1997 Chevrolet Malibu Logo
Posted on Jan 15, 2018
97 Malibu. V6-3100. Starter turns engine, but car
'97 Malibu. V6-3100. Starter turns engine, but car will not start. Don't hear fuel pump. Instrument cluster/odometer do not light up (no indications) when key is turned on. When starter is disengaged, the motor sounds like it tries to run very briefly (<1 sec). Radio, interior/exterior lights work.
Amanda Filsinger
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 27, 2023
Amanda Filsinger
Contributor
Level 1:
Answers
Questions
0
Helped
424
Points
6
My 97 malibu sometimes randomly goes into Theft mode. Is the Theft light blinking or on? put your key in the "ON" position and sit and wait 10 to 15 minutes (actually wait that long, don't do anything else) when the theft light turns off start your engine.
Jeff Zdroik
Level 1:
Habit-Forming:
New Friend:
  • Contributor 26 Answers
  • Posted on Jan 15, 2018
Jeff Zdroik
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
26
Questions
0
Helped
19403
Points
88
I think you may have answered your own question. I would check to see if the fuel pump is turning on when you turn the key on to the run position. You should hear a buzz sound coming from the gas tank. I would start there.
5 Related Answers
psds4
pat murray
  • 293 Answers
  • Posted on Sep 22, 2008
SOURCE: Instrument Cluster Replacement
it will register the car it came out of and you can not change the milage you would nrrd to send it out
Anonymous
  • 12 Answers
  • Posted on Feb 16, 2009
SOURCE: 93 Chevy Blazer S-10 4.3L F.I.
if this is the vortec engine you may want to check to confirm that the injector pot is working. The injector pot is located under the air intake manifold (top half only) & PLEASE BE SURE TO DISCONECT BATTERY FIRST. if you unbolt the top half of the intake manifold you will find the main injector pot otherwise known as the SPIDER. This part does have a history of failing and can be very costly to replace if you purchase it new. most junk yards should be able to find one for you.
Anonymous
  • 19 Answers
  • Posted on Apr 23, 2009
SOURCE: fuel gauge quit working
check grounds wires
honeymokey
honeymokey
  • 3113 Answers
  • Posted on Jul 08, 2009
SOURCE: light showing odometer and what gear transmission
The cluster will have to be sent out for repairs or exchange by a dealer or see Model Electronics.
ourhowse
Dar
  • 2007 Answers
  • Posted on Jul 20, 2009
SOURCE: how can i fix a clogged fuel pump on a 2001 chevy
Have you changed the fuel filter? Did it die while driving, or just wouldn't start? Don't use starting fluid on a gas engine! It will cause a lot more problems than it solves. Ether, starting fluid is made for diesel engines... not gas, not ever. If it won't start, it isn't lacking ether. It's lacking gas, air or spark.
1helpful
1998 Chevrolet Malibu 54k miles - replaced fuel pump assembly & now some dash warning lights and clock stay on. Any ideas?
Replacing a fuel pump has nothing to do with instrument cluster lights or the clock staying on. Unless you shorted wires , did you disconnect the negative battery cable before hand ?
The body control module (BCM) performs the following functions:
• A/C compressor request
• A/C cooling fan
• Exterior and interior lighting control
- Daytime running lights (DRL)
- Automatic lighting control
- Fog lamps
- Interior lighting
• Battery rundown
• Chime
• Gauge control
• Instrument cluster indicator control
• Fuel gauge control
• Temperature gauge control
• Theft deterrent
Interpreting all of the driver warnings sent by the control modules on the class 2 serial data line
Sending the information to the instrument cluster in the form of a SPI serial data bus message
The following list of messages are sent by the BCM to the instrument cluster:
• Fuel gauge position
• Temperature gauge position
• Oil pressure
• Low engine coolant
• Check oil
• Volts
• ABS
• High beam
• Low fuel
• High temperature
• Washer fluid level low
• CRUISE
• BRAKE
• SERVICE VEHICLE SOON
• Door ajar
• Seat belt
• THEFT SYSTEM
• PRNDL
Check the fuel level sensor wires , the fuel level sensor is a input to the BCM .
