Question about Thomson GE DECT 6.0 Cordless Phone
Manual como lo registro
PERDI MI MANUAL DEL TELEFONO INALAMBRICO BEETEL 2.4 GHZ DIGITAL, NECESITO REGISTRAR EL AURICULAR EN LA UNIDAD BASE.
POR ERROR BORRE REGISTRO, COMO LO REGISTRO NUEVAMENTE? EN LA PANTALLA SALE REGISTRAR! MI CORREO ES : lcasinos@hotmail.com GRACIAS!
Mar 26, 2011 | Cell Phones
Tip
C?mo limpiar de forma segura a un Jefe de cintas de v?deo
<span><span><span>Si</span> <span>usted no est&aacute;</span> <span>recibiendo</span> <span>v&iacute;deo</span> <span>desde</span> <span>un VCR</span><span>,</span> <span>videoc&aacute;mara</span> <span>de 8 mm</span><span>,</span> <span>o</span> <span>c&aacute;mara de v&iacute;deo</span> <span>digital</span> <span>grabadora de v&iacute;deo</span><span>, pero</span> <span>de audio</span><span>obtener</span><span>, haga lo</span> <span>siguiente</span><span>:</span></span></span> <span><span><span><span>1</span><span>.</span> <span>Utilice</span> <span>una cinta grabada de</span> <span>nuevo</span> <span>-</span> <span>a</span> <span>la derecha</span> <span>del</span> <span>paquete</span> <span>e insertarla</span> <span>en</span> <span>la</span> <span>unidad.</span><br /><span>2</span><span>.</span> <span>Lleve a cabo</span> <span>un registro</span> <span>en la</span> <span>cinta</span> <span>-</span> <span>la puso</span> <span>a</span> <span>hacer</span> <span>un registro (</span><span>no</span> <span>la reproducci&oacute;n</span><span>)</span><span>.</span><br /><span>3</span><span>.</span> <span>Deje que se</span> <span>completa</span> <span>a trav&eacute;s de</span> <span>toda la cinta</span> <span>sin parar</span><span>.</span><br /><span>4</span><span>.</span> <span>Al</span> <span>terminar</span> <span>-</span> <span>le permiten</span> <span>rebobinar</span><span>.</span><br /><span>5</span><span>.</span> <span>Inserte</span> <span>una</span> <span>conocida</span> <span>cinta</span> <span>pregrabada</span> <span>buena</span> <span>y el juego</span> <span>-</span><span>observar</span> <span>la imagen</span><span>.</span> <span>Si es</span> <span>bueno</span><span>,</span> <span>entonces</span> <span>la</span> <span>cabeza</span> <span>estaba</span> <span>sucia</span><span>y</span> <span>est&aacute; limpio</span> <span>ahora</span><span>.</span><br /><span>Usted</span> <span>puede llevar a cabo</span> <span>lo anterior</span> <span>cuantas veces sea necesario</span><span>sin ning&uacute;n tipo de</span> <span>da&ntilde;os en el</span> <span>aparato</span><span>.</span></span></span></span>
on Dec 13, 2010 | Televison & Video
Hola el problema es que son dos telefonos registrados en una base pero el 2 que seria el movil no funciona no da linea suena como si estuviera ocupado,ya lo intente con el manual y nada ha es nuevo gracias...
Hola, el procedimiento sujerido del fabricante en este caso es el siguiente:
  1. Retire y vuelva a colocar las baterias
    del terminal.
  2. Intentelo de nuevo desconectando la
    alimentacion de la base y volviendola a
    conectar y siga el procedimiento de
    registro de un telefono.
Registro de un auricular.
  1. Inserte la bateria para encender el
    auricular. En la pantalla LCD
    aparecera "PULS TECLA OK
    PARA REGISTAR".
  2. Pulse pantalla LCD aparecera "PULSE
    PAGE DURANTE 5 SEGS".
    Antes de que transcurran cinco
    minutos, pulse la tecla de
    localizacion (PAGE) que se encuentra en la
    estacion base para iniciar el proceso
    de registro.
  3. Si el registro se realiza con exito, el
    auricular volvera al modo en espera.
    Si el registro no se realiza
    correctamente, en la pantalla LCD
    aparecera "PULS TECLA OK PARA
    REGISTAR". Repita el proceso de
    nuevo.
Feb 28, 2011 | Philips CD1503B/17 Phone
QUIERO SABER TODAS LAS ESPECIFICACIONES DE FUNCIONAMIENTO, CONSUMO Y MANTENIMIENTO DE LAS FOTOCOPIADORAS ESTUDIO 350
Esa informacion la podras encontrar en el manual de servicio de esta copiadora, esta informacion es muy extensa, tendrias que bajar este manual de alguna pagina de soporte como de toshiba.com el nombre simplificado como la puedes encontrar es sm450 a lo mejor asi lo encuentras en un buscador como google o yahoo, suerte.
