How do i hook up my Panasonic SC-AKX73 2.1 Channel 850W System w/ 3-Way Speakers to my desktop computer
I purchased this system for my son for his alienware computer. I know now it doesn't have magnetic shielding, if I distance it from the pc, will i be able to hook it up or is it not compatible w/ a desktop computer?
    Genius:
  • 1,479 Answers
The easiest way to hook it up is with a lead with a 3.5mm speaker plug on one end and red/white rca (or whatever) on the other end to input into the panasonic.
the dell alienware probably has 5.1 or 7.1 audio out so you could use a lead with matching wires for the panasonic.
Posted on Jul 19, 2013
tech48
  • 624 Answers
SOURCE: Panasonic home theater system pt760
Make sure you have put the transmitter for the wirless speaker in the slot on the back of the reciever, it is a slim white device that is about 3 to 5 inches long?? and maybe half an inch thick. and make sure it is put in the right way.
Then make sure the wireless speaker is plugged in to the wall outlet.
If this does not work for you it may require being taken in to an authorized panasonic service center. when one part of the wireless system fails (transmitter or reciever) they both must be replaced. they are not interchangable from one panasonic to another.
They have a code in each unit that lets the wireless speaker that came with it only work with the reciever it was sold with.
I have even seen times where the store that sells them swapped the transmitters of two units and then they had two customers very mad at them because the wireless speakers did not work for either person.
Let me know if I can be of any more help.
Posted on Jun 19, 2008
daniel719
  • 240 Answers
SOURCE: Adding another external device to the sound system
yes you are right you can pick up an arc aux swich box from radio shack.
will do your job just fine.
thanks
and pleas rate this, if is of help to you.
Posted on Jan 13, 2009
SOURCE: wireless pananaonic sound sytem
http://www.pasctraining.panasonic.com/pass/elearn/Document_Downloads.htm
Try looking at the training document for your system. The answer might be there.
Moon
Posted on Jan 25, 2009
glenmann62
  • 91 Answers
SOURCE: My Panasonic SC-PT760 system just doesn't sound right....
it definetly sounds like their is a set-up issue or a grounding issue , refer to your user manual for reference to check your wires ,also bad buzzing sound also comes from cheap rca cables that you might be using for components to your system ,also sometimes the end jacks of the rca get worn out and don,t provide good conductivity , auxillary inputs should be used for playstations or x boxes and not for anything else , hopefully this was helpful, sincerely Glenn
Posted on Mar 03, 2009
efs_perpends
  • 1996 Answers
SOURCE: How to connect pc to Panasonic SC-HT730 home theater system?
From what I can tell from your manual, you do not have auxiliary audio inputs on your system. You can, however, use the TV audio input for sound from your laptop. You will need to purchase an adapter cable that goes from male 1/8" stereo mini plug on one end (your computer jack) to a split (Y) male rca type jack (two connectors for R&L inputs on system. Then you'll need some length of 1/8" male to female miniplug extension cable. You can use the miniplug speaker jack on your laptop as an output.
Of course, if you're using the TV audio inputs, and don't want to unplug them to plug your laptop in, you'll need another pair of splitter cables for those rca jacks on your system so you can plug two different pairs of input devices into them, but I'd try to avoid this scenario if possible.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 16, 2009
My panasonic SA-PM193 died after 3 hours of playing music after i added a 4 inch subwoofer and 2 small speakers
... whatever that tells us.
If you severely modified the load to the amp by running more speakers than it's designed to drive and/or at a lower impedence, well, are you surprised?
It only pushes around 25 watts/channel AT TEN PERCENT DISTORTION through a carefully and unrealistically limited bandwidth specification.
http://audio.manualsonline.com/manuals/mfg/panasonic/sc-pm193_1.html?idRes=699618
Running 'clean' (under, say, 1% distortion throughout th 20-20000hz range) it probably only pushes 10 watts/channel. Once an amp is taxed beyond it's clean abilities it will start to distort, badly, and distortion will kill speakers and maybe the amp itself.
