Pac w110e hl always on - Heating & Cooling
Tip
Air Conditioner User Manuals
Air Conditioners:
Pelonis units are manufactured by Midea Group. You will need to contact them for the manual they can be found at the following link:Download
or Via their contact page (depending on your country):Download
De' Longhi
De' Longhi PAC A120E Portable Air Conditioner Download
De' Longhi PAC C120E Portable Air Conditioner Download
De' Longhi PAC T110P Portable Air Conditioner Download
De' Longhi PAC WE125 Portable Air Conditioner Download
on Jun 08, 2011 | Heating & Cooling
Emergency lights, brake lights and hight beams work but the tail lights and heads lights dont come on and work. What could be the problem
fuses, check all fuses. 1st.
this car has diffr. path for park/tail lamps (same path as cab lights)
just a switch (park) turns them on, NO RELAYS.
there is a high beam relay marked, dimmer. and
a HL relay (head light ,low beams)
both fuses can't blow on HL, lows. no way.? huh? but seen it with a berserk Alternator.
all answers USA< not canada or? with DRL. so... do post country. or Honda market code, KA is USA.
i always check the HL relay 1st. (lows)
HL are hot all the time. no key needed at any time (easy)
i always go to the mid point in the circuit. (saves 1/2 the work)
i go to the HL relay; 1 checks here.
1: power contractor pin, input, 12v all the time, if not fuse bad.
2: coil top pin, 12v all time ,same answer.
3: HL on, coil bottom 0v, if not the combo switch is bad.
4: HL on, contactor out 12v, if not and above ok, Relay is bad.
the book is here, you can see the HL in chapter ,23 .
if not usa or car has DLR?;, do say so, nobody ever does, but do.
http://hondatech.info/downloads/Auto/Manuals/Accord/
Nov 11, 2013 | 1995 Honda Accord
Wiring instructions for PAC Tr7 video bypass, for ixa-w407
Hello! go here for instructions....http://assets.sonicelectronix.com/manuals/pac/tr7.pdf
Guru...saailer
Jan 18, 2012 | PAC Audio Pac Tr7 Tr-7 Video Lock Bypass...
When ever I turn the air condition on. this symbol (HL) appear on the small screen, and it won't open What does that mean? Thank u
I think what you are seeing is "FL", rather than HL. FL indicates that the water collection bucket is FULL & needs to be drained. Sometimes. the LED letters on the screen can be hard ti read.
Hope this helped you and thanks for choosing FixYa.
Aug 10, 2011 | DeLonghi Pinguino PAC T100eco Portable Air...
Detergent door opens, but does not spring back. After cycle is done, some of the soap is still in dispenser because door does not open back all the way.
Hello. I can illuminate this issue for you and offer a couple of choices. Dishwashers have a soap dispenser located on the inside of the door. When the timer cycle calls for the soap to be emptied into the dishwasher, it either sends electricity to a bi-metal switch that opens it, or it mechanically opens the soap dish.
I always recommend to my customers that they go with a product like cascade 2 in 1 action pacs. These little pacs are merely tossed into the machine before you close the door with no concern about the soap dispenser at all, and they work better than any powder or liquid alone.
Jun 21, 2009 | Dishwashers
Cd drive problem
if you get to see a yellow exclamation mark that means to say that you will need to install the driver of that device. the current driver may be corrupt of non-functional. download the latest driver
Jul 13, 2008 | Computers & Internet
Despenser cup - Kenmore dish washer
hi
the dispenser will always open when the washer goes through it's regular cycle. I would recommend to only use powdered soap, that is what the washer was designed to work best with.
Mar 20, 2008 | Miele 24 in. G892SCU Plus Built-in...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
