Has to do with a new computer that won't read my scanner
I keep getting the error & code: The drivers for this device are not installed. (Code 28) But if I reconnect this on to the older computer it works perfectly well. What options are there for me?
  • 27,725 Answers
Click start control panel administration tools computer management device manager scroll through all of your devices
If you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
If you computer came with a motherboard disk the drivers could be on it.
Rather doing a driver hunt which can take hours
http://download.cnet.com/SlimDrivers-Free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
it might take some time being a freeware driver solution
Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Posted on Jul 19, 2013
Junoon007
  • 1011 Answers
SOURCE: pioneer dvd-rw dvr-k17a
Dear Sir/Madam,
This is the problem of not matching/support the motherboard of your driver with Pioneer DVD. U just go the manufacturing site of Pioneer dvd and download the driver / updates and then install it. (Before u uninstall the driver). Then fix it.
Thanks
"Don't Forget To Rate the Solution"
Posted on May 19, 2008
harry1276
  • 51 Answers
SOURCE: I have installed Windows XP on my PC. However,
so, you should install your sound driver  follow the step below to reinstall it.
start/ right click my computer/ choose Properties in system properties, choose Hardware tab. Click Device Manager check if there's yellow question mark in it. If so, that's where the driver perform not normal. Delete it, and restart your windows to reinstall that driver.
Posted on May 14, 2009
  • 468 Answers
SOURCE: SM Bus Controller Driver Required
There is missing appropriate chip-set driver, check your motherboard model and download and install chip-set driver.
Posted on Oct 14, 2009
Testimonial: "This has solved the problem! Many thanks :-)"
shehrozeali
  • 12 Answers
SOURCE: sound error msg : please install proper driver or
this error code 88780078 is for bad sound driver..
i think u may had not installed the correct driver for ur machine...Go to hp driver update web and download the proper driver for ur sound device
Posted on Jun 18, 2010
  • 77 Answers
SOURCE: when i start computer a option appear on the
first tell me is your audio is working or not? For some high definition audio drivers it also require universal audio architecture. I think your audio chipset is also related to thats.
check in device manager in sound section. for go to device manager open run and type "devmgmt.msc" and check. If any device is there with yellow mark means that driver is not loaded properly not only in sound section check all devices because if the driver is not recognized as sound device then it show as unknown device.
tell me which motherboard you are using.based on that i can help u.
Posted on Jul 06, 2010
Can't get my cd/dvd rw drivers to work? Can't read the CD/DVD RW Tray?
Description of Code 10-related errors that Device Manager generates in Windows-based computers
Try this - Control Panel - Device Manager - CD/DVD - double click the device - Driver's Tab - then RIGHT CLICK the drive - UNINSTALL - REBOOT
this will refresh the default driver stack.
if this not work, replace the device with a new one.
Mar 03, 2015 | Acer 15.6 Inch LCD Screen Panel for Aspire...
Hi Buddy, Can you help me with my HP printer? I keep getting a Scanner Error 8 message and it won't print. Time to buy a new printer?
Make sure the scanner usb and power leads are securely seated
the drivers for the scanner might have been corrupted
you might have to uninstall the scanner restart your computer then reinstall your scanner
if your printer/scanner came with an installation disc the drivers could be on it
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow Question/exclamation ? ! mark or a red X this will mean you need to install a new driver for this device right click to update driver
select properties again you will have the similiar options also have option to troubleshoot
HP PRINTER DRIVER PACKAGES
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=25523
hope this helps you
Nov 16, 2011 | Office Equipment & Supplies
Disk drive won't work cannot install driver
IF YOU HAVE NO INSTALL DRIVER GO TO MY COMPUTER, MANAGE, DEVICE MANAGER, UPDATE DRIVER SELECT DRIVER PATH AD INSTALL IT
IF YOU HAVE NO DRIVER, GO TO MY COMPUTER, MANAGE, DEVICE MANAGER, PROPERTY ON DEVICE WHOSE DRIVER ARE NOT FOUND, COPY DEVICE ID CODE ON DRIVER DETAILS OPEN http://devid.info SITE AND DOWNLOAD SUITABLE DRIVER AND INSTALL TO USE ABOVE STEPS
May 18, 2011 | Computers & Internet
Internal error occured code: 5,202,52 after installing Canon CanoScan Lide 210
Perhaps you have forgotten to unplug the scanner before
scanning? That's what happened to me. I kept getting
different error codes, 5,202,63 or 5,202,52 or 5,202,54 and
also a message that the driver was not in the TWAIN folder.
According to the help file the problem might have been due
to my nfts file system. I also tried downloading various
new drivers. Nothing helped until I noticed that I had not
unplugged the scanner!
Apr 11, 2011 | Canon CanoScan LiDE100 Flatbed Scanner
I have a pakon scanner f 235 which read error code 235 ,what can i do to resolve that problem.
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot hope this helps
Apr 08, 2011 | Computers & Internet
Computer see error code 43
Restart your computer if you haven't done so already.
Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a possible solution to a Code 43 error.
Update the drivers for the device. It's also very possible that installing the latest drivers for the device could correct the Code 43 error.
Install the latest Windows service pack.
Update BIOS.
Replace the data cable that connects the device to the computer,
Reference the hardware device's manual
for more help regading this issuer or other issue visit https://cbrtechsolutions.net
Feb 17, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Canon CanoScan LiDE 25 Flatbed code 39
Did the message say:
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
Download the Delete driver application from Canon's website and run it. After deleting this and rebooting, try installing again.
May 29, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
CanoScan LiDE 50 error code: 2,7,0
Has your scanner been working before?
If so, has anything changed since then such as new printers or other devices added to the computer, or upgraded to a new OS?
Which OS are you using?
When exactly does the error occur?
Does ScanGear open?
Are you able to preview?
Try connecting the USB cable to another port on the computer (directly to the computer...not through a HUB or any other device). Bypassing a hub, which would have to be a powered HUB, or other devices would rule out any issues with those devices.
Ultimately trying the scanner on another computer would rule out issues with the scanner as well.
May 09, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Error Code 39 with Canaoscan LiDE 25 Scanner
Try RunAs Administrtaor
Try logging in as Administrator (You may need to unhide the 'hidden' Administrator account)
Jan 11, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Error Code ox24050010
sounds like a proprietary TWAIN driver from Canon must be installed...try forcing driver from cd under current devices driver...under device manager, look for imaging devices, then right click-properties then driver-update driver...make sure cd is in
May 30, 2007 | Canon CanoScan FB630P Flatbed Scanner
Computers & Internet Logo
David Payne
David Payne
