Question about Canon iP2700 Inkjet Photo Printer
Printer error 6000 - Canon iP2700 Inkjet Photo Printer
    Top Expert:
  • Canon Master
  • 12,223 Answers
Follow this instruction and fix it. God bless you
  • 1
    Make sure that the printer is connected to a power outlet. The power cable should be connected in the back of the printer and to a working electrical socket.
  • 2
    Check that the wire from the printer is running to the correct port on the computer tower. The wire runs from the small, square port on the printer to one of the USB ports on your tower or laptop computer.
  • Sponsored Links
  • 3
    Turn the printer on. Much of your printing failures can be avoided by making sure that the power is turned on before selecting the print command.
  • 4
    Install any updates or replacement software needed to run your printer on your computer. You can get this software from the manufacturer's website and will be notified through your printer drive if there is something new to download.
Feeder Problems
  • 5
    Pull out all of the paper supply in the printer and make sure that all pieces of paper are flat and whole. Any folded corners, crumpled sheets or torn pieces should be thrown away.
  • 6
    Check the size of the paper you are using and check the paper guide on the supply to make sure the paper is the correct size. The paper guide is the small plastic clip that holds the paper steady in the feeder.
  • 7
    Open the cover of the printer and make sure there is no paper stuck within the feed rollers. You should pull out the jammed paper if there is any, including any little torn pieces that may be stuck inside.
  • 8
    Clean out the feed rollers with compressed air to remove any dirt inside the printer and refill the paper supply.
Ink Problems
  • 9
    Check the ink levels in your cartridges to see if you have to replace the ink. You can do this through the control panel of your printer software. If you don't know where to find these controls, just search your computer for 'printer drive'.
  • 10
    Open the cover of the printer and wait for the ink cartridges to stop in front of you within the printer. This will allow you to take them out and replace them with full ones.
  • 11
    Pull the cartridges out of the printer. The number of cartridges and how to remove them will vary with your model of printer, but usually there is a small clip holding the top edge of the cartridge in place. Just push this clip back and pull the ink out.
  • 12
    Pull the protective seal off the head of the new ink cartridge. This is where the ink comes out and when you pull off the seal it will allow the ink to descend.
  • 13
    Drop the ink cartridges into the printer and push each cartridge into place. If there are clips you will hear them click when the cartridges are in place.
  • 14
    Run a diagnostics test on your ink heads if your ink problems persist after refilling the ink. This will help you clear out the heads.
Read more: http://www.ehow.com/how_6789824_troubleshoot-canon-printer-problems.html#ixzz2ZRL06I56
Posted on Jul 18, 2013
Error message 6000
6000 is a paper jam or jammed sensor.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#ServiceAndSupport
Click service and support, then enter error 6000, then click Error LCD ... 6000..., then click Removing paper jams mp600. Sorry, but they use javascript so I can't give you a more direct link.
Sep 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
My printer canon mx328 error 6000
what is remove for 6000 error simple tips
Aug 12, 2010 | Office Equipment & Supplies
My Canon MP980 is showing Printer Error code 6000. Have turn off machine and turned on again - no change - still showing.
error [6000] or light blinking 3 times is mean there is an error occurred in the LF encoder signal.
May 20, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon mx310 error code 6000
Error 6000 is a service call error, meaning that the printer needs to be taken into a canon authorized service facility for repair.
This is a line feed error, with the problem originating from the timing **** disk film or the printer's logic board.
May 22, 2009 | Canon PIXMA MX310 All-In-One Printer
C-6000 error
plz my printer is Kyocera TASKalfa 220 and I have error c-6000.
can you help me to fix it ?
May 05, 2009 | Office Equipment & Supplies
Service error 6000 canon pixma ip3300
Error 6000 means - The specified file could not be encrypted.
Solution: reinstall the printer driver.... it's better to install a upgraded version of driver...
Good Luck!!!
Sep 14, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon iP2700 Inkjet Photo Printer Logo
old marine
old marine
