Question about Garden
How much roundup would you put on an one acre yard to kill weeds
2 Suggested Answers
  • 15 Answers
SOURCE: Proper mixture ratio for roundup weather max commercial grade.
2 ounces per gallon. you can convert gallons to liters on the net.
Posted on Apr 19, 2010
How soon can weeds be mowed or watered after application of roundup?
Depends a littlebit on what tpe of weed but normally 24 hours after application on an actively growing weed is enough for it to be taken into the plant
Aug 03, 2011 | Roundup "" Weed & Grass Killer
Tip
A convenient way to kill individual weeds in your lawn
I purchase full strength roundup from places that sell fertilizers etc to farmers. I mix my own roundup per their recommendations plus a little. I fill a small eye drops bottle with my mixed roundup. I like this bottle because it has a small opening so I can squeeze out a drop at a time.. I carry the bottle of mixed roundup in my pocket, with the lid shut tight of course, and as I mow and I spot a weed I take out the bottle and place on or two drops on that weed. One drop of roundup on a leaf of a plant will kill it but I try to place one or two drops right in the middle of the plant. Roundup is fed to the root of the plant from the leaf kills the weed from the roots up. This works well because I can kill the weed without killing grass or other plants around it. Wind will not effect it because the roundup is place on the plant not sprayed on it. Roundup needs about 12 hours to work so do not water right away. Ready mixed roundup from a store may work, I have not tried it because I want to be sure the mixture is strong enough to do the job. About 4 ounces per gallon of water is recommended, I increase that to about 6 ounces. Works great.
on Apr 16, 2010 | Garden
I just want to know how much of roundup to put in the tank, you use air to disperse the weed killer?
Yes I do use it, you can put about 1qt of round up for every gallon of water. This should kill your weeds, for most precise mixing instructions check the bottle label.
Thanks.
Jul 28, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
How do you use roundup to kill a tree stump?
Hello, I am a grower and licensed pesticides applicator (40 yrs exp).
Roundup lost the trade mark years ago,"glyphosphate" which is now marketed (cheaper) under many other names,
Will kill a live tree if sprayed on the leaves! Also will damage young trees if you just get over spray on the trunk while spraying weeds.
Also, kills grass as well as broadleaved plants.
To kill a tree you would need to spray the leaves, then wait at least a month before cutting the tree down. I have successfully killed a few stumps by spraying the live suckers.
Be especially careful of spray drift as the finer the droplets are the more effective the chemical is. Read the label!
Aug 29, 2010 | Roundup "" Weed & Grass Killer
I will be applying Roundup to a large section of my lawn to kill a bermudagrass infestation. Will the Roundup work better on longer grass or a freshly mowed lawn?
Round up will work on any grass...I prefer to mix it a bit stronger when I know I am trying to kill grass... but yes it works... ask my daughter who wanted to help and spray the weeds for me and then decides to play around in the yard writing her name....:-)
It can take a week for a full killl though...
heatman101
Aug 12, 2010 | Roundup "" Weed & Grass Killer
How do i mix roundup concentrate plus
Roundup Concentrate Plus is the least concentrated mixable product Monsanto offers. Annual and perennial weeds can be controlled with a mixture of 6 fluid ounces of Roundup (12 tablespoons) per gallon of water. Small weed seedlings can be killed with half this strength: 3 ounces per gallon. When using Roundup Super Concentrate, mix 2.5 ounces (5 tbsp.) with a gallon of water to control most weeds and a half-strength solution for small weeds. Roundup Pro Concentrate is the strongest solution available. Spray a mixture of 2 ounces (4 tbsp.) on weeds and half that amount of concentrate on emerging plants. Since Roundup doesn't discriminate between weeds and other plants, use the least amount of herbicide possible to protect desirable vegetation.
May 25, 2010 | Roundup ScottsRoundUp 0394560 PT...
Danger of roundup applications around tree and bush plantings
Hi , I would be very carefull around good plants. Roundup will kill almost any plant, including aquatic plants, so you want to be sure to avoid spray drift onto other plants or into water.
May 06, 2010 | Roundup "" Weed & Grass Killer
How to mix roundup to kill weeds
May 02, 2010 | Roundup ScottsRoundUp 0394560 PT...
Agriculture Application of Round-up
Very important to buffer the pH of the water at pH 5. Then add Roundup /Glyphosate 360 at a 2% for grass weeds and 3% for brush weeds. Ensure that the grass is dry when treating and no rain is expected within 6 hours. Please take care with roundup as it is poison .
Apr 22, 2010 | Roundup "" Weed & Grass Killer
Quantity of Roundup weed killer to spray 140 acreas of crop land
This 2.0% glyphosate is ready to apply at a rate of 3-10 gallons per acre That's 420-1400 gallons per 140 acres. Some weeds need a higher concentration than 2%. Most farmers buy 41% glyphosate concentrate, determine the number gallons of spray mixture their equipment will deliver, determine the concentration of glyphosate they need and mix the concentrate with water accordingly.
Apr 01, 2010 | Roundup "" Weed & Grass Killer
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
