Question about La Crosse Technology Equity by La Crosse 30220 Desktop Temperature Station/ Time Alarm Desktop Temperature Station
I have Model:WT-8029U clock and cannot get it to change to mountain time. Could you tell me what to do?
How do I change to daylight saving time?
Your clock may have failed in a way that new batteries won't help.
Apr 04, 2015 | La Crosse Technology Atomic Wall Clock -...
How to set a Model:WT-8005 atomic cllock
download the manual from here: http://www.manualslib.com/manual/533191/La-Crosse-Technology-Wt-8005u.html
Mar 16, 2015 | La Crosse Technology Black Model Wt-8005...
La crosse atomic model wt 8005 clock instructions
The WWV broadcast is not really strong in some locations, so if things have changed in your area, like the location the clock is in or addition of items that produce interference like flourescent lights, change them back to the way they were. If that does not work try setting the clock near a window for several days and see. If you dont get synchronized time then the receiver in the unit may have gone out.
Jan 27, 2014 | Home
I have model WT:8029U solar power clock. How do I set it to Mountain Time?
If you have the LaCrosse WT-8-29U, it isn't hard to set the unit manually. After the unit receives the signal from the NIST radio station and sets itself (or fails to receive the signal), turn the clock around. (If you have it on a wall, take it down first.) Press and release the Set button (left-most button). Then press the + key (the button to the right of Set) to toggle through to MST. If you press and release Set again, you can use the + key to toggle DST on and off.
The manual for the WT-8029U is available here: http://www.lacrossetechnology.com/8029/manual.pdf .
I hope this helps.
Jul 19, 2013 | Audio Players & Recorders
MODEL:WT-8005 CLOCK IS 1 HOUR AHEAD HOW DO I TURN IT BACK?
Check both of these
  • Daylight Saving Time Automatically Updates (DST) (On/Off Option) applies to both USA and UK
  • U.S. Time Zone Selection: Eastern, Central, Mountain, Pacific (applies to USA only)
  • Mar 15, 2011 | La Crosse Radio Controlled Atomic Clock
    Does Lacrosse Model Number WT 2171U have a light or backlight ??
    No, this model does not have a light or backlight. Feel free to peruse the manual information at your convenience though, and I do hope I've helped!
    WT 2171U manual
    Sep 28, 2009 | La Crosse Technology WT-2171-UCS Digital...
    How to set time for day light savings time on wt-2171u
    http://www.lacrossetechnology.com/2171/manual.pdf
    Simple to fix
    Mar 09, 2009 | La Crosse Technology WT-2171-UCS Digital...
    La Crosse Technology Equity by La Crosse 30220 Desktop Temperature Station/ Time Alarm Desktop Temperature Station Logo
    37 people viewed this question
    Top La Crosse Technology Measuring Tools & Sensors Experts
    Tom Chichester
    Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