The odometer is not working on my 1999 navigator. It just says 0. What could be the problem?
Odometer The instrument cluster receives odometer rolling count status from the PCM-engine computer and stores the mileage in non-volatile memory (NVM). When the instrument cluster fails to receive the odometer rolling count status for more than two seconds, the odometer display will show dashes.
HEC Dealer Test Mode
To enter the HEC Dealer Test Mode, depress and hold the instrument cluster SELECT/RESET button and then turn the ignition switch to the RUN position. Continue pressing the SELECT/RESET button (5 seconds) until tESt is displayed in the odometer. The SELECT/RESET button must be released within 3 seconds of the odometer displaying tESt to begin the dealer test mode. Depress the SELECT/RESET button to advance through the following steps until dtc is displayed. Depressing the SELECT/RESET button will display any continuous DTCs stored before proceeding to the next step.
All segments illuminated Illuminates all odometer segments. If any odometer segment is inoperative, INSTALL a new instrument cluster; REFER to Instrument Cluster .
Odometer Display Description GAGE Activates gauge sweep of all gauges, then displays present gauge values. Also carries out the checksum tests on ROM and EE. If the gauge sweep is inoperative, INSTALL a new instrument cluster; REFER to Instrument Cluster . All segments illuminated Illuminates all odometer segments. If any odometer segment is inoperative, INSTALL a new instrument cluster; REFER to Instrument Cluster . bulb Illuminates all micro-controlled lamps and LEDs (low oil pressure/high coolant temperature, low fuel, service engine soon, brake, low range). INSTALL a new bulb or LED as necessary. r Returns to normal operation of all micro-controlled lamps and LEDs and displays hexadecimal value for ROM level (used when requesting assistance from the hotline). If alternating flashes of FAIL and ROM level are displayed, INSTALL a new instrument cluster; refer to Instrument Cluster . EE Displays hexadecimal value for EE level (used when requesting assistance from the hotline). If alternating flashes of FAIL and EE level are displayed, INSTALL a new instrument cluster; refer to Instrument Cluster . dt Displays hexadecimal coding of final manufacturing test date (used when requesting assistance from the hotline). dtc Displays continuous DTCs. Pressing the SELECT/RESET button will display any DTCs stored before proceeding to the next step. enG Displays the English speed in mph. Speedometer will indicate present speed within tolerances. Display will show 0 if input is not received, if input received is invalid for one second or more, or if speed is 0. m Displays the English speed data (mph) received from the PCM via SCP Network. Displays the metric speed in kph. Speedometer will indicate present speed within tolerances. Display will show 0 if input is not received, if input received is invalid for one second or more, or if speed is 0. tAc Displays the tachometer data received from the PCM via the SCP Network. Tachometer will indicate present speed within tolerances. Display will show 0 if input is not received, if input received is invalid for one second or more, or if engine rpm is 0. FUEL Displays the actual A/D fuel level. The fuel gauge will display a filtered fuel level value. This filter will keep the pointer from moving suddenly or erratically. If the value displayed is between 0 and 20, the circuit is shorted. GO to Pinpoint Test D .
  • 255=open send +/-0
  • 232=Full stop +/-10
  • 215=Full mark +/-10
  • 178=3/4 mark +/-8
  • 138=1/2 mark +/-7
  • 93=1/4 mark +/-5
  • 41=E mark +/-4
  • 54="LOW FUEL" (0-59)
  • 0-18=short (0-20 max.)
OIL Displays the code (0-255) for the oil pressure switch input to the HEC. Displays the oil pressure reading input to the HEC. Oil pressure gauge will indicate present oil pressure. Normal oil pressure (greater than 6 psi) will display a value between 000 and 176. A low oil pressure (less than 6 psi) or an inoperative engine oil pressure switch will display a value greater than 176. dEGC Display of engine temperature in Degrees C input from cylinder head temperature sensor. If the value displayed is -40C, the SCP message for engine temperature has not been received for more than 5 seconds. GO to Pinpoint Test E .
