Question about Sampo PME-50X7 50 in. HD-Ready Plasma Television
Technika LCD191d-107 LCD TV
I just recieved a lcd tv from ebay and it was working fine for a few hours whilst i played the ps2 on it until it flashed and a white line appeared down the left, its not a small line its about 5cm wide. any idea why this has happened.
  • 4 Answers
You may want to check the solid state fuse on the power suppy or which can be called the inverter. The fuse will blow and finding a fuse can be hard.
Thanks
C Dill
Posted on Sep 10, 2008
The company i work for bought Technika LCD191d-107 LCDTV, it was less than 9 months ago, we cant trace the receipt, the shop they don't want to now about this , the lcd has label of the time of manufacture was Sept 2007, can you help?
Posted on Jul 31, 2008
Technika LCD TV 22" - 208 the top half flickers
Your caps are fine I would think. This is heat related. Sounds like your transistor for the top CCFL's is weak or leaky. Once it is hot it equals out. You can test this by spraying freeze spray once the set is running properly. If it starts acting up when you spray it, you found your problem.
May 11, 2012 | Televison & Video
I have a 32" LCD
Tries tv turn off and turn on again about an hour later,see if the tv do resetting,tv might be back working to normal again.If still have the same problems.The tv have 1 or 2 long boards that call LCD inverter boards.These 1 or 2 long LCD inverter boards are dead.These 1 or 2 long LCD inverter boards are to help the tv LCD screen panel to have a backlight for the LCD screen panel to produced a pictures.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter board for the replacement.
May 13, 2011 | Televison & Video
I have a technika lcd tv model:lcd191d-107/207 stuck on standby i have not tried anything yet can you help please
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for different brand, but same issue) on youtube.
utube.png You-Tube video "BNHHrgX_6cs&feature=related" placeholder
utube.png You-Tube video "8l0AUj8QUkg&NR=1&feature=fvwp" placeholder
utube.png You-Tube video "Y7b_nTaZYcU&feature=related" placeholder
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Mar 10, 2011 | Televison & Video
Technika flat screen - model No LCD19ID-107. WHEN
There is a Diode and probably a Resistor blown on the power supply board... Check out the fix on my website:
http://normsweb.com/tektips/technika.shtml
I hope this helps you.
May 18, 2010 | Televison & Video
Trying to get a code for the tv so i can use my
Hi, Unless the Sky remote has a learning area for Television control, then it is unlikely that this remote will work - Sky should be able to confirm this for you
Mar 19, 2010 | Televison & Video
The remote control for our Technika lcd 26-207 doesn't work.
Sounds like maybe the remote receiver on the tv itself has gone faulty if a replacement remote doesn't work.
email me on markiexxxx (at) gmail (dot) com
for more info...
Sep 29, 2009 | Televison & Video
Need a code number for a lcd 19id-107 technika 19 in lcd tv
www.remotecodelist.com
www.tvcodes.com
www.remote-codes.com
One of these websites will have your code. I didn't know what brand and model remote you where using.
Sep 05, 2009 | Televison & Video
Red flashing light on my lcd tv technika 191d 107
Did you fix this yet?Please let me know.Thank You very much!
Tyler
Jan 06, 2009 | TruTech PLV16190 Television
Sampo PME-50X7 50 in. HD-Ready Plasma Television Logo
1,649 people viewed this question
Top Sampo Televison & Video Experts
Mohamed Ismail
Mohamed Ismail
Are you a Sampo Televison and Video Expert? Answer questions, earn points and help others
