Sony trinitron xbr
The picture on our XBR is concave on both sides. What does that mean? Thanks in advance. :)
    Top Expert:
  • Televison & ... Master
  • 74,118 Answers
Its 'pin-cushion' circuit has damaged. If you wish to get more details about the 'X' correction circuit, check the site linked here. Do a search. number. http://electronicshelponline.blogspot.com/ Pull up previous posts there, by type in the model name to your set in its search box.
Posted on Jul 19, 2013
Testimonial: "Thank you very much, Sasi. I'll do that."
  • 6 Answers
SOURCE: SONY 36 XBR SOUND BUT NO PICTURE
posible solution is adjust the screen to low.also check the trimer if it is working.check the resistor in the heater line...weng
Posted on Dec 29, 2007
  • 94 Answers
SOURCE: I have a sony trinitron XBR and the PIP won't turn
Please make sure that one input is connected to the UHF/VHF port of the TV and other is connected to composite or component ports. If you have connected likewise, please perform the steps below:
  1. Ensure the video source is turned on.
  2. Ensure the video source is connected to an available VIDEO input jack on the back of the television. IMPORTANT: The VIDEO 5 input cannot be used to view a program in the PIP window.
  3. On the television remote control, press the TV FUNCTION button.
  4. On the television remote control, in the PIP section, press the TV/VIDEO button to select the appropriate video input for the PIP window.
  5. If the issue is not resolved, connect the Audio/Video (A/V) cable from the video source to a different VIDEO input jack on the television.
  6. On the television remote control, in the PIP section, press the TV/VIDEO button to select the appropriate video input for the PIP window.
  7. If the issue is not resolved, replace the A/V cable.
Posted on Sep 22, 2009
  • 83 Answers
SOURCE: I have a sony trinitron XBR 32 inch... The pip was
pls. use remot menu key and open main menu use DW key and select system menu see the PIP option is "ON" set option is"OFF" .
See the PIP screen is clear.
Posted on Oct 20, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: sony trinitron xbr screen periodically goes black
Sony sets have several protective circuits that blank the screen if something happens that might damage the picture tube. One of the more common causes is trouble in the vertical output circuit. Given the age of your TV (the XBR models have been around a while), this might also be a symptom of a picture tube starting to fail. Most of these sets have circuitry (called AKB) that adjusts the color drive signals to the picture tube to keep them balanced. If one of the colors is enough out of range the screen will blank. It might be the tube itself, or failure of some part in that AKB circuit. The set might also have defective parts in the input switching or video processing stages.
Unfortunately, I can't suggest any place you might look if you want to try repairing this on your own. This kind of trouble usually needs to be diagnosed and repaired by a professional TV technician who has the service information to track it down.
Hope this has been helpful. Thanks for using Fixya!
Posted on Feb 20, 2010
Testimonial: "It sounds like you know what you are talking about."
  • 1274 Answers
SOURCE: I have the Sony XBR 40in Trinitron and it won't
sounds like you have some cold solder or bad joints,power section, inspect it ,with the back off, but be carefull.........i had one that did that...bad connection in solder joint...had to resolder,if you have to resolder,make sure it is unpluged.hope this helped....
Posted on Feb 23, 2010
My sony trinitron xbr won't come on when the remote iis pressed it only clicks.. no picture or sound
Your problem could be any one of the boards in the set. When a flat screen attemps to turn on, but finds an internal problem, it defaults by clicking off to keep the remaining circuits and boards from buring up. You'le have to take the tv to a shop. Sorry that I can't be of more assistance.
"Original Radio Man"
Ed
Feb 13, 2013 | Televison & Video
MY sony trinitron XBR TV does not stay on.
what's wrong with my Sony trinitron XBR tv's timer
Apr 27, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Feb 23, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony Trinitron XBR TV, picture-in-picture got
A solution I found for our KV-32XBR200 was to press Setup on top of the set, then select the "Demo" item with TV/Video. The text overlay apparently banished PIP. Verified this twice, as I'm at this page because our remote can only turn PIP on :-).
Dec 24, 2009 | Sony Televison & Video
Sony xbr 27"
you do have a deffective crt
Jul 30, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Trinitron XBR Try to turn on but light just
Look for the service manual, it contains the explanation of the flashing light codes, it will tell you what part is faulty.
Jun 26, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture, Standby blinks then goes out
Sony Trinitron XBR
Problem/ Standby Flashes Power button
Aug 12, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron XBR
VHF/UHF works for me. Make sure the game/tv/video rtc tab is correct
Dec 23, 2007 | Sony KP-51HW40 51" Rear Projection...
Oct 30, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
