Question about Windchaser Portable Air Conditioner - PACR12
Alarm light keeps coming on and stops blowing cold air out front and blows cold air out the exhaust hose instead?
4 Suggested Answers
SOURCE: Windchaser PAC9 (WA9000ER) is on but not cooling...
I've got exactly the same problem. I think it is a fuse gone bad.
Posted on Jun 15, 2007
rockitman187
  • 2559 Answers
SOURCE: My air conditioner blows cold then kinda a shakes
The compressor is going into thermal overload.
Posted on Jul 29, 2009
SOURCE: keeps frezing up. ice on the coils, not blowing
Try to make general general cleaning of the unit specially the coils.
Posted on Aug 10, 2011
SPT WA-1220H Portable Air Conditioner stopped blowing COOL air?
sounds like the compressor has died and is tripping its overload protection. Give it a good funeral, and next time, buy a brand name model.
Oct 06, 2014 | Kenmore Ac Airconditioner Remote Control...
My everstar blows hot air out the back and cold air in front i want all cold air
this style unit needs an exhaust hose attached to the rearand be placed out the window to exhaust the heat that is removed from the air in the room, you will also have to empty the condensate drain bucket when it gets full.
Jul 23, 2011 | Fedders Portable Dual Hose Electronic...
Brand new delonghi PAC C120e, I got everything installed easily with the unit rite next to the window, I have it turned all the way down and it still does not cool my small room at night. It seems to blow...
Since the unit is new and under warranty and hopefully you have registered it with Delonghi. Your best bet, is to contact their Customer Support Rep 800-322-3848. Doing it this way has you totally covered.
Jul 12, 2011 | DeLonghi PAC C120 12000 BTU Portable Air...
How does the heater part of the CPN12XH9-E work? Does the hoses need to be in window still?
Yes, hose needs to connect to outdoors, since it operates as a heat pump. You'll notice cold air blowing out the exhaust when in heating mode, and hot air blowing out the exhaust in cooling mode - unit exhausts opposite of temperature you want.
Jun 13, 2011 | Haier HEATER CPN12XH9 Air Conditioner
Case 580 m ac will come on blow cold then the light comes on and it stops blowing cold you can turn ac off for bout 1 min and turn it on it blow cold and kick off light on manual say light eather high...
take a garden hose or somthing with high water pressure and spray out all of radiators in the front of machine. This will clean out all the dust build up between all the rads and will cause your fan to cool the ac fluid as well as the others
Aug 05, 2010 | Ertl 580 Super M Series II Tractor
Our heater takes about 20 mins to blow warm air, and then if we are stopped at a light and the engine is idling it gets cold. Also, in the summer when we turn on the a/c it blows hotin the front and cool...
always check the coolant first, then feel both heater hoses to see if they are equally hot.
if one hot and one cold, then the heater core is clogged
if both hot then you have a blend door problem.
on the a/c there's some time a rear unit that blow cool air even the front does not
Feb 26, 2010 | 2001 Ford Windstar
2001 Dodge Caravan heater blows cold air when stopped
Have you checked the coolant level? What you describe is exactly what happens if the coolant level is low. When stopped at idle, hot coolant is not circulating through the heater core, so no heat. As the engine increases in rpm's when you pull away from the light, the water pump is spinning quicker, and some coolant is making it to the heater core. So check the level, and if it is low, keep an eye on it to see if it drops again. That of course indicates a leak somewhere. Get it fixed, as overheating the engine leads to costly repairs and worse case a new engine. Let me know how you make out with this.
Dec 05, 2009 | 2001 Dodge Grand Caravan
Back air blows cold air, the front blows warmer air
I recenly had the same problem on my 1999 suburban, even after I replaced the whole ac system.
The heater valve, which is under the air filter area was not closing, causing heat to be blowing over the evaporator core. I used a zip tie to keep it in the closed position, and ac went from 70 degrees to 40. I think the vacuum switch is bad, 40 dollars (dealer part). You can also pull the vacuum hose off the switch, which is on the firewall and connect it dirctly to valve and it closes the valve, but fits loosley. Use silicone around vac hose if you go this route.
Jun 09, 2009 | 1999 GMC Suburban
High limit switch open- but only faults in night and extreme cold
Hello , I can try to help you out on this one , It sounds like what is happening is that your exhaust vented up is condensating from the heat in the pipe and the cool in the attic or wherever the exterior of the exhaust pipe travels. It is very common because your exhaust/flu pipe is not insulated.
To fix this issue you must drain the water/condensation from the small 5/16th hoses in front of the blower assembly , just pull them loose and angle them downward to drain. This should fix the problem if this is the problem.
Let me know how it turns out or if you have anymore questions. Phil
Dec 31, 2008 | Heating & Cooling
Heating & Cooling Logo
20 people viewed this question
Top Windchaser Heating & Cooling Experts
Jay Finke
Jay Finke
Donni Steen
Jake's Auto Care...
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