Sep 23, 2011 | Panasonic SC-PM193 Micro SystemMicro Audio...
I CAN'T GET THE REAR SPEAKERS FOR MY PANASONIC SCHT720. MY TV'S ON I HAVE RCA RUNNING FROM MY AUDIO OUT TO MY TV IN ON THE RECEIVER AND ALL SPEAKERS ARE PLUGGER IN
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Panasonic-SC-HT720-Home-Theater-Systems-manual/id/356ci960/t/2/
In your scenario the TV has nothing to do with the ANY audio you hear from your speakers. It's an audio output, not a sound source as you have it hooked up. RCA cables wouldn't carry multichannel audio anyway.
Let
Mar 01, 2011 | Panasonic SC-HT720 System
Just purchased SBHS100AE-K rear speakers to connect to my SC-BT100. I want to connect them wired rather than purchase the wireless transmitter, but I can't figure out how to connect the wired rear speakers...
This unit is not as flexible as traditional receivers are as far as speakers are concerned. Speakers are labeled and *must* be connected to the correct speaker terminals.
Upon reading the manual - it is quite apparent that the only provisions for rear surround speaker connections is <i>only</i> via the optional wireless transmitter / receiver hardware. The optional digital transmitter is connected via a proprietary plug on the rear of the SC-BT100. The optional receiver amplifies the received signal and passes it to the connected surround speakers. I would bet that there are no provisions for amplifying a surround L and R speaker channel inside the SC-BT100, and that it only provides a low level (like a "tape out") or un-amplified signal to the transmitter plug. Even if you were to manage to get the surround speaker connections made up there - you would not be able to hear anything from them - as there is no amplifier. The amplifier is contained in the wireless receiver, and is largely why it requires a connection to house current.
Unfortunately, I doubt you'll find a way to listen the surround channel audio from the SC-BT100 without the optional transmitter / receiver and the integrated amplifier.
You can review the manual like I did here:
http://service.us.panasonic.com/OPERMANPDF/SCBT100.PDF
I hope this answered your question.
Jun 11, 2010 | Panasonic SC-BT100 Theater System
Can I add this to the 5.1 home theater surround system?
Hook RCA audio wire/ cable between home theater line out terminals and line in pins of Panasonic shelf system to get sound in its speakers.
Aug 28, 2009 | Panasonic SC-AK78 CD Shelf System
thanks
Jan 13, 2009 | Panasonic SC-PT660 Theater System
Can't get the surround sound to play the rear speakers and small front speaker
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
Aug 04, 2008 | Panasonic Home Theater System System
Hook up
well u cannot hook almost any devices with the SC-HT500.
I have this homecinema system for 5 years now, and i had to buy another stand alone DivX player to hook it up, but can't get the sound in dolby from the standalone player since the panasonic SC-HT500 has only 2 analog stereo RCA ports (audio in) in the back and a scart (A/V out) and component video (Video out).
At that time it was a very good system, but since i have bought a Full HD LCD tv with 1080p capabilities, I realised that my home cinema system i.e the Panasonic SC-HT500 is kind of useless, in the sense that you cannot even change the player for another one since the whole spaker and power connections are made trhough a special cable from the subwoofer. :(
best solution is that put the system back in a corner and get a new system which is not an all-in-one system. Preferrable get home cinema systems that come with a receiver, separate dvd player and speakers and subwoofer hooked to the receiver.
you asked how to hook these devices to your tv,, well the panasonic dvd recorder is better if you connect it via HDMI cable if you can. In the other case, connecting them with a scart cable would be another solution.
Dec 02, 2007 | Panasonic SC-HT500 System
Panasonic SC-HT920
One option is to set the cross over to the sub so it knows when to send the low frequency to the sub and not the front speakers. 120 is a good setting. This can be done either via a know on the sub woofer or the setup screen of the main unit.
good luck
smeags
Sep 07, 2007 | Panasonic SC-HT920 System
275 people viewed this question
 Grubhead
Grubhead
