I have power in both speakers and the wire connecting the two is plugged up but no sound is coming out of the speakers.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 56 Answers
Go to the control panel and click sound and change settings to exterior speakers
Posted on Jul 19, 2013
Why am I getting a alternate he whining when RCA plug is plugged in speaker RCA jack is plugged in
Good wiring practices and noise reduction accessories can help cut back on alternator whine and ignition popping sounds thru auto audio systems.
Typically, amplifiers and other high current devices work best when power leads are direct connected to the vehicle battery. The remote on signal should come from the head unit or other location of choice. Use only shielded signal cables between head unit and amp. Try to keep as much space as possible between the audio wires and power wires - including speaker wiring.
By connecting to the battery directly, it acts like a giant capacitor. It is also where the cleanest, level DC power in the vehicle is - the further away from it you go, the dirtier is gets. Even only a slight AC ripple on the DC level voltage can wreak havoc on the sound coming from the speakers. You can add a "choke input filter" to further reduce the AC ripple. There's a ton of data on these filters, so I'll leave you to determine how far you want to dig - here is the Google result page:
choke input filter Google Search
May 23, 2014 | Car Audio & Video
Why wont my sound come out from the speakers you cant hear nothing from the speakers it turns on and everything but no sound
if you have a factory amplifier you have to connect the blue wire from the amplifier plug into the power wire for the player
Jul 14, 2010 | XO Vision XOD1735 Car DVD Player
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
I need to hook speakers up to my Dell B110 computer.
2 things are needed to get sound from your speakers:
1-wiring connecting your speakers to a socket to the back of the computer. (The spot they need to plug in to ON YOUR COMPUTER is a small light green circular socket. The other end of the plug you plug in here should run to one of your speakers *usually the right side speaker-the right speaker should then have separate wiring to connect the left speaker.)
2- A source of power.
Some speakers use their own power source and plug in to a power outlet - your wall. Other types have a USB type plug and plug into a USB port in your computer and that is how THOSE get their power.
Those are the basics of sound setup. Some computers are equipped with more complicated setups such as surround sound, subwoofers, digital and more. Reply if you need more help, I will try to assist you further.
Hope this helps.
Feb 02, 2010 | Dell Dimension™ B110 PC Desktop
I just bought some speakers and a receiver, cd player no instructions, how do i connect it myself
- Use a cinch- cable (red&white) to connect the cd player to the input (often called CD or AUX) of the receiver
- Use standard speaker cable (two copper wires per wire) to connect each speaker to one speaker-output on the receiver
- Plug in the power cables
- Select the right input (or source) on the receiver
- Voila! Press play on the cd player and sound should come out!
Oct 08, 2009 | Audio Players & Recorders
Installing an aftermarket stereo in 1996 explorer...sound issues.
You may have a factory amplifier in the rear of the explorer in the right cargo panel. You need to supply power to it by connecting the amp power on (Blue/White I think) in the dash to a power source (such as red on your stereo harness) so it comes on with the key. If you do have the amplifier, that's why you have no sound.
Oct 02, 2009 | 1996 Ford Explorer
Wiring internal board of labtec computer speakers
The shielded wires are for ground, so they get connected together. Plug the wire into the PC and run some music. Then touch each wire to the others. You only have a couple of combinations to try...red-to-green and white-to-yellow, or red-to-yellow and white-to-green, . You can do this while the PC is one and music playing until you get sound thru the speakers. There virtually no current running thru the wires and you can't hurt the PC by doing this.
If the speakers use an external power supply, have it plugged in and working when trying these connection options.
Sep 07, 2009 | Labtec LCS 1040 Computer Speakers
No sound from my BA745 speakers
Make sure you have the right speaker wire (green plug to green socket)
You should have three wires going into the right speaker, the left speaker, sub woofer, and the power wire...and one wire coming out as mentioned above.
double click on the speaker (lower right corner of the monitor) and make sure the volume levels are normal. And too check the volume level on the right hand speaker.
hope this does it for you,
PLease leave rating...thank you
May 14, 2009 | Boston Acoustics BA745 Computer Speakers
Loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Dec 16, 2008 | KLH HTA-4906 System
Help with speakers!@!@!@@!!
The odd plug coming out of the speakers is to connect to a power adapter to power the speakers, the other is to plug into the output plug of your sound card. Normally this is color-coded on the back of the computer in a light green colour.
Dec 05, 2008 | Dell AS500 Sound Bar Computer Speakers
 Grubhead
Grubhead
