Videocon washing machine K5500
While in spin mode drum is not rotateing but center part is rotateing
SOURCE: Washer not completing cycle
I HAD THE SAME PROBLEM ON A 4 MONTH OLD MACHINE AND I CALLED A SERVICE PERSON. HE SAID THAT I CAN THROW IT AWAY. THIS IS A PROBLEM THAT NOBODY CAN FIX.
Posted on Feb 15, 2007
the dr
  • 447 Answers
SOURCE: grinding noise when drum rotates
may be a foreign object trapped in between the inner and outer tub. Major Disassembly required to split the outer tub. May also be the rear bearing in which case back half will have to be replaced.
Posted on Oct 04, 2007
  • 209 Answers
SOURCE: Hoover Premier 10.1 kg washing machine
do you actually see the motor spinning? or think you hear it, check the belt hasn't come off, or gone slack, it needs to be fairly tight but not too tight, if the belt and pulley go round but the drum doesn't then you have serious damage and need a new inner drum hope i have helped and if i can help more get back to me, i am an appliance engineer of 20 years
Posted on Oct 07, 2007
barkencoa
  • 3463 Answers
SOURCE: bosch wfk2801 washing machine drum does not rotate
Remove rear panel and check the belt is o/k, if it is, then remove belt, undo 2 bolts that hold motor, unplug the motor connector, lever motor back with a screwdriver, and remove motor.
Check the brushes, they should be at least 5mm long, \any shorter, then replace.
Plz rate my solution.
TRhanks.
Posted on Jan 11, 2009
nikeananth
  • 267 Answers
SOURCE: Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see o circular lid there, turn it on anti-clockvise to open. All of the water blocked will come from there, be careful. Look carefully that there are some objects blocking the water draining. Then turn on the machine on draining programme, the plastic rotor should turn fastly when the machine is on. If it is not running, change the pump motor. If it is running, but machine is not draining again you can understand that there is an objeck stuck on the hose between drum and pump motor. Lay down the machine on its rear facade, you will see a large and black hose between drum and pump motor. When you remove it, you will see that there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
Posted on Oct 04, 2009
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
The drum in my washer will not rotate. Are they belt or direct drive?
Every washer I have dealt with have all been direct driven through a transmission. There are several reasons that a washer drum will not rotate. The simplest reason is that the door interlock is not functioning properly.
Aug 05, 2016 | Washing Machines
My elite drum is not centered and is rotating off center, see additional details please, thanks.
probably need drum or bearing support rods
contact your local authorized service agent for parts
Jun 24, 2017 | Washing Machines
Washing drum not rotating
More than likely belt gone, otherwise the motor has gone.
Apr 06, 2014 | Russell Hobbs RH1042 Frontload Washing...
Washing machine drum does not rotate.
was the waser noisy before it stoped woeking if so it could be your drum bearing or somthing caught in the drum
Nov 10, 2011 | Washing Machines
Drum will not rotate
im confused as to why you think no drum rotation would be caused by bearings. typically worn bearings would cause noisy spin. only if bearings were completely seized would that cause no drum rotation. can you rotate drum by hand? if so bearings are not seized. can you hear motor rotate when you select spin? if not, then likely cause is motor brushes. do these simple tests and get back to me if you want. and bearings are quite difficult to replace on this machine
Apr 26, 2007 | Zanussi F1045W Front Load Washer
Hoover Vision 1600 drum not spinning?
Have the same problem, different model and it looks like I am outside 5 years spare parts. Probably just a belt or something from overloading. Also looks like it would nearly be cheaper to buy a new machine.You must have checked your pump???? What a rip off
Nov 27, 2006 | Hoover HF7 160E Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
