42ld450-ua tv does not turn on , red lifgt on tv blinks
  • 336 Answers
SOURCE: My Tv made pop sound and now the red lifgt blinks
Hi,it sounds like you lamp went bad.If your tv is between 2-4 yrs it will be the lamp that needs replacement,The red indicator is indicating there's an issue with the lamp.Try this websites discount-merchant or, discounttvlamps, They carry the original brands.
Posted on Oct 05, 2009
eagle338
  • 4889 Answers
SOURCE: My LG HD TV Model
Please let me know how many times it blinks in between each pause so that I can tell you what the problem is.
Sai.
Posted on Dec 12, 2010
gopakumarg43
  • 75571 Answers
SOURCE: Have LG 42LD450-UA lcd tv that has no picture or sound. When plugged in the red power light comes on but when it's turned on the red light flashes very slowly continuously. Thanks in advance
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Posted on Nov 14, 2015
AJIN G
  • 6694 Answers
SOURCE: I need a schematic diagram for an LG 42 TV Service Code 42LD450-UA.CUSWLO
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Posted on Sep 17, 2016
  • 44926 Answers
SOURCE: After turning on LG model 47lh40-ua the TV blinks 3 times then turns off
Open internal fuse or power supply failure
Posted on Jan 10, 2017
I have a LG TV model 60LN5400-UA. I attempted to turn on my TV and the red light on the bottom blinked red but there was no picture. Your help would be greatly appreciated.
hi the tv is stuck in standby, it's a power supply fault, capacitors could cause this also a mainboard fault could cause this, thanks
shaun
Mar 30, 2017 | LG Televison & Video
Sep 17, 2016 | LG Televison & Video
Nov 13, 2015 | LG Televison & Video
My 42 in lg tv model number 42ld450-ua went off
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Sep 25, 2014 | Televison & Video
LG tv is in protection mode, I guess. Can get it to work sometimes for a few hours, but always turns itself off and power light blinks red after that
Hello People, I have today took the back off from my LG 42LD450 TV. I had problem like screen goes from picture to like white or green lines. The tv has no functions then auto shuts off with red blinking light. I was concern and I notice my main power supply cord. The several gray little cords bind together are badly chewed. plus a black cord that is chew too. a more thicker cord. I indicated that if I replace these wires, perhaps my tv will start working correctly.. Yes we have little mice issue and this tv sucks cause there a small space were the stand goes at. can't close it either. Here's some pictures I took. sorry if blur. battery was low at the time. couldn't get flash or phone to focus.
20170522_212905 copy-n1wp1d2yjqbukp0mguo5hfo5-3-5.jpg Anyways I would try to look at these wires if you are having same issue.. I found the gray wire only cost $25. So I'm guessing the larger wire be around $25 or $30+ I hope this helps anyone that having this issue. Good luck and hopefully good luck to me.
Jun 11, 2012 | LG 42LD450 42 in TV
I have a LG 42LD450 LCD TV. Problem is I can't power on the unit. I use the remote control to power on the TV but the red power light turn on and then dim and then on again. Thanks
you have a problem in the in built SMPS which can not provides sufficient power to your LCD and you got problem replace your SMPS or repair it , ithink replacing is best idea for it
Feb 16, 2011 | LG 42LC2D 42 in. LCD HDTV
When I power on the TV, the blue light comes on then a red blinking light comes on. The TV has no sound or picture.
You need to troubleshoot it to narrow down the problem. It may be in the shutdown/restart mode because it senses shorted circuits, or it may have failed power supply.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 13, 2011 | LG 42LD450 42 in TV
Lg 42ld450 is not turning on. It keeps flashing "red" in what appears to be the power saving mode. Any ideas??
The power board or power supply could be the likely cause of the problem. Have that checked out.
Jun 29, 2010 | LG 42LD450 42 in TV
My Tv made pop sound and now the red lifgt blinks 4 times.. And no picture. any idea what I need to do and the cost?
Oct 05, 2009 | Sony KP-53S70 53" Rear Projection...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
