Question about Optoma EP761 Projector
Getting little white dots appearing on screen.
These tiny white dots I thought were dirt on lense, but after cleaning they are still there. Every couple of weeks, a few more pop up. Any ideas?
Little white dots in tv modle# wdt657 what are they how can i get them off
Your TV is DLP projection TV. DLP is Digital Light Processing. Digitally processed light coming out of DMD (Digital Micro mirror Device) is projected on the TV screen. This DMD is made of thousands of tiny mirrors & the size is about 0.7 inch. These mirrors are fixed with tiny hinges for its movement. They reflect light as per processed signal. DLP is invented by Texas Instruments. When there are dots on the screen, that means the tiny mirrors representing the dots are stuck in its position. If the dots are few & the viewing is bearable, just leave as it is. If the dots are more than bearable then you will have replace the DMD chip which is quite costly.
Sep 25, 2011 | Mitsubishi WD-Y657 65" HDTV
Help! Our Optoma DLP projector is about 6 months old. It started with one white dot on the screen. It has since mulitplied to be at least 20 white dots all over the screen and now some black dots are...
Your DMD chip or DMD driver need to be checked. The most likely it is DMD. If your projector is new with one year warranty, send it to the company for repairs. They will replace it at no cost.
sonsunny
Jun 12, 2011 | Optoma EX536 DLP Projector
It has very tiny white dots (only a few...) on the lenses. They seem not to be removed when I clean outside with a soft tissue. I do not see anything on the pictures. I am wondering if this happened when...
Hello - the dots could also be on the inner side of the lens , have you tried cleaning both sides.
I had a similar problem once while shooting waves and tiny droplets of salt water were hitting the camera.
Only damp soft tissues on the outside of the lens, any thing on the inside of the lens is a shop job. Ray
Feb 27, 2011 | Nikon D3100 Digital Camera
Hi i am having problems with the projector it was going well for the last year that i have it but up to a week ago i have been getting tiny white dots appearing on the screen from the projector. i have...
I noticed you have a DLP projector. I have a Optoma EzPro 756 which is also a DLP projector.
I notice white "blobs" on the screen when there is a black screen. It is caused by dust getting into the optical block not the lense. If you are comfortable with opening up the projector, you could gently blow out the optical area with compressed air, GENTLY so you don't dislodge any components, and see if that helps. I seems to be a common problem with DLP projectors a few years old. If there are sharp focused dots on the screen then most likely, it could be some pixels starting to go bad like dead pixels on a computer screen. That problem is pretty much irreversible.
Hope this helps,
Feb 20, 2011 | Acer X 1130 3D DLP Projector
White dot on my samsung DLP 42" screen
white dot is from a failure in the dlp chip. it controls 1000s of tiny mirrors which help make up your pix, when the mirrors get stuck a white dot appears. over time more will pop up. Probably in the $300-$500 range to have someone repair.
Jul 04, 2010 | Samsung Televison & Video
Why the white spots on my tv screen. started with one, then two and now up to 9
the reason this is happening and the problem is getting worst is because the DMD board is starting to go bad some of the micro mirrors are getting stuck on the on or off position and the problem is only going to get worst if you want to fix this problem you need to replace the light engine here is a link that will teach you about this projection works
http://www.howstuffworks.com/dlp2.htm
Jun 12, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Hi there,there is a ring of blue dots
clean the lense of your projector, dirt or moist of water may be possible reason
Feb 18, 2010 | Canon LV-S3 Multimedia Projector
Sony a100 distortion dots - Im getting several
If these are single pixels on the LCD screen, they are normal. From pg. 8 of the user's guide:
"The LCD monitor is manufactured using extremely high-precision technology so over 99.99% of the pixels are operational for effective use. However, there may be some tiny black points and/or bright points (white, red, blue or green in color) that constantly appear on the LCD monitor. These points are normal in the manufacturing process and do not affect the images in any way. "
This may also be helpful.
"images may trail across the LCD monitor in a cold location. This is not a malfunction. When turning on the camera in a cold location, the LCD monitor may become temporarily dark. "
May 03, 2009 | Sony A100 Digital SLR & 18-70 Lens Kit...
Kolin PT-501 LCD/LCOS HDTV, rear projection TV
Well i really do not know what that is but i do have a thought it could be a bad connector and if you want i have the same tv for sale for $300 shipped just for parts the problem with my pt501 was the screen turned colors but the lamp is in excellent shape and so is the lcos screen the ownly thing that does not work is the main board (ciruit board) i will send you the hole thing for just 300$ shipped if you'd like email me back giovani.rivera@yahoo.com
Jun 29, 2008 | Olevia Kolin DLT2711M 27 in. LCD...
Red dots on screen of
Typically this is an indication of dirt in the optical path. Try blowing out the area using compressed air. Also, make sure that the lens is clean. Use a cloth and solution made specifically for cleaning lenses.
Dan
May 05, 2008 | Televison & Video
Optoma EP761 Projector Logo
32 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