  • 49 C="C" mark.
  • 60 C=Normal band start.
  • 120 C=Normal band end.
  • 119 C=Temperature warning indicator ON.
  • "-40" C=No SCP Message for 5 sec.
br Displays the brake fluid level input to the HEC. bAtt Displays the code (0-255) battery voltage input to the HEC. Battery voltage gauge will indicate present battery voltage.
  • 93-102=6.9-9.1 volts (Low voltage)
  • 115-124=8.5-10.7 volts (Norm band start)
  • 215-225=15.8-18 volts (Norm band end)
  • 230-241=16.9-19.1 volts (High voltage)
rhEo Displays the present hexadecimal value for the instrument cluster backlighting pulse width modulated (PWM) input to the HEC (used when requesting assistance from the hotline). rhi
rhS
rho PWM input duty cycle.
SCP hexadecimal dimming step (used when requesting assistance from the hotline).
Output driver counts in hexadecimal format (used when requesting assistance from the hotline). Cr Displays the present RUN/START sense input. Display will show -h with the ignition switch in the START position and -L with the ignition switch in the RUN position. ALtF Displays 8-bit hexadecimal value for alternate fuel level. Display will show a value between 00 and FF if the message is received. PA-PE7 Not used. GAGE Repeats test display cycle.
Turn the ignition switch to the OFF position or press and hold the SELECT/RESET button for 3 or more seconds and release to exit HEC Dealer Test Mode. If no DTCs related to the concern are retrieved, proceed to the Symptom Chart to continue diagnostics.
2003 ford f150 supercrew lariat. Odometer is all dashes. All lights headlight tail lights park lights are all on even with switch off and keys out. Horn won't blow. Engine will turn over but not crank.
Engine will turn over but not crank.???? Engine cranks but won't start an run .
Odometer
The instrument cluster receives odometer rolling count status from the PCM and stores the mileage in non-volatile memory (NVM). When the instrument cluster fails to receive the odometer rolling count status for more than two seconds, the odometer display will show dashes.
B2143 Odometer NVM Memory Failure Instrument Cluster INSTALL a new instrument cluster. REFER to Instrument Cluster in this section. CLEAR the DTCs. REPEAT the self-test.
Taking the vehicle an having it checked for DTC'S - diagnostic trouble codes would be a good idea ! Not to autozone or advance etc... Need a professional or factory scanner to check for these codes .
  • The headlamps are on continuously
  • Headlamp switch.
  • Circuitry.
  • Multifunction switch.
  • Daytime running lamp (DRL) relay No. 2 (if equipped).
  • DRL jumper (if equipped).
  • Headlamp relay (if equipped).
  • Remote anti-theft personality (RAP) module (if equipped).
  • Central security module (if equipped)
  • Light sensor amplifier (if equipped).
  • GO to Pinpoint Test F .
Instrument cluster gauges
Check engine light ,abs , air bag lights etc.... come on when key turned on ?
Fuse IPC/HVAC BATT 10 amp located in the left IP junction block . Do you know where this junction box is ?
Does the heater an A/C work ? If so the fuse isn't the problem .
Speedometer
The speedometer is a road indicator. The vehicle speed sensor (VSS) is a permanent magnet generator which is located on the transaxle. The VSS sends an input to the PCM whenever the transaxle differential carrier turns. The PCM then buffers the VSS signal. The PCM transmits the VSS signal to the following components at 4000 pulses/mile through CKT 817:
• The instrument cluster
• The cruise control module
• The radio (uplevel)
The instrument cluster uses the input in order to indicate the vehicle speed on the speedometer.
Instrument Cluster Indicators
The BCM controls the instrument cluster indicators through the SPI serial data communication bus. Refer to Body Control Module System Check in Body Control System.
