Question about Garmin nuvi 1690 Car GPS Receiver
Unlock maps - Garmin nuvi 1690 Car GPS Receiver
    New Friend:
How to get on truck route
Posted on Jul 27, 2013
I have bought a second hand garmin, and the owner gave me the manual and free US navigation map. Recently he also provided me the 25 digit unlock code, but I cannot register or unlock maps, cos when i try...
The unlock code he gave you must be the map unlock code. IF it is you can unlock the map without registering. Details of how to unlock your map are at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
There's more information there than you'll need so skip to the paragraph on unlocking the map.
If the previous owner deletes your satnav from his garmin account you should then be able to register it.
Mar 21, 2011 | GPS
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
My GPS keeps saying cant unlock maps after i already loaded maps on it
The Garmin Maps require a map unlock code in order for the GPS to be able to open/access it. Since the maps are copyright protected by Garmin you should of recieved the unlock code from Garmin when you purchased the new map update.
Mar 07, 2010 | Garmin GPS
I get the message "no detailed maps can be found that support routing. The nuvi cannot be used without them." and I can not get to anything else on the garmin.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  2. Select myMaps
  3. Select Manage Maps
  4. Select the device from the drop down menu
  5. The unlock code is located under the "Maps installed on this device" section
Jul 18, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
When the "no detailed maps found that support routing" screen comes up it covers any of the icons, so I'm unable to do anything.
  2. Select myMaps
Jul 07, 2009 | Garmin nuvi 260W GPS Receiver
Unable to unlock new maps
Where did you download the Australian maps from? If from Garmin, contact Garmin for the unlock code. Maps have to be unlocked to a specific unit.
If you downloaded the maps from the internet, you will still need to contact Garmin for an unlock code.
Jun 14, 2009 | Garmin StreetPilot c340 GPS Receiver
My Garmin nuvi says ''maps unavailable''
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear for the following reasons:
  2. Select myMaps
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Enabling maps on the GPS device:
    1. Touch the wrench icon on the Where to/View map screen
    2. Touch Settings
    3. Touch Map
    4. Touch Map Info
    5. Select the checkbox next to the maps to be enabled on the device
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
Garmin 205w: Can't unlock maps
If you purchased the maps from Garmin, contact Garmin for an unlock code.
Mar 21, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Maps don't show after downloading upgrade.
sounds like you might not have the new map set selected
settings -> map -> map info (make sure the NT 2009 map is checked)
Mar 17, 2009 | Garmin nuvi 350 GPS Receiver
Garmin gps map updates
Unlocking garmin software and maps is very simple - you only need Unical ID you device and SD-card where is you locked maps. Install in keygen and unlock you maps.
If you need help or professional GPS-consultation or unlock you PNA, update navigation maps - please ask
http://www.goodslowprice.com/en/unlock.htm
Apr 27, 2008 | GPS
Garmin nuvi 1690 Car GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
