i was answering someone with a whirlpool fridge and i thought yours was also a whirlpool,i don't work on lg machines but any other fridge i worked on usually if you chnage out the start device and the compressor just clicks the compressor is bad bad maybe there's a board on this that i don't know about but it sounds like you have a bad compressor.you can write back and ask your question again and hopefully someone that knows about lg machines can help you.i was answering someone with a whirlpool fridge and i thought yours was also a whirlpool,i don't work on lg machines but any other fridge i worked on usually if you chnage out the start device and the compressor just clicks the compressor is bad bad maybe there's a board on this that i don't know about but it sounds like you have a bad compressor.you can write back and ask your question again and hopefully someone that knows about lg machines can help you.
You can't post conmments that contain an email address.
Automobile starter repair shops have a test set-up and can test any starter with it. If the solenoid is bad, they can tell you. The most common fault is a clicking sound when not starting, but that isn't the only fault. A common fault is a loose ground wire or short, but since your starts with a pull, then that appears unlikely in your case or it wouldn't start at all. Good luck.
It IS true that starters are finicky beasts. They require fairly precise alignment, which sometimes includes the use of spacing shims. The starter must freely engage and disengage with the flywheel to start the engine, and a slight misalignment can prevent this process. You probably don't require a factory starter (OEM), but you should try adding one shim at a time until the starter engagement is consistently working. Good luck.
By some strange reason it happens also if the instrument panel dim light is all way up and you have to keep your dome light switch off or it will light even if all doors are shut. I put the dim light switch into normal position and my remote starter resumed its function! Thanks to F150 forum, I found this remedy there: 2010 REMOTE START
your starter capastor has gone bad or got diconnected it`s look`s like round cylender 2 inch by 4 inch dimention`s or it could be an internal (inside the motor) depending how new the motor is
Switching DDR cards solved the problem. I was getting long beeps every 2 seconds. No short beeps. Just one long beep every 2 seconds. Thanks Josh Whitehead.
Sounds like you have bad solder joints on the vertical ic which should be numbered IC501 on the board.also there are capastors that coud be going bad but i would look for bad solder joints on ic frist.
The capastors numbers on board are C502 / C516 also need to check R 483 which is a resistor.
resolder the ic if you know how to solder. That is a comon problem a lot of tvs out there have. The only thing is the tv has high voltage on it even if it is unpluged from the wall. Some of the capastors hold there voltage for a long time. Be sure and unplug tv before you try anything if you are going to do it yourself and stay away from the capastor in the AC line should be marked 200 V or moor.
sounds like relay chater might be a bad capastor out of spec near the relay i dont have the spec on this tv but some sanyo tv had that kind of sound and it is a bad capastor like 470u at 25 volts in them. Look for a bulg on the top of caps around relay area. Board marking are like c 601 this is not the right number for your set just to let you know sort of what you are looking for the c standing for capastor. Be sure to unplug tv before youtake it apart there is high voltage in the set even after you unplug it.the cap shuld be black or blue with a silver flat top even if they look good still can be bad cant tell untell you test them on a machine.