Feb 24, 2011 | Toshiba e-Studio 350 Copier
Como puedo volver a registrar el tel si ya estaba en uso pero se borro el nip que ya tenia
primero tienes que presionar la tecla de registro/localizacion que se encuentra en la base por aproximadamente 3 segundos como minimo, luego la sueltas y le das en menu OK, luego configuracion OK, auriculas OK, Reg, auricular OK, y ahi te pide el PIN, son 0000 (cuatro ceros) OK, y eso es todo, tarda un minito o menos en registrarse, si tienes mas de un telefono, con cada uno de ellos tienes que hacer el mismo procedimiento y eso es todo, espero aun te sirva :)
Jan 02, 2011 | Siemens Gigaset A490 Twin Cordless Phone
Como conectar bluetooth madcatz playstion 3
Antes que nada asegurese de que el dispositivo bluetooth este encendido.
Para poder sincronizarlo:
1. Enciende el PS3
2. En el men? Settings (Ajustes), seleccione Accessory Settings (Ajustes de accesorios) y presione X.
3. Presione X en el icono Register Bluetooth® Device (Registrar dispositivo Bluetooth®).
4. Despl?cese hacia abajo y presione X en el icono Register Headset/Microphone/Headphones (Registrar auriculares/micr?fono/auriculares).
5. En la siguiente pantalla, prepare el auricular para sincronizarlo con la PlayStation 3. Para hacerlo, presione el bot?n K1 durante 8 segundos.
6. Una vez que el indicador luminoso LED del auricular titile en azul y en fecha de comprarojo (lo que indica que el auricular ya se puede sincronizar), presione X en Start Scanning (Iniciar escaneo).
7. Una vez que se haya efectuado el escaneo, la PlayStation 3 reconocera todos los dispositivos Bluetooth que se encuentren dentro del ?rea de alcance del sistema.
8. Busque 8860 en la lista de dispositivos, seleccione el icono correspondiente y presione X para que se le solicite una clave.
9.Escriba 0000 (cuatro ceros) como clave y presione X en OK.
10.A continuaci?n, aparecer? el mensaje: Register completed (Registro finalizado).
Dec 28, 2010 | Mad Catz Bluetooth Headset for PS3
BUSCO EL MANUAL DEL Usuario
Yo encontre lo aqui: http://support.rcaaudiovideo.com/manual.aspx?product=27
pero desafortunadamente, solo es en ingles.
Posiblemente, se puede usar este (de Google) para traducirlo, si lo necesita. En ese sitio, se puede subir un documento (como el manual) y traducelo.
(Lo siento por mi espanol mal)
Buena suerte!
Jun 04, 2010 | RCA TH1101 MP3 Player
Problemapara prender el carro
Adivina, adivinanza, y mientras lo solucionamos, nos rascamos la panza.
Sugiero revisar el arrancador y compoenntes de encendido, asi como el sistema de envio de combustible, presion de bomba, asi como componentes que mantienen el minimo (ralenti) del vehiculo. Descartado eso, verfificar sensores IAC y oxigeno.
Visita autozone.com (registro gratuito), seleccionas el año, marca modelo y motor de tu vehiculo para poder acceder a guias y manuales de reparacion.
Espero haberte ayudado (recuerda valorar esta ayuda).
Oct 20, 2009 | 1994 Acura Legend
NECESITO MANUAL DE INSTRUCCIONES POR PERDIDA
Estoy seguro de que hay una para descargar, pero no encontró nada en Google ...
Si los motores de búsqueda no son de ayuda, simplemente pedir a algunos especialistas en la Web profunda, por ejemplo, http://manualfox.com/es - esta es una agencia de búsqueda manual y si no lo encuentras, no existe en la Internet.
Sep 03, 2009 | LG RC389H DVD/VHS Recorder
Agregar entradas al registro a traves de file.reg
I HAVE WINDOWS XP OPERATING SYSTEM. I AM NOT GETTING SOUND SETTING. PL. SEND PROPER DRIVER FOR THAT & OBLIGE.
THANKS
JAYDRATH.
Aug 01, 2008 | Microsoft Windows XP Professional With...
Thomson GE DECT 6.0 Cordless Phone Logo
19 people viewed this question
Top Thomson Lands Phones Experts
george  peters
george peters
Are you a Thomson Lands Phone Expert? Answer questions, earn points and help others
