Question about True T-49 Side by Side Refrigerator Commercial
Kitchenaid ksrg25 I replaced the relay this AM now the compressor is hot to the touch. Is this normal until the unit reaches its normal cycle/operating temp?
  • rick Jul 19, 2013
    Guess it is not normal as the unit is not shutting off...unless I do so buy turning off the unit. Any ideas as to how/what I did not connect correctly?
2 Suggested Answers
  • 1250 Answers
SOURCE: What is the normal operational
why yes there is. Generally speaking, the head pressure should be around the "ambient +30" rule.
That is, measure the entering air temp to the condenser, say 75 degrees. Now add 30 to that and get 105 degrees. Look at a P/T chart and see what the pressure is for that temp which is about 253 for R-404-A.
The evap on a freezer leads the load so, as a general rule, the evap temp is going to be around minus 10 degrees to get a 0 degree box. Coolers are different. So, the pressure for a minus 10 evap is around 25 or so. But the unit has to be close to operating temp. If the box is warm, naturally the pressure is higher. And what influences the pressure is whether or not it's a TXV or a cap tube system.
If a TXV and no receiver, charge by subcooling. If a receiver, fill by sight glass. If Cap tube, charge by superheat.
Hope that answers your question.
Posted on Oct 06, 2010
Should my refigerator compressor be hot to the touch?
Hello friend, thanks for the post!
Based off the information you have provided your compressor can be hot to the touch because it is working to help cool down your refrigerator. I would allow it the opportunity to maintain proper temperature inside of your appliance before it stops running. I hope this is helpful. -Matt
Sep 23, 2014 | Frigidaire Refrigerators
Kitchenaid KSCS23IN Burning Hot Divider Wall then No Compressor, No Fan, No Cold Can Hear Clicking
The clicking is caused by the clixon turning off power to over heated motor that is not starting. Check the condition of the starter cap or relay and change. If a good cap or relay does not start your compressor then the rotor is frozen and you need a new compressor. (ouch)
Mar 12, 2017 | KitchenAid Superba KSCS23IN Side by Side...
Describe your 50522 / 50524 Side by Side Refrigerator Problem Compressor does not run. Control relay mounted on compressor rattles but has connectivity to the 3 terminals going to compressor
Hello if the start relay is rattling it is at fault and would have to be replaced. You may have connectivity between all poles but if the inside of the relay is rattling you would most likely have one side touching the other when the compressor trys to start which would not make the compressor start at all. It would be like taking the hot and grounding it out before it had a chance to reach where it is supposed to be grounding out to or not even makeing it to the common side at all. I would first look at replaceing the start relay and overload and then see how your unit is running after replaceing these two with the new replacements. If you have any further questions message me back Thanks Rick
Aug 30, 2011 | Kenmore 50522 / 50524 Side by Side...
Unit is not cooling. Compressor fan is constantly running and the compressor is hot to the touch but not running. Is my compressor broke?
It may be broke but the start relay and capacitor should be replaced first...
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 06, 2010 | KitchenAid KSRS25IL Side by Side...
I have Kitchenaid Model KSRG25 and need water filter replacement. Need number of water filter to order
If it is the model KSRG25FK, the following filters will work:
4396510 (best filtration)
4396508 (standard filtration)
May 20, 2010 | Refrigerators
Ksrg25 kitchenaid is running, cooling, freezing but making a clicking noise at compressor every couple of minutes or so?
there ia probably a mouse knawing a the rear entry conductor, it's warm and does have a slight vibration... be very quite and listen...
Mar 24, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Wine fridge not cooling
It is normal for a compressor to be hot to the touch, but not super hot. clicking noise sounds like the relay located on the compressor terminals is bad. Hope this helps
Jul 27, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Failure
compressor is hot but is it running. one likely thing i would check is the start relay on the compressor.
Dec 09, 2007 | KitchenAid KSRS25IL Side by Side...
True T-49 Side by Side Refrigerator Commercial Logo
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
