Question about Vehicle Parts & Accessories
My 02 tundra runs great but I have to hit the gas when I start the car to bake sure it keeps idle, after that its fine. Today it cut of while I was driving , I reved the engine a little and it ran great again. What could be the issue
    Problem Solver:
  • 7 Answers
Could be idle control module,
Posted on Jul 18, 2013
Want idle
You most likely have a large vaccuum leak.You should be able to hear it under the hood with the engine running.I'm not sure if Toyota had gone to "drive by wire" in 2002,or if your truck still has an Idle Air Control motor.If it has a mechanical throttle cable(not "drive by wire",then it will have an Idle Air Control motor,which could be stuck or defective.
Mar 28, 2014 | 2002 02 Toyota Tundra Instrument Cluster...
2000 tundra v6 5-speed cold start truck runs great, park it for 20-30 min it will start fine but after going 1/4 mile it dies, looses power. pull over and it will backfire and sputter until it eventua
bad need of a tuneup? like new spark plugs, ?
172 , is 02 rich/ lean warning. this one is low oxy for rich.
this code can just be a victim. for sure , with misfire.
means 02 sensor stuck at rich,
what is water temp in engine coolant, at failure? less than 150F?
could be lots of things.
leaking injectors, bad fuel.
injector sticking> causing misfire.
id use a scan tool and watch all sensor when it fails.
too high fuel pressure.
misfires cold, but only luke warm cold starts not fully cold.
just one DTC, no P0300 or 30x misfire codes, not even P0300 pendings?
Jan 31, 2014 | 2000 Toyota Tundra
I disconnected my battery in 08 tundra and now it wont idle
disconecting batt resets the computer. now it needs to learn how to set everything to run again. disconnect batt for atleast 60 seconds, re atach, start car it will start and die(dont press gas) do this over and over until it idles (could take up to 10 times). by pressing the gas you make the computer think it is idling to high so it keeps turning down the idle. it will idle fine after reseting computer and starting several times without hitting gas peddle.
Mar 09, 2013 | 2000 Toyota Tundra
91 Sierra 1500 5.7 l. starts and runs fine, but starts cutting out badly after warming up out on the road. It will sit idling 15 + minutes before it starts to skip a little.
you can try to clean out the 02 sensors I had a problem like this in a 05 saturn. The 02 sensor that I cleaned was located towards the front of the engine behind the fan right in the middle of the car. the sensor was all powdery and black, i would brush it off with a wire brush that worked for me and then I learned of the ethanol in gas so I got ethanol free gas, used for boats and I never had that problem again. and never had to replace the 02 sensor.
Feb 23, 2013 | 1991 GMC Sierra
I have a 91 Chevy Lumina, just replaced the injectors and all the coils on saturday and ran fine but when driving it would have trouble it seemed shifting, starting today when you hit the gas the car dies...
Your ignition spark control module is going bad,your coils pack are located right underneth them. this is what tells your coils packs to produce spark to your spark plugs. they are easy to replace just make sure you mark you coil pack with some tape and make sure you put them back in the same order as they came off the spark control module. Easy to replace,just make sure you use the proper size torx or socket size on the screw heads...
May 31, 2011 | 1991 Chevrolet Lumina
02 Toyota tundra won't idle. I put a new battery on and cleaned air filter
sounds like a bad idle control sensor.as long as you're driving it and giving it gas it runs somewhat ok right? it won't idle by itself,or it idles up and down by itself and then dies?thats a sign of a bad idle control sensor,some times they straighten up after the engine warms up and run fine.but eventually go completely bad and won't idle at all. hope this helps and thank you for choosing fixya.com
Jan 09, 2011 | 2002 Toyota Tundra
Vehicle Parts & Accessories Logo
54 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
