Question about Peavey Rtd31 - 13 Octave 31 Band Equalizer Rtd-31
I need to change the voltage on a Peavey RTD 31 1/3 octave equalizer from
  • Gregg Mitchell Jul 20, 2013
    change voltage from 220 to 120 on circuit board.
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Peavey Expert
  • 232 Answers
Need more info..
Posted on Sep 20, 2014
My pv231 eq just stoped working, the led light is not coming on, what could be the problem? pls help!!
Most common problem is power cord works loose. Beyond that it may be a pwer supply failure.
Apr 13, 2011 | Peavey Pv231eq Dual 31 Band Graphic...
Where can i buy a spare fuse (T100mAL/250v) ?
Buying one is no problem BUT you should NOT have to replace it unless there is a failure within the unit. If there is a failure and you keep replacing it, you MAY be doing further damage within the unit.
You can get fuses from Digikey.com and others.
Feb 09, 2011 | Peavey Pv231eq Dual 31 Band Graphic...
Sound cuts out
Hi Darren.
I suspect you may be right about the eq here, though you probably have had it sorted by now.
I came across this thread because I was searching for a fix to my R-231 and was hoping you might be able to help me if you found a fix. I'm persisting with this one as I can't really get another just now and it seems that it's not a major issue. I managed to get a good signal out of it when I ran it without the ground connected on output???
Anyway, any info I would greatly appreciate,
Thanks, Rob dronno@live.com.
May 20, 2010 | Digi-Tech DOD-Digitech 231 - 31 Band Per...
Peavey TKO115 bass amp. Any help on where to buy parts? My son's amp needs a new AC power receptacle. It works, but was smashed loading it one night.
If you're living in the States, you can go to any RadioShack store.
They can help you, it's nothing special.
Good luck,
Gerard
Jan 24, 2010 | Peavey EQ215FX Home Equalizer
Change the voltage from 240v to 120v
Unless there is a 240/120 switch on the back, this amplifier cannot change voltage. The only way is to replace the power transformer, and when you do that you need to use the exact model transformer Peavey uses for the 120 version. I have also seen differences in handling power outside of just a different transformer for USA/Euro models.
The differences between these two market models might be beyond what is cost-effective to convert.
If it is the Peavey blazer 158, they go for as cheap as 100 bucks here in the states. Or buy one new for 120.00 bucks and 4.99 shipping: http://www.dcmusicstore.com/Peavey-blazer-158-guitar-amplifier
Best advice: sell it for what ever you can get and buy one here.
Hope this helps!
-mike
Mar 28, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Old peavey amp cutting out
time to resolder everything, got a good 10 power eye loupe?
Mar 09, 2009 | Peavey EQ215FX Home Equalizer
Eq on channel a doesn't work on 2 units
It could be an internal ground connection on the EQ that's broken ( maybe inside the connector) ..I repaired numerous peavey products and broken grounds are common.
Feb 11, 2009 | Peavey EQ215FX Home Equalizer
Peavey Bass Amp TKO115s
Start with a clean setting - zero cut and zero gain on the Eq. Play a song close to the amp, and then move away, playing the same notes. Do you still get the distortion? Change lower the input gain and repeat the test. Lower the output gain and repeat. Are any outboard distortion pedals in the mix, such as overdrive? Eliminate them. Run straight through from your axe to the amp. Check for any distortion settings. Set everything including reverb to zero. When the distortion disappears, this is your base setting.
Change only ONE parameter at a time. When the distortion comes back, you have found your problem.+
Dec 03, 2008 | Peavey EQ215FX Home Equalizer
How to hook the eq up??
take output from left and right from equalizer and go to line in any two channels inputs in peavey mixing console and adjust your level with faders and other control knobs.
Mar 02, 2008 | Phonic PEQ3400 2x15-band Graphic Equalizer...
Peavey Rtd31 - 13 Octave 31 Band Equalizer Rtd-31 Logo
59 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
