Problem with GPX portable dvd player
I bought a GPX portable DVD Player (Model # PD901WRS )for my nephew's birthday in March. It was fine until a couple days ago but now it has a white screen. It still plays the dvds as we can hear the sounds from the movie but there is nothing on the white screen. Is there a way to fix this?
  • 814 Answers
SOURCE: dvd player will not reconize a dvd when trying to play
Try cleaning the dvd compartment of all dust and debris with a can of compressed air. Check and make sure all the dust and debris is cleared of the laser transport and lens. Use cotton swabs and small amount of isopropyl alcohol to clean off the laser lens and tracks and gears of the transport . Use a cotton swab with a small amount of alcohol on the tip to clean the laser lens. Rub the swab gently across the lens, until it appear bright and shines. Use the other side of the swab to remove any excess moisture from the lens. Use cotton swabs to clean the rails and gear of transport. Applie small amounts of alcohol to the tips to loosen caked on dust or dirt. Use compressed air again to clear the dust and debris from transport area. After the through cleaning. Try the player again, using a dvd to see if the operation returns to normal. If not, try resetting the dvd player to factory setting. You can do this using the on screen menu to go into the settings. Use the remote control and press the settings button. Use the up and down arrows to highlight the preferences section and press enter. Once in the sub-menu use the up and down arrows to highlight the default function and press enter. This will have reset the dvd player to the factory settings. Now try using a dvd to test the player to see if it operates normally. If it does not play normally, you may have a proplem with the spindel, check it to make sure its is making good contact with motor, if it appears loose, applie a drop of super glue to snug up the grip. After it dries completely. Test the player again with a dvd. If the unit still fails to operate normally, you may be having problems with either the drive motor or the power supply circuits. For these problems you need to contact a service center. They will have all the service information to troubleshoot these problems properly. You can call Phillips customer support at this telephone number 1-888-744-5477. They will be able to tell you how to get the dvd player tested and serviced. I hope this information helps you with your problem.
Posted on Jun 01, 2009
  • 65 Answers
SOURCE: No sound on Memorex DVD player
This could be caused by loose tape connector or faulty volume adjuster. First try playing a standard cd, then dvd, and finally a bootleg dvd because they create a lot problems for these smaller units. It would seem that you may need to open the unit inorder to find out what the problem is. If you do please becareful and take notes because you will have to put it back together.
Posted on Aug 20, 2009
brownline45
  • 310 Answers
SOURCE: Sony portable DVD player wont load DVDs
maybe the spindle motor is defective so it cannot read the disc. just bring that your dvd to sony service center to fix your dvd.
Posted on Jun 19, 2010
SOURCE: I have the sdvd87 dual screen portable dvd player.
i found the problem of the video blackout of the second screen, it's the chip marked CC5R sot23-6 close to the a/v connector. it's possible to make it work without changing the IC but you won't be able to have an output or input depending what you want to do if you want to make it work as original, replace that chip and it will work again. any other questions i will come back soon
Posted on Oct 29, 2010
SOURCE: GPX portable DVD model PD808B - wrong region message
Turn on power. Open lid. Enter 9735 with the remote and press 'enter', you can now choose between regions on the screen. Select the desired region unlock and press 'enter'. This works well!
Benony Jonsson
Posted on Dec 08, 2010
I have audio but not picture. I have cleaned the lens with alcohol. Any other ideas or is this trash?
Amazon.com: Gpx PDL805 8.5 Inch Portable DVD Player ...
www.amazon.com/Gpx-PDL805...Portable-Player/.../...
Amazon.com, Inc.
Rating: 2.5 - ‎14 reviews
I got this GPX brand portable dvd player a couple days ago and am so far satisfied. It does everything I ... The picture is pretty sharp, and the sound is decent. And I didn't... Not Happy with my GPX8.5 portable dvd player PDL805. By Nanarozi ...
Gpx PDL805 8.5 Inch Portable DVD Player > Customer ...
Amazon.com, Inc.I got this GPX brand portable dvd player a couple days ago and am so far satisfied. It does everything I ... There is no menu button on the player itself! If you don't have ...The picture is pretty sharp, and the sound is decent. And I didn't expect ...
gpx dvd player sound Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on gpx dvd player sound related issues.... Question about PDL805 Portable DVD Player ... lets I have a GPX PD708BPortable DVD player that has picture but no sound, this is actually my second ...
GPX PDL805 Portable DVD Player Pd808b - Questions - Fixya
www.fixya.com > ... > GPX > GPX PDL805 Portable DVD Player
Jan 06, 2016 | GPX PDL805 Portable DVD Player
I need a plug for my gpx model#pd708b portable dvd player
http://www.amazon.com/adapter-charger-PDL805-YG-PDL907-YGPDL907/dp/B001R2664O
There's one for the wall!
http://www.acdapter.com/gpx_dc_car_adapter.html
And theres one for the car!
Jul 10, 2009 | GPX PD708B Portable DVD Player
Gpx dvd player model D1816
We have the problem fixed. My nephew did it when he stopped by on his way home to Georgia. Sorry I can't tell you what he did. Thanks anyway.
Not interested in the plan.
Jun 25, 2009 | GPX D1816 DVD Player
NO SOUND
C14 was leak and resistor R2 burn out, I replace C14 with 0.1 uF and R2 with a chip fuse, sound after that was great at the speakers.
A.S.
Apr 18, 2009 | GPX PD708B Portable DVD Player
GPX DVD player flashing power light
Ihave a GPX portable dvd player that has a broken charging jack on the unit itself. The model is a GPX 808.
Mar 11, 2009 | GPX D1816 DVD Player
Benony Jonsson
Feb 20, 2009 | GPX PD808B Portable DVD Player with Screen
Need manual for gpx dvd player
Please visit the below mentioned link to download the style sheet of this product:
GPX PDL805 Style Sheet
Thank you
Dec 08, 2008 | GPX PDL805 Portable DVD Player
Dvd GPX cannot find the remote code for it
I need to program a universal remote with my GPX DVD player
does anyone know the 3 digit code?
Jan 03, 2008 | GPX D1816 DVD Player
Connecting to front inputs of a Toshiba tv
As a replacement for "Dolby Digital DT3 AV cable" can be used a " 3.5mm (mono) to RCA(or coaxal)" Cable.
Just make sure that DVD Player set for "SPDIF/RAW" or "SPDIF/PCM" output
Oct 12, 2007 | GPX PDL805 Portable DVD Player
Televison & Video Logo
Top Televison & Video Experts
