Question about GE Hotpoint 30" Self-Cleaning Freestanding Electric Range - White-on-White
No gas to burners & display reads "unloc dor" when try to turn oven on.
However, the oven door has never been locked. It has a manual lever, which I have moved back and forth and jiggled to try to "unlock" the door. The oven door opens just fine. I have tried unplugging the stove for a few minutes and for several hours -- no change. I also don't hear the usual tic tic of the pilot trying to light the burners. I do not smell gas around the stove at all. Any other ideas or is it time for a new stove?
I try to turn on the self cleaner and it only beeps 3 times but then does nothing.
read the manual .look above the oven handle and see if there is a door lock lever , slide it to the right and see what happens .
Nov 11, 2015 | Whirlpool WFG371LV Black 30 4 Burner Self...
Magic Chef Range - oven door won't open Gas Oven with stove top 1980's Model 64DY-3CKXW all dials/no electronic displays There are two dials for the oven One that controls the temperature and another that...
If a selfclean oven door lock fails to open after the self clean cycle and sufficient cooling time has elapsed (approximately 1 hour), there are several things you can try.
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Most self cleaning ranges today use one of 3 different types of door locking systems. One design is solenoid driven, another is heat activated and the last, motorized.
  • A solenoid controlled system can be identified by the lever that must be set to lock the door, plus a loud buzzing or clunking noise heard when locking or unlocking the door.
  • The heat sensitive lock mechanism also has a locking lever but makes no noises. It instead utilizes a coiled spring to slowly lock the door as the oven heats.
  • The motorized design has no lever to move, the motor locks the door by itself when the range is set for self clean. The motor may have made an audible whining or ratcheting sound when in use.
A motorized or heat sensitive style lock will usually be located beneath the cook top on free standing ranges. The cook top would usually need to be lifted to access the locking mechanism. On built in ovens, the oven must usually be removed from its enclosure (or at least partially) in order to remove the top panel to gain access to the locking mechanism. On some built in oven models, the lock assembly may be able to be accessed by removing the control console.
sc-lock-geheatsensitive.gifOn the heat sensitive style (illustrated), there are no electrical parts used to operate the lock which could fail, so the whole mechanism will usually need to be replaced if not operational.
With the motorized lock mechanism, a volt/ohm meter is required to try to determine why the locking motor will not operate. The failure could be in the motor itself or the power supply leading to it, including a door activated and/or console mounted switch and switches on the latch mechanism itself.
On solenoid activated designs, the solenoid coil is a common failure point which is often mounted on the back of the range. On many of these models, the lock mechanism can be accessed by removing the rear panel of the appliance. Some models such as built-in ovens or drop-in/slide-in ranges, may have the mechanism mounted towards the front, under the top.
sc-lock-gelocksolenoid.anim.gifFailure of a solenoid style lock is most often caused by a bad solenoid. Once the lock is located, the solenoid coil can be checked for continuity. Some latch assemblies also have micro switches in the power supply that will need to be checked for faults too.
Be certain to unplug or remove power from the range before undertaking any repairs yourself and follow all standard safety precautions.
usually if you are unable to open it after all these tests then you would resort to manually opening the door by getting a piece of wire and slip it where the latch mechanism is and prying to the left this is a last means resort so try these other ways and get back to me with any further questions that you may have and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Dec 18, 2010 | Magic Chef Ovens
Clock works, locked door appears and door is locked, burners do not work
locked door appears In the clock display?? this is the eoc telling us that there is a problem with the door interlock or it's system . however this has nothing to do with the top burners/ there independent of the oven system . now when there is a code in the display. the oven will not heat and you may not be able to dor open . this is a job for service tec . turn off power for 15 min. and retry .mm
Nov 22, 2009 | Frigidaire PLEF398AC Electric Kitchen...
Oven door locked
THIS IS NOT A STRANGE PROBLEM. Many times the lever that you move to lock door becomes slightly bent and it now will not travel completely to the unlock position (yet you can't tell just by looking) and it only needs to travel another 1/8 or 1/4 inch; you need to bend the handle in the oposite direction in order to get the extra clearance when moved to the unlock position. If this does not work, then you need to remove the burner top; some lift up, others need the individual burners removed (unscrewed) so the burner top can be lifted. Inside you will see a metal arm attached to the lever. This arm is either moved by a small servo-motor (geared rotation motor) or it is attached to a small micro switch or magnetic selenoid. You may need to disconnect the arm or rod from any of these components in order to move the lock lever and tereby release the lever tong from the door. Goodluck, Macgivor
Nov 13, 2009 | Kitchen Ranges
Ge xl44 after self clean cycle the door won't open and the display says "locked door" flashing.
or
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Sep 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
After canceling self cleaning on my GE Hotpoint oven, I was able to unlock the door and open the oven door. When I try to use the broil or bake feature it keeps saying "un lock dor" The door is not lock...
You will need to allow oven to cool, the temperature is one thousand degrees plus while the oven is cleaning. Until the oven cools it will not open, this is a safety caution. If it will not open after it is totally cooled, it may be stuck, try pushing on the door or pulling it out a bit while trying to move the lever.
Always consult the owners manual when using the cleaning mode on your oven. Be sure it is fully cooled before cleaning any residue out of oven area.
Jan 28, 2009 | Kitchen Ranges
Self-cleaning error message f90
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 30, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
What does the errror code F90 mean?
unplug the range.
wait 1 minute.
wait 2 minutes.
Nov 18, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
LOC for oven door is unable to unloc
Put the oven in Self Clean mode for 3 minutes and then cancel.. if if that will release the relay that controls the lock. If that doesn't work, Unplug the oven for 10 mintues, then plug it back in holding the CLEAR button down. If neither of those work you will need to contact a service repair man.
Jul 19, 2008 | Ovens
New fridgidaire self cleaning oven w/ no insturction manual
its a new oven?? press the clean button the arrow up(the display should read 3:00, press start,the door will automatically lock and your on your way. remember to remove racks first, they will warp and discolor
Feb 24, 2008 | Ovens
GE Hotpoint 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
48 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
