Question about iHome Technology iC50 Stereo Alarm Clock Radio for Android
IC50 mode shuts off after 3 minutes
When playing music on the music player on my Galaxy S3, it shuts off after 3 minutes. I have to keep pressing the mode button to get to music to play. Please help...this is extremely annoying. :) Thanks.
I have a samsung s3 gt-i9300 i cant make or get
Your Samsung Galaxy S3 must be restricted to some specific network. That is why it allows only emergency calls when a SIM card from some other network is inserted in. You need to unlock your Samsung Galaxy S3 to make it work with all SIM cards. You can unlock your Samsung Galaxy S3 safer and easier using unlock code. You can get the accurate unlock code for a Samsung Galaxy S3 from Unlock-Zone.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
Method 1:
1 - Switch ON your Samsung Galaxy S3 with a NOT ACCEPTED SIM Card.
2 - Samsung Galaxy S3 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung Galaxy S3 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung Galaxy S3.
3 - Compose : #0111*CODE#.
SOURCE: MobileUnlockGuide.com
Oct 02, 2014 | Cell Phones
Esquire Wireless shuts off during play
Think I might just have discovered the issue here. I had the same problem but didn't realize that the volume was maxed on the unit (as I was controlling it through the phone). As soon I brought the volume down on the unit the problem went away.
Apr 13, 2014 | Harman Kardon Audio Players & Recorders
Android bluetooth
remove the jacket of your music syste from your car, look out for the reset button in it, reset it, install back the jacket, try connect now and play the music, it may help
Apr 11, 2014 | Alpine eX-10 iPod Controller with...
Samsumg galaxy tab 3 shuts off every 30 minutes
Check the power settings to see if that is the cause of it shutting down. Streaming music does not produce the keep alive activity that is required, so it thinks that it isn't being used and turns off.
Mar 19, 2014 | Samsung Galaxy Tab Tablet PC
Galaxy s3 won't turn on fully
Hello Sarah,
You can try these solutions:
Solution 1: Soft Reset(no data loss)
  1. Take out the battery and leave it there for 5 minutes.
  2. Reinsert the battery.
  3. Press and hold the power button for 10 seconds.
Solution 2: Replace Battery
  1. Take out your battery
  2. Insert new battery that you found from a friend or family with same model.
  3. Power on
  4. If it works,buy a new battery
Solution 3: Hard Reset(you will loose your data)
  1. Switch off the device.
  2. Press and hold Volume Up + Home Button + Power Key.After 2-3 seconds, release the Power Key.
  3. You will enter boot screen,use volume buttons to navigate and select Select Wipe Data / Factory Reset and then press power key.
  4. Select Yes.
  5. Reboot your device and wait to power on.
If nothing works you have to take it to your supplier.
Nov 28, 2013 | Samsung Galaxy S3
I just installed this unit yesterday and I am using a Samsung Galaxy S3 as the music playing device over Bluetooth and so far I'm hearing a brief cutout/popping sound during music playback and it's really...
roflmao - I just upgraded my phone from a samsung galaxy s4 and the AT&T tech laughed as he asked me how i managed to keep mine working so long.
you likely need a new phone dude. the easy solution: get a new one.
Mar 08, 2018 | JVC Audio Players & Recorders
S3 Galaxy mini switches off
I had the same problem with my s3 shutting down and rebooting. The problem wasn't with the software or the main body of the phone, it was the back cover obstructing the operation of the switch, not allowing it to pop out smoothly (I could hear the switch scratching on the case when pressed). I rremoved the back case and pressed the on off button and it didn't make the squeaking scratchy noise and had no resetting issue. I shaved a little from the edge of the case and now there's no issue at all.
Nov 18, 2012 | Samsung Galaxy S GTI9000 Smartphone
Does YP-S3 Have Bluetooth? Or It can Put Bluetooth on my own?
YP-S3 has not Bluetooth. Unfortunately you can only listen to music of it with corded headphone.
Thanks.
gylacz
Aug 31, 2011 | Samsung YP-S3 Digital Media Player
Wont play the whole song
Sounds like the player is running in INTRO mode, only playing the first part of each song. To change playback mode, follow the steps as described below.
Switch the player ON and start music playback:
1. Press PLAY button to START music to play
2. Press PLAY button again to PAUSE the playback
3. Press MODE button to enter playback mode selection
4. Scroll with MODE button through selections
5. Press MODE button when selection REPEAT is in the display
6. Use MODE button to select from: Normal, Repeat One, Repeat
within current Folder (if any), Repeat Folders (if any), Repeat
All songs, Random Play back, and Intro
7. Press MODE button to confirm selection
May 02, 2010 | Element Electronics GC823 MP3 Player
iHome Technology iC50 Stereo Alarm Clock Radio for Android Logo
82 people viewed this question
Top iHome Audio Players & Recorders Experts
ray gallant
Tom Chichester
Are you an iHome Audio Player and Recorder Expert? Answer questions, earn points and help others
