Question about Invacare Health & Beauty
Rascal 600 looses its charge after 3 days unless battery is disconected
    New Friend:
How do you slip the inner of a wheel to put a new tyer on plrase
Posted on Jul 19, 2013
5 Suggested Answers
batvette
  • 16 Answers
SOURCE: rascal 600
Neil wood, the Rascal 600 DOES use an on board charger. What signal is the white wire looking for to make the scooter move is the question. 28v?
Posted on Sep 01, 2012
gewiz
  • 1271 Answers
SOURCE: Need battery charger for Rascal 600 scooter
Hi, GOTO the following website , they sell you a 5 amps one for 30 including postage.
Posted on Dec 06, 2012
  • 692 Answers
SOURCE: Low hour, RASCAL 600
The green light on your charger indicates a full charge but you know thats not right since you didn't charge the batteries when they were in storage they have dropped so low the charger cannot detect them and provide a charge. The batteries will need to be replaced with new ones. Charge before use and charge for at least 20 days to get them operating at 100% now you will have to use it for those 20 days to get the batteries used to charging charge every night when you go to bed and unplug when you get up in the morning. If you do have to leave the chair for a week or so put up fully charged and charge once a week overnight. If you put the chair in storage again disconnect the batteries from the chair and store with a full charge. Hope this helps you
Posted on May 08, 2011
  • 6 Answers
SOURCE: We purchased a Rascal 300 two months ago that
Also check the fuses.
Posted on Sep 09, 2009
I have a rascal and put new batteries in it and it seems they will not charge up what could be the problem?
Hi Chris,,,, Now lets get the silly question out of the way first, have you tried another charger ?
IS it a built in charger ?
Remember a bad charger == Bad batteries...
the lead that goes from the chagrer socket to the batteries via the controller are most likely adding resistance that the charger does not like ...
Regards
Robi
Aug 31, 2015 | Rascal 600 T Electric Scooter w Seat Lift...
How to change batteries in a Rascal
The Rascal 600/300, remove the seat, lift off the cover, unplug a battery, replace the old battery with a new one, putting the cable connections on the same way, red is +, black is -. Do the same with the next battery, reconnect the anderson plugs,reinstall the cover and seat and plug in the charger with the key on watch to see the needle raises up toward the full mark, allow to charge fully, overnight is good. keep the bats charged up not allowing them to drop below half way for the first 20 charges to break in the batteries. as a rule charge the scooter after every use!
Scooter Doctor App
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Jun 29, 2014 | Rascal 300 Electric Scooter - Used...
Joy stick to fast 318 power chair
Hi, Unless you have access to a PG Drives fault/programmer unit, You will need to go to a Rascal dealer to sort this out for you.
Feb 09, 2014 | Rascal 600 T Electric Scooter w Seat Lift...
My charger on Rascal 600 does not charge. After checking all the common reasons without any luck I remove the charger and could not measure any voltage output. My Dealer sezs the charger won't work without...
Most chargers are 3 pin. Plus and minus charging voltage to the
batteries and a third pin monitors the actual battery voltage, so
that the automatic charger can turn itself off once the batteries
are fully charged. As Brad has mentioned, the connection
from the charger has to be made for the charger to produce
a voltage at those pins. The best way to see if it is charging
is to remove the seat and measure across both batteries..
assuming it's a 24volt system like most. Charging voltage
can be as high as 28volts across the positive of one 12volt
battery (connected in series to the other 12v battery) and the
negative of the other battery. You can monitor the charging
voltage across the batteries with a digital volt meter.
Nov 04, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
3 wheel rascal 600 blinks 4 - 8 times...what does it mean?
Good day to you.These series or blinks or bleeps are codes to determine the fault.& the trouble you will find is Shoprider etc will not give out info to the public.Contacting a Scooter repair shop is a good idea,reason being.They can order your part if needed.You can also download:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772 as a PDF File,if you do anything yourself.Remember a repair shop will be hesitant to even look at it & I suggest you take a photo of every step if fixing yourself with your mobile.Have a nice day,hope I was of help.Colin
Mar 31, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
Rascal 600
Apr 20, 2012 | Electric Mobility Power Electric Scooter...
I have a 2004 Kawasaki zzr 600 that does not keep the charge longer than 2 days. What is causing this problem
hi, you probably have a "almost dead" batery, but in order to properly check, proceed as folows:
1 - give the batery a full charge
2 - disconect both cables (+) and (-) from batery
3 - check charge and see if batery holds it - a good batery must keep 12,7 to 13,2 volts for a very long period
If after this test,considering that batery is ok, then chek your wiring loom for ground losses
good luck
Sep 13, 2011 | 2004 kawasaki ZZR 600
Low hour, RASCAL 600 has been in clean safe storage with new batteries won't charge, no amp meter reading, no fuel gauge reading, yet charger itself has red and green light showing. If and when the...
May 08, 2011 | Health & Beauty
My friend has a rascal electric wheelchair he rode it here andveven tho we put the charger on--and he recently spent $200 on new batteries--it wont move the horn honks and it appears charged but it wont...
Hi. This type of fault can be caused by a few different problems. Is the machine flashing any fault codes?
Faults could be a stuck brush in the motor, Free-wheel lever in the wrong position, faulty motor or battery connectors, loose battery terminals, jambed brake solenoid.
Hope this helps. Neil.
Jun 09, 2010 | Pride New Jazzy 600 Power Wheelchair by...
Health & Beauty Logo
35 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
