Question about Marantz Audio Players & Recorders
My marantz cd 6004 won't play my cds,sub Q ERROR keeps coming up
SOURCE: ford 6006e cd changer with e 3 error keeps happening
The only way to do it is to remove the radio using DIN radio removal tool - then you will have easy acces to remove cd's if you do not have this tools try to use coat hanger (do small catss on the ends)
(you can try to hold eject button and swich off - swich on button - probably it will not work but try few times
Good luck,
Kamil
Posted on Jun 24, 2009
mikelpoynter
  • 77 Answers
SOURCE: I have a vauxhall astra with a cdr 500 cd player
From what I have been told, you would need to reset the unit. With a reset, basically disconnecting the battery cable you would need a four digit code. It was one that came with the car or the radio. It will put it into safe mode as if the radio was stolen. Once it is in safe mode you would then need to punch in the 4 digit code. That will reset the unit and allow the radio to begin working. If you do not have the 4 digit code you would then need to take it to a dealer and have them reset the code. I was told it would only be about $25 at almost any dealer.
Posted on Oct 29, 2009
  • 9 Answers
SOURCE: I have a marantz cd re-corder but I insert a cd rw disc or cd r
check the manual for what types of discs you can use.
Posted on Jan 15, 2010
  • 15 Answers
SOURCE: my cd player keeps saying error 3 what does that
its because of data memory corrupt.. u might need to flast your memory of ur cd player
Posted on May 29, 2010
  • 3 Answers
SOURCE: The CD player in my Pure Legato 2 system won;t
I have fixed this problem in 2 Legatos. But don't attempt this if you have no experience with electrical equipment.
You need to open the case (4 screws deeply recessed in the back panel, 3 screws securing the speaker terminals and the phono socket block, and the nut and plastic washer holding the aerial socket. Gently ease the rear panel back enough to access the rear of the CD mechanism. Under the CD laser assembly carriage, there is a small trim pot (with a yellow cross-head adjuster screw). I found a small anticlockwise adjustment got the CD player working again. (I assume this trimmer increases the gain of the optical sensor amp.) Secure the rear panel before powering on again to test. It may require a little trial and error to recover the full functionality of the CD.
Good luck.
Posted on May 30, 2010
Volume fluctuations
Does the volume fluctuate through speakers?
Feb 19, 2016 | Marantz Audio Players & Recorders
We have Marantz PMD 325 CD players. Usually TOC REading comes up when you put a CD into the player. However sometimes we now get the following message "PMA Reading", What does this mean.
Hi Wendy CD-Rs and CD-RWs have a component that ordinary music CDs do not have -- an ...This additional track space includes the power memory area (PMA) and the ... which tells the CD player what part of the disc it is reading at any particular time. ...uncorrected error on a music CD only means a bit of fuzz or a skipping noise. GOOD LUCK !
Jan 05, 2014 | Marantz SA8260 CD Player
My Marantz receiver wont work
Hola my best advice is to find the model and type in online or
see if these pages help you
http://us.marantz.com/...004_Spec_sheet.pdf
http://us.marantz.com/...6004-5004_U_EN.pdf
or maybe refer to the manual hope this helps a little good luck
May 10, 2013 | Audio Players & Recorders
Sub q error
I think that is a wise choice, this is clearly a manufacture defect.
Apr 01, 2012 | Marantz Audio Players & Recorders
It no longer reads all cds sacds it use to, thought cds were bad,bought second cds and still will not play help love the sounds
When you say it doesn't read SACD's do you mean it doesn't put out 5.1? Keep in mind that you have select the SACD multichannel area and use the 5.1 analog outputs for that and NO digital output will be produced.
The manual...
http://www.retrevo.com/support/Marantz-SA8260-manual/id/511bh850/t/2/
Dec 28, 2010 | Marantz SA8260 CD Player
Marantz cdr420 recorded media stored on harddrive.played back all fine unplugged now it says no valid files when i try to burn the disc but the drive reads full.
If you are attempting to burn mp3 files as an audio CD, then that's the problem. You cannot burn audio CDs from MP3 files. You have to burn MP3 files as a data CD and not as an audio CD. See excerpt taken from page 33 in the CDR420 user guide. "Prepares CDs that can be played on standard CD players. Compact Disc Digital Audio (CDDA) uses uncompressed PCM, .wav files. The CDR420 does not convert MP3 files to PCM so MP3 files are ignored if you choose AUDIO as the CD TYPE"
May 04, 2010 | Marantz CDR420 CD Recorder
Will no longer play Red Book CDs - says either
just replace the ribbon wire of your cd player or check lense.by. jhuntech17
Oct 26, 2009 | Marantz SA-11S1
373 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
