Question about Dewalt DXPW3835 - 3800 PSI Professional Gas-Cold Water Pressure
I recently purchased a Dewalt DXPW 3835 Pressure Washer from Home Depot.... After 4 hours use I no longer get any pressure. After depressing the trigger, I get a second of pressure and then it just dies. I called DeWalt and they couldn't help and to take it to the Warranty Shop. They informed that they wouldn't be able to look at for 2 weeks so I took it back to HD and got a new one and this one does the same thing. I'm pretty sure it's probably a pretty quick fix but no one seems able to tell me on the phone how to do it. (and there is not any info in the manual pertaining to this) Any advice.
  • 1383 Answers
SOURCE: I have a dewalt 3750
I worked at a tool rental center while attending college and learned many tips and tricks about Dewalt and other brand pressure sprayers. Your machine probably has a 13 hp honda and has max pressure of about 3500 to 3700 psi. Most of the problems that customers had were engine related due to severe working conditions including totally wet engine /plug, wet air filter, and or other problems that were easy to remedy. We would set the pressure regulator to minimum pressure and explained to the customer how to increase the pressure as necessary but only after the engine was completely warmed-up to running temp to prevent engine stall. Your machine has a throttle lever between the tank and carb that should be set to max if you are going to set pressure at or neer max range. Most cleaning jobs do not need much pressure. Use lowest pressure to get the job done. Your engine developes around 13hp at about 3600rpm. If you want to maximize the life of you sprayer, then use your machine at about 70% of capacity or about 2000 to 2500 range that will allow you to run your engine slower increasing lifespan. Your sprayer is likely rated at 4 gallons per minute so make sure that the tip is that capacity. The tip has the size stamped which would show the fan degree and flow in gpm. The wrong tip, say a 3.5 gpm will strain the engine to point of stop because the smaller tip increases pressure. Most engine stall is due to high pressure setting on new machines. Lower pressure when warming-up machine and use max pressure rarely when necessary to max life. Please email for other information/questions or simple tests to determine faulty parts, good luck.
Posted on Jan 30, 2009
  • 942 Answers
SOURCE: My DeWalt Gas Pressure Washer Model DPD3100 is
Hi
Just try the following steps
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Good luck
Regards
PCmania
Posted on Jul 05, 2009
harlan301
  • 205 Answers
SOURCE: I have purchased a Dewalt 3800 PSi cold water
check to see how hot the water can be, ti should be on the unit or in your book. also your amps should be no less than 15amp, long core can over heat the motor. if your unit can't handle hot water it will melt the valves
Posted on Oct 12, 2009
LandaNW
  • 45 Answers
SOURCE: Hi, I have a Dewalt pressure
There are two common issues that will cause what you are describing. What you need to do is run the machine until it dies as you are describing. Then pull the spark plug and check for spark. If you do not have spark you have a failing stater. It is very common for this problem to only show itself after the machine warms up. If you find that you do still have spark try removing the gas cap and restarting. It is also common for a vacuum lock to occur due to the seal on the gas tank cap. In most cases one of these will be your issue. If not feel free to contact me at 800.247.8103 and I will help you to troubleshoot the issue further.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Posted on Mar 10, 2011
SOURCE: After running my dewalt pressure washer for a few
put gas!
Posted on Jul 20, 2012
The machine shuts off when you let off the trigger. Seems like pressure must build up and it shuts off.
Your unloader bypass system has failed. Several pumps were used on this model, see link for parts breakdowns.
Sep 28, 2014 | Dewalt Pressure Washer - DXPW3025
Husky 2600 pressure washer with honda gcv160 engine. engine won't run with choke off.
I bought mine at Home Depot, the pump failed after about 8 hours of use then Home Depot agreed to replace it now it failed again after aabout 10 hours of use. This is a piece of crap and Home Depot should be ashamed for selling this junk. I am sure they are in with Husky and making big dollars on a crappy product. My machine is like brand new just will not work. Now the carb has to be replaced only after less than 20 hours.
JUNK Home Depot
Nov 23, 2011 | Garden
The drain plug on my Porter Cable pancake compressor leaks so badly that it no longer build pressure. The compressor is just a little over 1 year old and I have always drained the compressor after each...
Yes...the drain valve on the bottom of the tank is just a standard 1/4 Drain Pedcock that you can purchase at most hardware store.
You can also find these in the hardware section of Lowes or Home Depot where they sell the Air Compressors.
Oct 24, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Assembly
HI your machine would have been delivered with a blanking plug in the pump. You will need to remove this and fit a vented pump or your pump will build up too much pressure inside.
Apr 13, 2010 | Comet BXD2527 Pressure Washer Pump
In originally how is the warranty .
DEWALT Pressure washers warranty is as follows:
DEWALT pressure washers model year 2007 and prior (yellow frames) have a 2 year engine warranty, 1 year all other limited warranty.
DEWALT pressure washers model year 2008 (black frames) have a 2 year all components covered warranty.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 19, 2010 | Dewalt 3700 Pressure Washer
Need to know type of oil DeWalt pressure washer 3800psi
Pump is specialty pump oil available at Home Depot. Engine is 10W 30 motor oil.
Mar 16, 2010 | Dewalt 3800 PSI Pressure Washer
Power washer not starting what type of oil to use dpd3100
10 w 30 for engine
10 w 30 and specify for [PUMP OIL]
ANY AUTO STORE
THANKS AND PLEASE RATE JJ505
Apr 11, 2009 | Dewalt DPD3100 Gas Pressure Washer
Dewalt DXPW3835 - 3800 PSI Professional Gas-Cold Water Pressure Logo
124 people viewed this question
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
