Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
OPC and Power green lights blink twice, tv will not turn on.
Hi, I have a Sharp Aquos 52 in. TV model LC-52D78UN, I unplugged it to rearrange some wires from the outlet and when I plugged it back in the Power and OPC lights flash twice continuously but the TV will not turn on. If I try and turn it on, the Power light stays on for like 1 second and then it resumes flashing twice with the OPC light. Any clue as to how to fix it?
    Top Expert:
  • Sharp Master
  • 12,223 Answers
Follow this instruction and fix it. God bless you
    • 1
      Press the power button on the TV and not the remote control. It is possible the remote control's batteries are dead. If the TV does turn on, you know you need to replace the remote's batteries.
    • 2
      Disconnect the power cable from the TV, then insert it into a different electrical outlet. On occasion outlets are damaged, and do not provide a power current. If this is the case, changing the electrical outlet connection corrects the problem.
    • Sponsored Links
    • 3
      Switch the television's input to a different connection. It may be possible you have the wrong input selected, causing the TV to give off a black screen.
    • 4
      Connect a different source device (such as a DVD player or cable receiver) to the television. If the source equipment is damaged, you will not receive an image from the hardware. If the TV still does not display an image, there is an electrical shortage in the interior of the TV. To see if there is any way to fix this issue, you need to take it into a local TV repair shop.
Read more: http://www.ehow.com/how_7308433_flat-screen-tv-won_t-turn.html#ixzz2ZROWyhSB
Posted on Jul 18, 2013
3 Suggested Answers
dsacco86
  • 1077 Answers
SOURCE: Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Posted on Jun 03, 2009
Zenodilodon
  • 145 Answers
SOURCE: 52 sharp aquos tv wont turn on. Hear click of tv
This tends to be the result of an electrolytic capacitor somewhere, either on the main board or the power supply board bursting due to overheating. In this case you can pull off the back paneling and review the boards over to make sure all the capacitors are in excellent condition. After identifying a bad capacitor you can buy one from an electronics store in the area or a reputable online source. To replace it this will require soldering. Look for a capacitor with the same uF, the voltage can be the same or higher. Make sure all the power is out of the system before servicing, also make sure to note capacitor polarity observing the negative indicator line on the side. If your not sure this can be done at home I would recommend taking it in to a servicing shop. If you do not know what a capacitor looks like do a google image seatch for both examples of a good and bad copacitor. I honestly hope it's something much simpler, I hope this helped and good luck.
Posted on Mar 03, 2010
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Power and OPC Lights flash twice and TV won't power on.
see this steps and fix it. God bless you
    • 1
    • 2
    • Sponsored Links
    • 3
    • 4
Jul 18, 2013 | Televison & Video
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
The power light is blinking and the tv wont turn on
I have two 46" Sharp Aquos tvs,so i know this tv model well.Tv have Power and OPC LED lights flashes?Yes.Tries tv unplug,replug it back like about an hour later.The tv should be working again.This problems happen to Sharp tv alots,later on,should it happen again,just tries push the power switch on the remote again and wait the backlight will light up and tv will work again,some it will go back to Power and OPC LED lights flashes again,just push power switch again and wait,sometimes,u have to do this three or four tines to make the tv Tuner signal board to take to make the tv to work again.If u have to pushes power switches 10 or 11 times and wait and Power and OPC LED flashes lights again,it time to replace the tv Tuner signal board,that the board,where that take the tv incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Jan 29, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV won't turn on
the first thing that you need to do is to open the back cover of your tv.Go to the power supply section it is separate board where the power cord is connected.Using a multitester,plug in the power cord and measure for the output supply.see if the 5vdc ,12vdc and 24vdc are present..if one of this output is missing,replace the power supply board But if the output voltage are complete,replace the inverter board,It is a board that supplies the high voltage to the backlights of your monitor/screen....You can also try to reset the system of your tv by pressing the the small switch mounted on the main board press it twice while the power is on...tnx and good luck!
please vote for my help!
Jun 04, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Sharp 52" Aquos LCD Will Not Turn ON-Blinking LEDs
I had a similar problem. Fleeting video, then audio only for few seconds and then nothing except the green power LED blinking on and off.
I changed the power inverter board, backlight inverter boards and power supply board but still the problem is not gone.
Just 18 month old TV and out of warranty.
Jun 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC-37D4U, the monitor doesn't turn on
It is hard to say without first looking at it.
Jun 28, 2017 | Sharp Aquos LC-32D40U Television
No picture, but power is on...
How many times does the POWER led blink per sec? (dont worry about the OPC)
2x = power supply (not as expensive to fix)
3x = Main board (expensive to fix)
Oct 20, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
240 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
