Question about Apple iPod nano
Charging via ac dc
My ipod nano charges and syncs when connected to my computer but wont charge via the AC connection or the DC connection in my car.
Sounds like your ipod is having trouble reading your firewire connection, it is different than usb. you could probably go to the nearest apple store and get it replaced if its under warrenty.
Posted on Aug 29, 2007
SOURCE:
Wire my ac jack for my samsung np365e5c
The AC adaptor goes into the AC socket, NOT the computer connection. The Computer connection is DC and comes from the DC side of the Adaptor. If you mean the DC socket has broken, then you need someone to replace it inside the computer.
If the AC adaptor has failed, you can buy a replacement ( 19V 3.16A 60W AC Adapter).
See the Manual
http://downloadcenter.samsung.com/content/UM/201408/20140829115137641/Win7_Manual_eng.pdf
Feb 23, 2015 | Samsung Computers & Internet
Charger ipod model a1199
http://www.everymac.com/systems/apple/ipod/specs/ipod-2nd-generation-nano-specs.html
USB Support:
Sync & Charge
Firewire Support:
Charge Only
Details:
The second generation iPod nano models are capable of charging and syncing by USB via the dock connector. It also can charge, but not sync via Firewire "400".
Connectivity:
USB
Ports:
Dock, Headphone*
Details:
Apple reports that this model provides "USB through dock connector."
*Ports include the "dock connector [and] stereo minijack".
http://www.bing.com/images/search?q=images+of+apple+ipod+usb+chargers+&qpvt=images+of+apple+ipod+usb+chargers+&FORM=IGRE - view=detail&id=9C41186E7131E6658B9324CCA
Aug 05, 2013 | Computers & Internet
Won't charge, purchased new battery and new AC adapter, still does not charge. AC charges other Dell I have so must be in charging circuit or connector. How do I disassembly computer to voltage getting to...
You are right, most of the situations like this end up that the charging connector fixed / soldered to the motherboard get damaged because of shaking the connector when ever we connect and disconnect it .
Mar 06, 2011 | Dell Inspiron 2600 Notebook
My ipod nano does not hold charge.
What you can try and do is to charge it ac not dc. Ac would be in the car with a car charger. But if that is how you always charge it that is why it dont keep charge cause an long about of time charging your ipod in the car is bad on ac. The reason im telling you to charge it ac is because the battery is not use to it. Or vice versa.
Nov 18, 2009 | Apple iPod nano
Unable to charge the 3100. If charged via car
the Magellan Maestro can not be charged using the USB connection.
make sure green light is on if using the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 800,860,2000,2200t,2500,3000,3050,3100,3140,4000,4040,4050 and the 6000t are known to have faulty dc connectors...if your Magellan gps is not charging or will not power up, its most likely the dc power port.
you can get it repaired here
or buy the port here
Sep 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Ipod 4 GB not charging and gets very Hot when I try to charg
my nano 4gb ipod gets hot when i try and charge it on conputor ac ports it gets hot
Mar 18, 2009 | Apple iPod nano
Apple ipod not getting charged
First, please check your connection (I'm sure you have already done this). Make sure that the cable is plugged in and working on both ends.
If that is fine, I would recommend taking it back and getting a new one. If you just recently purchased it, you should be able to return without a problem. It sounds like you might have a defective product and you don't want to get stuck with it after the return period.
Good news is that when you get the new one, if you use iTunes, it will automatically sync up and you wont have to manually load songs.
Hope this was helpful but if you still have questions, let me know.
Have a great day
Nov 13, 2008 | Apple iPod nano
Battery is not charging
Charger board seems to have gone bad.
Aug 05, 2008 | HP NC4010 Notebook
I can't charge the battary.
Disconnect DC power cable from AC adapter/charger. Battery charging will not be possible if the DC power cable is left connected to the AC adapter/charger.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Apple iPod nano Logo
53 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
