Question about Pool & Spa
Hi, I've had my spa ALMOST 5 years and I have
Hi, I've had my spa ALMOST 5 years and I have started noticing these little ball bearings INSIDE THE SPA. I can't remember how long the warranty is, I'm thinking 5 years ( I hope ). Anyway one motor has a ON AND OFF buttton while the other motor has a OFF, LOW AND HIGH button. The motor with the low side seldom if ever turns off. Thanks Robert Glasscock. (318) 470-9759
    Problem Solver:
  • 21 Answers
The balls are out of the spinning jets, expensive if you need 20 or 20, can replace with fixed ones at low cost
Posted on Jul 28, 2013
4 Suggested Answers
SOURCE: High speed spa pump shuts off
The motor may have a thermal cutoff if the motor draws too much current. Do you have a sufficient large gauge circuit supplying the motore? If not the actual voltage at the motor may drop, causing it to draw more current to make up for the loss of voltage, thereby tripping the motor's protective breaker. I assume the motor will start again after serveral minutes of cooling down.
Curtis
Posted on Apr 19, 2009
  • 59 Answers
SOURCE: Spa Motor Hums
if it is a used pump, these have a tendency to have a little rust. just get some pump pliers and rock the shaft gently back and forth. then plug it back in.
David
Posted on May 25, 2009
SOURCE: Pump will not work in high speed
Clean the relay contacts on the board. Cut the power, ofcourse. Also, try switching the hot wire on the low side of the pump to the high side to rule out the pump.
Posted on Jun 08, 2009
What is the flow rate (GPM) of an Executive 56 Waterway pump Model PF-50-2N22F?
Waterway Executive 56 Spa Pump, 5 HP, 230V
Waterway Executive 56 Frame spa pump wet end
assembled to a 56 frame, 5hp, 2-speed 230V spa motor
This Spa pump has a 2-1/2 inch intake and a 2 inch discharge for plumbing
(but measures 3-1/2 inch and 3 inch- see bottom of this page)Manufacturer Part No. 3722021-13 Other Part No. PF-50-2N22C
Features:
  • Executive spa pump wet end designed specifically for 56-frame spa motors
  • Two double shielded ball bearings with moisture resistant grease for quieter operation and longer life
  • Two speed spa motors have four sets of insulated windings for increased efficiency
  • 56 frame spa motor for added strength, cooler operating temperature and longer motor life
  • Large 2-1/2 inch intake for improved flow performance and reduced noise
  • Large 6-1/2" diameter wet end for higher head pressure
  • Split capacitor, (start and run) for less energy consumption
  • Thermally protected to extend life expectancy of hot tub motor
  • Highly versatile wet end can be rotated every 90 degrees
  • Viton seals
  • Three year manufacture's warranty on spa motor and spa pump wet end
Jun 05, 2015 | Waterway Garden
What are the side effects over years of use
Ball Bearing needs to change.there is inside the pump a mechanic seal that with the time, leaks water and rust the ball bearing balls and making rusted the shaft .
The pump at this time gets Humming when works.
Pump humming or making noise is not a good working pump.
must be quiet without noise
Aug 19, 2014 | Pool & Spa
Spa don't want to start
how long the Spa was without use?
Maybe you need to disassembly the pump and make the shaft turns to unlock the shaft. sometimes the ball bearings are rusted.
Aug 16, 2014 | Pool & Spa
Intex Automatic Salt Water System For Above Ground Saltwater Pool won't turn on
Usualy if it is some years the ball bearing on the motor shaft are rusty and if you can desasemble and use a UD40 lubricant or similar it can be fixed, or replace the bearing. One more posible case is the starting capacitor if it replaced can run the motor again.
Jun 05, 2012 | Intex Automatic Salt Water System for ...
Dreammaker 400 spa won't heat up
make sure recirculation pump on then check heater element then pressure switch then loud motor you hear
May 21, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a hayward CL220BR brominator on a 750 gallon spa in a hotel.it overfeeds the bromine.i've changed the check valve and setting dial and still overfeeds.this happens every few days.is there...
Ristrict the flow of water thru even more...We've put a tee in a line then a stubby piece of PCV into a ball valve then another stub about 6 inches long and a cap. Tie the inlet line into this stub and partially close the ball valve.
John
May 20, 2011 | Hayward Offline Brominator
I found silver balls in my pool pump basket
Do you have a robotic or automatic pool cleaner? If so, inspect the bearings in them for failure. Otherwise, is it possible they were tossed in by something outside the pool? Your motor bearings would have a very hard time coming apart and allowing the balls from inside the bearings to migrate to the pool.
John
Sep 12, 2010 | Smith AO Pool Pump Motor
I have the ball bearings showing up in my lounger in my spa and now realize that it is probably from a spinner jet after reading several postings. I just filled the tub and put in all new chemicals. Does...
Well.. Ummm... Yes. really to be safe & responsible & to prevent any more damage. Just having it hot & using for a little bit, may be OK, but no water jets etc. No Water Pumping jets etc.
Feb 06, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Pool & Spa Logo
41 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
