Question about Hardware & Accessories
Utilitech wall timer
After a few months, the display went out. The screen's gone dark and the switch will not work. I've this happen with other timers as well; they work for a few months and then the screen flips out and the entire switch stops working. An electrician friend says he's had that happen and there are batteries you can replace (because the digital screen isn't powered by the wall wires usually), but I cannot see any place to get inside it and change any batteries.
  • 5,089 Answers
Utilitec timers do not have replaceable batteries.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
Older timer designs have batteries, while more modern timers have internal rechargeable battery that is integral with circuit board, and cannot be replaced. The battery holds memories in event of power outage, but current time must be reset if power is out for extended time.
If you have continual problems with failed timers, then have electrician friend run test on your power for spikes, shortages and surge that will cause timers and other non-hardened electronics to fail frequently. Also check for polarity and grounding issues. Also if you have motors, other electronics and/or fluorescent lights on same circuit, this can cause interference.
Also check load limitations, and load on timer to make sure you are not exceeding the timer rating. For example using timer to control motor when timer is rated for non-inductive incandescent loads.
Reset timer using reset button, and then re-program. Buy another timer at Lowes and return defect in new package for refund.
Buy Intermatic ST01C timer. This timer uses CR2 battery, and timer electronics operate separately from electric line. Rated for any load: motors, cfl bulbs, led, incandescent, etc.
http://waterheatertimer.org/ST01C-program.html
Add a comment
Posted on Jul 18, 2013
SOURCE: I HAVE UTILITECH 7-DAY DIGITAL IN WALL TIMER.
Great! I just bought one and am typing the directions from a blown-up scan so I can read them. This us the 3rd timer that doean't seem to want to be programmed and I am forced to operate manually!
Posted on Mar 14, 2010
  • 351 Answers
SOURCE: Trying to replace Intermatic with Utilitech inwall
The wires on your new switch are intended for black = power .. white = neutral . and red = lights .. with two black wires on the old switch I am assuming that there is a bundle of white wires in that wall box, the white timer needs to join that bundle ... then you need to determine which black wire is the power from the electrical panel ( voltage tester) and connect to the black timer wire .. the red timer wire connects to the other black wire in the wall..
Please Vote !!
Posted on May 13, 2010
SOURCE: Utilitech 192773 timer is DOA
90%m chance you have the two black wires reversed - can't hurt to try to reverse them
Posted on May 24, 2010
  • 351 Answers
SOURCE: I bought a Utilitech 7 day digital in wall timer,
HI .. if the switch has only a black and white wire attached, and there are no other wires in the wall box, then you cannot use this timer switch. You need to return it and get a timer that does not use a neutral connection. The wires you have are a switch leg from the light and there is a white wire but it is not a neutral.
If there are other wires in that wall box , tell me and we can chat more about how to remedy this .
Please Vote !!
Posted on May 25, 2010
SOURCE: Utilitech 7 day in-wall digital timer #LW60418
Need programing instructions
Posted on Nov 13, 2010
Utilitech TM-029 wall timer: I've installed the
Do not run any timer warm... replace with switch, and/or buy another timer.
Copy following link to identify timer and download instructions:
This timer is rated 15 amp 1875 watts.
Safe maximum is always 80% rating plate: is 12 amp and 1440 watts.
Add up total watts on circuit.
Add a comment and say what you discover.
Jun 29, 2013 | Hardware & Accessories
Installed Utilitech 192773. The lights works, the backlight display comes on light blue but there is not numbers on the digital digital display
Reset timer, and see if that fixes problem
Use toothpick or paper clip to press reset button, or refer to instruction sheet, or copy following link.
I have tested this utilitec timer, and using reset button will repair most problems.
If not, then Timer has 1 year warranty against defect, but it is easier to buy new timer at Lowes, and return defective timer in new package and report timer as defective.
Jul 29, 2012 | Hardware & Accessories
I have a Utilitech In Wall Digital Timer Lowes Item #: 141224 | Model #: LW60418, purchased from Lowes. I've lost the instructions and can't figure out how to set the timer after a power...
Open following link for Utilitec timer manual:
This timer should have a back-up capacitor so that programming is kept in memory during power outage.
Power outage is known cause of timer failure. When power turns on, the surge knocks out electronics.
People writing to fixya report electronic timers and electronic water heater controls stop working after power outage. Probably many other electronic devices are affected too, but that would be out of my specialty.
Troubleshoot says 'in case of operational failure, press reset button to clear all settings and restart.'
If timer has failed, buy another from Lowes and return defect in new package.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 11, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Bought a Utilitech #0192773 to replace an older and non-working Intermatic SS7 series. The Intermatic had a black wire connected to hot, and a blue wire connected to neutral, and a red wire was capped off...
Utilitec 0192773 replaces single-pole switch and will not work for 3-way applications.
Open following link for clear wiring and programming steps for Utilitec 0192773
Utilitec can also be tricky to program if you are setting up astro dawn-dusk function.
For others finding this thread, same wiring applies to in-wall programmable timers by GE, Woods, Swilight, Sylvania, Tork, Hagar, UPM, Leviton, Grasslin, Wattstopper, Westek, and Intermatic analog timers. Intermatic battery-operated, Brinks and Aube timers are wired differently since they also work for 3-way applications.
Jun 05, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I HAVE UTILITECH 7-DAY DIGITAL IN WALL TIMER. THE TIMER WILL NOT PROGRAM AND ONLY WORKS MANAUAL ON/OFF SWITCH.
Mar 13, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Acer Travelmate LCD screen went dark
The same thing happened on my HP. I ended up buying a LCD screen off ebay. That corrected the problem. New screens cost $150+. You can get one off ebay for half the price.
Jan 16, 2009 | Acer TravelMate 270XV Notebook
Hardware & Accessories Logo
60 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