IPC/BFC ACC
10A
Instrument Cluster and Body Control Module (BCM)
IPC/HVAC BATT
10A
Instrument Cluster and Heater A/C Control Assembly
No gear indicator, replaced cluster, odometer and PRNDL lights on, but no indicator light for gears. ????? Swapped out instrument cluster, gears displayed on other vehicle, (both instrument clusters)
I had a similar situation. No odometer, fuel gage, etc. Turned out to be loose connection in the relay box that is closest to the battery cables. I opened the box and reinserted the connections. It happened again and I took a hammer and gave the black box a whack and it started working again. I found that when the car is running, my wife behind the steering wheel an me under the hood, that when I manipulate the box she hears a click under the dash and the symptoms appear and disappear. That is where I would direct my attention. I understand it is a common problem on this model from a Buick mechanic.
After disconnect and reconnect the battery of my opel antara, the indication of odometer displays only 888... for all indications. How can i reset it?
This solution will be of great help to you,even in the case of future or other dashboard problems;
Instrument cluster consists of electronic analog gauges, various warning lights, and optional tachometer. Vehicles equipped with tachometer have an electronic vacuum fluorescent transmission range indicator (PRND3L),odometer and trip odometer display. Vehicles without tachometer are equipped with a cable-operated transmission range indicator.
Instrument cluster is equipped with the following warning lights:
Battery voltage.
Cruise (speed control).
Door ajar.
Fasten seat belt.
Lift gate ajar.
Low fuel level.
Low windshield and washer level.
Traction Control.
The Body Control Module (BCM), which receives input from various sensors, sends display information to instrument cluster and operates gauges. Instrument cluster incorporates a self-test diagnostic feature to identify electronic problems. BCM, Powertrain Control Module (PCM), and Transmission Control Module (TCM) are continuously monitored by the diagnostic system.
SELF-DIAGNOSTICS
With ignition off, press and hold TRIP and RESET buttons while turning ignition switch to ON position. Continue to hold TRIP and RESET buttons until odometer window displays CODE (approximately 5 seconds). If problem exists, system will display diagnostic trouble codes. See DIAGNOSTIC CODE CHART table. If no problem exists, Code 999 (end test) will be displayed.
CodeDescription
110.......Cluster Memory Fault
111.......Cluster Calibration Fault
905.......No CCD Bus Message From TCM
921.......Odometer Fault From BCM
940.......No CCD Bus Message From PCM
After diagnostic code display ends, instrument cluster will go into each of the following tests in order:
Dim test.
Calibration test.
Odometer segment test.
Electronic Transmission Range indicator segment test.
Dim Test
CHEC-0 will be displayed in odometer window. Instrument cluster will dim Vacuum Florescent (VF) display. If VF displays do not dim, a problem in instrument cluster exists. See BODY CONTROL COMPUTER TESTS in BODY CONTROL COMPUTER article.
Calibration Test
CHEC-1 will be displayed in odometer window. Each of instrument cluster gauges will move sequentially through each calibration point. See GAUGE CALIBRATIONS table. If gauge needle is not calibrated properly, a problem in instrument cluster exists.
Odometer Segment Test
CHEC-2 will be displayed in odometer window. Each segment of odometer will light sequentially. If any segment does not light, replace instrument cluster.
Electronic Transmission Range Indicator Segment Test
CHEC-3 will be displayed in odometer window. Each segment of electronic transmission range indicator will light sequentially. If any segment does not light, replace instrument cluster.
1helpful
My nissan Almera S reg has no side lights or dash lights.All fuses seem ok.
Battery voltage.
Door ajar.
Fasten seat belt.
Lift gate ajar.
Low fuel level.
Traction Control.
SELF-DIAGNOSTICS
CodeDescription
Dim test.
Calibration test.
Dim Test
Calibration Test
2000 dodge caravan 3.3 motor,,,,,,,we put the key in the ignition,, turn the key to unlock it,, turn key to light up odometer & shift indicator,,,, then there is another click to power up the rest of...
sounds like you have instrument cluster problem it probley has a short which would cause the security system to lock thinking that the van was being stolen i have has this problem before. hope this helps.
Changing dashboard light
Battery voltage.
Door ajar.
Fasten seat belt.
Lift gate ajar.
Low fuel level.
Traction Control.
SELF-DIAGNOSTICS
CodeDescription
Dim test.
Calibration test.
Dim Test
Calibration Test
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
