HP 400 m475 leaves horizontal lines when I print a document .
Horizontal line at times is very dark and at times is faint, but they are always there and at even spaces all the way down the page.
5 Suggested Answers
SOURCE: copies print with horizontal lines
thin lines? spaced about 1.5 inches apart could be toner left on the drum, take the cartridge out turn it over and retract the shutter, manually turn the drum using your thumbs on the edges of the drum, do you see thin lines on the drum? sometimes something sticky gets on the drum attracting toner and then it transfers to the paper during the copy process
Posted on Dec 21, 2007
Ajkill
  • 2035 Answers
SOURCE: Horizontal line print errors
  1. Hold the cartridge upside down, with the bar-code label facing you.
  2. Take a damp paper towel and use it to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
  3. Continue doing this until the printhead looks clean.
  4. Then dab the cartridge on the towel to make sure the ink is flowing.
  5. Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
    1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
    2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
    3. And then perform This
  6. Press the Mode button on the operator panel until the Copy light comes on.
  7. Press the Menu button once to enter the menus.
  8. Press the down arrow button until you see Clean Cartridges.
  9. Press Select. The 'Clean nozzles' page will now print.
Posted on Oct 16, 2008
  • 49 Answers
SOURCE: Faint horizontal dark line about 2 1/8 inches down from the top
You can easily fix this yourself, one of the quickest ways to fix it is to print 10 doublesided blank pages and it will clean the inside of the machine for you and the line will vanish.
For further print quality problems on this machine follow these instructions to troubleshoot.
When troubleshooting image quality problems, it is important to understand the situations in which the problem occurs.
Print a copy of the color test pages to determine whether the problem is in one color or more than one color.
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Color Test Pages], and then press the [OK] button to print the test pages. If the problem occurs with one color on the test pages, perform the solutions for this problem. If the problem occurs in more than one color on the test pages, restart your search and select a case for the image quality problem occurring through all colors.
Posted on Mar 31, 2009
  • 32 Answers
SOURCE: hp 2500l prints a dark line horizontal down each
A dark line on the hp 2500 series can come from the drum You can't clean it at home), it can come from a toner cartridge, from the fuser unit and from the optics.
Step one - check if the line in all colors, run copy quality check through Menu and diagnostics, if the line is only on one color your problem is the toner cartridge.
Step two - if the line is on all colors, take the drum unit out and look at the drum, if you see the line on the drum you need to replace the drum unit.
Step three - stop a print in during the printing process by turning the printer off, take out the drum and look at the printed paper under the drum, if the printed page is clear of line your problem is in the fuser.
Good luck.
Posted on Dec 14, 2010
Testimonial: "Thanks, just the advice we needed. Easy to follow and understand."
Two faint white horizontal lines
the white ghost lines are down to the charge wire within the toner cartridge being dirty, the only real way forward is to replace the toner cartridge as access to the charge chorona wire is not possible without ruining the cartridge itself
Jan 09, 2014 | HP LaserJet 1000 Printer
Horizontal white lines through the text
Your ink cartridge (s) is dried up, even some new ones are dried up, even tho' they're sealed.
Some self-tests don't use black.
Sep 21, 2008 | HP DeskJet 6122 InkJet Printer
HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Sep 14, 2008 | HP DeskJet F380 All-In-One Printer
Horizontal red lines when printing
Horizontal line is carriage axis , while moving its may give line if some dust or resdual ink may be on he carriage base
clean the caping station and cleaning wiper ( place where carriage rests )
if its not resolved please update sample images for same
May 24, 2008 | HP Officejet 6310 All-In-One InkJet...
Prints Faint green horizontal lines
Go to control panel and printers and faxes and right click on printer icon then hit printing preferences, go to maintenance and do head cleaning cyles and print nozzle check. if it comes out fine trash and reinstall driver
download driver from support.epson.com site after selecting the printer mdel on the lists
Apr 12, 2008 | Office Equipment & Supplies
HP 7110 still won't print in color
Your post "...it prints very faint horizontal lines in color..." is indicative that indeed your color printheads are clogged and would need repetitive deep head cleaning. This is of course would require that you keep on cleaning until such time as the faint color lines have turned to legible print.
Apr 08, 2008 | HP OfficeJet 7110 All-In-One Thermal...
When printing in color a yellow line appears on document
A horizontal line U say and U don't have problems in B&W pages.... ( on the length or width af a A4 page?) the yellow line is just a line or parallel lines at the same distance?.
1-st of all try replacing the Y cartidge.
Jan 17, 2008 | HP LaserJet 2840 Printer
Faint blue horizontal lines
Try re-installing the printer driver it might be caused by a virus... if not then you need somebody to clean your printers head mechanism.. the blue cartridge might have messed an ink to its circuit.
Oct 27, 2007 | Epson Stylus Photo R200 InkJet Printer
Faint horizontal lines in picture
This is usually caused by a problem in the Horizontal Output section, around the Horizontal Output transformer usually a capacitor or diode going or gone faulty... the line you see are the Horizontal "Retrace" lines that are useually "Hidden" when the circuit is OK..
Jul 30, 2007 | JVC AV-27320 27" TV
159 people viewed this question
k24674
jasbo
jasbo
