Question about HP OfficeJet 7110 All-In-One Thermal Printer
Why is my printer saying original loaded?
Im trying to print and the printer keeps saying original loaded. How do i stop it from saying that so that i can print ?
    Sergeant:
  • 279 Answers
Is there a piece of paper in the top (copier/fax) feed, or under the top against the glass? Original Loaded means there's some document in place, ready to be copied or faxed. If you remove that, the message should go away. If there isn't one, check inside the feed on top, and see if there's anything stuck in there that could be blocking the sensor.
Posted on Aug 28, 2007
SOURCE:
A document was sent to the 5110cn color printer. it is a full color duakl sided brochure. Keeps trying to print but errors out before loading all images so all that gets printed is one or two of the...
The reaason it keeps trying to print is because it's in the print queue on your network.
Have whoever sent this to the printer open the print queue and delete it.
Only the originator or the print queue admin can delete the job
Jan 06, 2011 | Dell 5110cn Laser Printer
Paper sensor faulty - printer doesn't recognise when paper is loaded
Cannot print from the glass top. The top load area keeps running and then the message says to reload the original. Push OK and go in circles. Maybe the paper sensor is missing?
May 15, 2010 | HP Officejet Pro L7680 All-In-One Printer
Hi, im facing a problem with my Canon MP145 printer now. It keeps on showing the message"E14" and it cannot print. When i click on priont it says"The ink cartridge is not recognised" Please help me.
Hi, try removing the ink cartridges, cleaning their contacts and then replacing them. If this doesn't fix the problem, try replacing the carteidges with canon originals. This should do the trick!
Feb 27, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
Im trying to delete a pending which will not go
You can use the following command to stop spooler at DOS prompt.
net stop spooler
When the spoller stops, you can open the printer dialog and try to delete it. When it gets deleted, go to DOS and type:
net start spooler
Hopefully, this will solve your problem
Nov 21, 2009 | Office Equipment & Supplies
Canon Mx300 wont recognize my paper. says:load paper
I cant print...orange light under alarm keeps flashing...please help...patricia
Jun 04, 2009 | Canon MX300 Office All-In-One Printer
PRINT SPOOLER IS OFF
go to the run box and type
net start spooler
note: There is a space between the words above
Should be good.
or start, control panel (classic view), administrative tools, services, scroll down to
" Print spooler "
Stop and re-start it here
Regards
Richard.
May 20, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP Photosmart C5180 (wont accept photo paper but will normal paper)
Load the printer with the slick glossy paper face down. See if it will print.
Jun 06, 2017 | HP Photosmart C5180 All-In-One InkJet...
PRINTER WONT FAX AND WON'T STOP PRINTING
Hello Ncerritos. I have an ideaj that may help. First disconnect the AC power. Second disconnect the RS232 or interconnect cable to the mainframe and look for bent pins in cable or socket. If you find pins bent I worn you they are no very fexable. If it is the cable it would be safer to replace the cable, If its the socket you may try straighting CAREFULLY. I wish you luck on this ventur.
Sep 28, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Printer keeps reprinting same material
Hi Canela,
Unfortunately most printers have what is called a Cache memory. once you initiate a print job the computer loads it in to the printer, Much like filling a glass of water then the printer takes slow sips so as not to overload the job..if you decide to cancel the print job at your computer you also have to hit the stop button on the printer. In most cases this will empty that "glass" Out and clear the memory. In Vista this problem is inherent to that O.S. I'm still an Xp kinda guy. I hope this helps. Be mucho blessed.. Mark
Dec 07, 2007 | Lexmark X83 All-In-One InkJet Printer
HP OfficeJet 7110 All-In-One Thermal Printer Logo
597 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
