you have an unread message on your sim from prevouis cell phone. Go to messaging, options, sim messages. Look for unread message
Jul 17, 2010 | Nokia E72 Smartphone
My blackberry
You Blackberry needs to be restored to factory settings.
The steps you need to take are described at : Restore Blackberry to factory settings.
May 12, 2010 | RIM BlackBerry Pearl 8100
PCG-9G1L SONY
not too sure what you mean here.you can reset bios to default or can set bios to factory reset.to set default ...when you turn on pc ,message at bottom left hand screen indicates which key to press to enter setup(bios setup) note...its very brief;mines f 10 for instance.at startup press this key and select load default then select save settings and exit;then ur pc restarts with default settings.
To reset bios to factory requires disassembly.
you locate rtc and remove battery(looks like large watch battery)for 5 minutes then replace,reassemble and restart pc.you dont need to know what rtc means(real time clock)or what it looks like cos the battery is right next to it.
Mar 04, 2008 | Sony VAIO FXA63 Notebook
"Inbox Full" message
i have this problem too and i dont know why its happeneing, i cant receive any messages because of this and i have erased my whole inbox and outbox! have you solved the problem yet? if you have please let me know my email is becky__da_sexy_chick@msn.com i would be very grateful for this help. thanks
Dec 28, 2006 | Motorola Mobility RAZR V3
Samsung UN46C6300 TV Logo
21 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
